Belt tensioner specs?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MGH-PA, Nov 19, 2009.
  1. Nov 19, 2009 at 12:14 PM
    MGH-PA
    MGH-PA [OP] Well-Known Member
    Northcentral, PA
    05 Tacoma TRD AC 4x4
    265/75/16 Nitto Terra Grapplers, Bestop
    Ok, before I go ripping idler pulleys out this weekend, I want to make sure the squeal I'm hearing isn't the tension not being quite right. Is there a torque spec on that 14mm bolt for the tensioner or do you just go by physical play in the belt?
  2. Nov 19, 2009 at 12:19 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    No torque value I know of. The tensioner keeps the belt at the propper tension via a built in spring.
  3. Nov 19, 2009 at 12:26 PM
    MGH-PA
    Northcentral, PA
    Alright. Now to figure out which pulley is bad:cool:
  4. Nov 19, 2009 at 12:27 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    You only have 1 tensioner pully. Thats usually the one that goes bad.
  5. Nov 20, 2009 at 4:32 AM
    MGH-PA
    Northcentral, PA
    I don't think it's the tensioner. I was referring to the three idler pulleys.
    It's odd. The truck squeals slightly when I first start, but not like it did before the belt was replaced. Before the belt was replaced, it squeaked on cold or wet starts, and would only last for about 30-40seconds. Now it starts again on colder mornings (not so much wet days unless it's cold), and squeals usually only during acceleration and lasts much longer (ususally about the first 5 minutes of the drive).
    I can't pinpoint the source no matter how hard I try. The noise isn't getting worse either. Does that really sound like a pulley, or is my belt (non OEM) already garbage again?
  6. Nov 20, 2009 at 4:49 AM
    MGH-PA
    Northcentral, PA
    September 12 was the last day I changed my oil (~2,000 miles ago). The belt was replaced a month before that. This problem started I would say about a month ago.
  7. Nov 20, 2009 at 5:23 AM
    Asgard
    Asgard Well-Known Member
    06 PreRunner DC SR5 w/LSD
    I have a bad u joint and it squeals like a bad pulley or belt. Mine is accompanied by vibration but I was talking to someone who recently changed theirs on their '05 and they said they had the noise but no vibration.
  8. Nov 20, 2009 at 5:43 AM
    MGH-PA
    Northcentral, PA
    Well I know the u-joints are good, and I've definitely isolated the noise to the front of the engine, I just don't know whether it's the belt or pulleys (and which one).
    Chris (or anyone else), should I be able to test these pulleys out with the belt of to see if they're bad (spin them by hand, and if they stick or don't spin smoothly, I can assume they're going bad)?
  9. Nov 20, 2009 at 5:49 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    You can try to localize the squeak by useign a stethescope, but you need to be VERY carfull with the engne running, and use one long enough for use in listening to pullies. You need to put it on the pully shaft, or the item you are checking, ie, alternator, powersteering, etc..
  10. Nov 20, 2009 at 6:03 AM
    Rhino8541
    Rhino8541 I like ze best!
    AZ
    2017 QS DCSB OR
    Anyone done a write up on changing the belt pulleys? I've had several replaced on two separate occasions by the dealers. I can't imagine they are going to do many more under warranty, so I'm gonna have to start doing them myself I think
    Also, can't you take the belt off, and spin the pulley's by hand to hear them individually for squeaking?
  11. Nov 20, 2009 at 7:16 AM
    MGH-PA
    Northcentral, PA
    That's what I'm wondering.
  12. Nov 20, 2009 at 7:29 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Many times they wont squeak without a tenson on them...
  13. Nov 20, 2009 at 7:55 AM
    MGH-PA
    Northcentral, PA
    Great. I thought about the stethoscope idea, but like you said, I'm not too keen on jamming that thing in there.
    Do pulleys that are going bad get progressively worse over time? Mine haven't gotten any louder or any longer in duration which leads me to believe it MIGHT be some dirt/grease on the belt. I might pull the belt and wash it in soapy water.
  14. Nov 20, 2009 at 7:56 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    They do tend to get worse, but it depends on the environment in which you drive as to how fast they go bad.
  15. Nov 20, 2009 at 8:04 AM
    MGH-PA
    Northcentral, PA
    Ok, so other than a stethoscope, there's really no way to pinpoint which pulley is bad? Because honestly, when it was finally squeaking on startup yesterday with NO acceleration, I got out of the truck, popped the hood, and listened. I could NOT even pick a side of the belt system as to where the noise was originating. This is going to be fun.
  16. Nov 20, 2009 at 8:06 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I use an 18" long peice of 1" dia. steel pipe. I place the pipe on the item (alternator, PS pump, etc), and listen that way. BUT....yes.....Thats about the only way to track it down.
  17. Nov 20, 2009 at 8:07 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    If you have an IR thermometer, with the engine off, you might be able to see wich pully is more warm (indicating more friction), but Im not sure how accurate that would be on a pully that is just squeeking.
  18. Nov 20, 2009 at 8:17 AM
    MGH-PA
    Northcentral, PA
    Sounds good. I think I can scrounge up something.
  19. Nov 24, 2009 at 6:55 PM
    eyball
    eyball Well-Known Member
    Quinebaug, CT
    05 Double Cab SR5 V6
    Extang Tri-Fecta Tonneau cover, Westin nerf bars, K&N intake, OEM roof rack.
    any luck on this one? My 2005 is doing the same thing. I am on my second belt replacement and the last new belt OEM lasted for about 4 months before the noise came back. Right now its only there when its wet out. I know its the belt as I rubbed some sidewalk chalk on the inside of the belt today before I left for work (with engine running-very careful) and the noise goes right away. It will be back in a day or so though.
    I am thinking about trying a Goodyear gatorback belt next. After that my guess is the belt tensioner is not applying enough tension although it seams pretty tight. You cant even turn the belt 90 degrees whcih I always thought meant it was tight enough.
    I never thought about oil getting on it. I attach a hose to the drain below the filter but maybe then I take the hose out when I am done its possible some oil dripped on the belt at that point. I would think the chalk on the belt would dry up that issue though.
    Who the heck knows but this sure is annoying!
  20. Nov 25, 2009 at 3:15 PM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    You can take the belt off and see if there is any play in the pulleys by rocking them back and forth. Also, do any of them not spin freely? Is the water pump leaking out the seep hole?
    I am just going to take a stab in the dark and guess water pump but only because I have owned alot of GM vehicles in the past and they were notorious for failing water pumps and fuel pumps.
