Belts, chains and water pumps...
Discussion in 'Technical Chat' started by silvertrd09, May 13, 2013.
  1. May 13, 2013 at 9:18 PM
    silvertrd09
    silvertrd09 [OP] Well-Known Member
    Andrew
    New Waverly TX
    09 TRD 4x4
    Wanting to do some preventative maintenance on my 09 V6 and would like some input. My truck has 93,400 miles on it. I just replaced the spark plugs two weeks ago along with an oil change and filters. I drive a lot of highway miles and will be going to west Tx. on Memorial Day weekend. Its about 500 miles one way. I would like to change out the water pump before it would have a chance to puke the coolant out on Hwy 90 west of Del Rio somewhere. How long do they last (OEM). Is this too early to worry about it failing?? If to change it what about the Timing belt? This is different that the Timing Chain? Do I have both, belt and chain?
  2. May 18, 2013 at 7:59 AM
    BamaToy1997
    Bill
    Navarre, FL
    As memory serves you have a timing chain. Barring and major mechanical issues, you shouldn't have to worry at all about replacing the timing chain. They usually last the life of the engine in most cases. Water pumps are not typically considered "preventative maintenance" items. If they are not leaking, and your truck is not running higher temp than usual, or overheating, then there is no need to replace it.
    The older 3.4 L V6 engines have a timing belt, which also drives the water pump, so it is usually standard practice that when you change the timing belt, you also replace the pump.
  3. May 20, 2013 at 7:18 AM
    SpacemanSpiff
    SpacemanSpiff Well-Known Member
    James
    08 TRD Off-road
    Yours has a timing chain - no timing belt...unless there is another that I don't know about...
  4. May 20, 2013 at 7:25 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    You have a timing chain (I believe it's a chain as mentioned above) and a serpentine belt. As mentioned above, you don't need to replace the timing chain. The serpentine belt is what drives the water pump and is visible on the front side of the engine. If the water pump isn't leaking or making noise, I wouldn't mess with it. The belts and pulleys kind of depend on the vehicle. I just replaced all my idler pulleys and serpentine belt on my 2007 with 80k miles. One of the idlers was making noise so I replaced them all and put a new belt on. At 90k+ miles, check out the belt, if it looks like it's dry and cracking, it might be a good idea to throw a new one on. It's easy and relatively cheap. While the belt is of, check all your pulleys although if any of them are bad, you'd likely hear it as they usually squeel when they're worn out.
  5. May 20, 2013 at 7:50 AM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    What they all said.
    The reason you change the pump and belt at the same time is if the pump goes, you're already in there so change the belt and vice versa. My old girlfriend had an Escort that needed the belt and didn't listen when I told her to have them change the pump too. Not a month later the pump broke and ruined the belt.
    In absentia of a timing belt, water pumps are a replace if they break item..as they all were in the good old days :)
  6. May 21, 2013 at 11:35 AM
    silvertrd09
    Andrew
    New Waverly TX
    09 TRD 4x4
    Thanks guys for the info. I have purchased a belt yet be put on. My main concern about the pump is that i know it will fail at some point and was worried as I will be traveling with my 11 yr old daughter. I will keep an eye on the pump.
  7. May 31, 2013 at 4:15 PM
    jerzeyjoe
    jerzeyjoe Well-Known Member
    New Jersey
    08 Prerunner 2W
    If it gives you peace of mind, change it.
  8. Jun 9, 2013 at 9:00 AM
    silvertrd09
    Andrew
    New Waverly TX
    09 TRD 4x4
    Made it out West. Truck performed awesome.
  9. Jun 9, 2013 at 9:20 AM
    DJB1
    DJB1 Well-Known Member
    Dave
    SLC, UT
    2003 Regular Cab 4X4 5MT
    Water pumps have a small "weep hole" on the bottom that begins to leak a little bit when the seal in the pump is on its way out. If you check out the weep hole with an inspection mirror and find wet coolant dripping out, or a big stain of dried coolant all over it, then it's time for a new water pump.
    If it's dry or has a tiny bit of dried coolant around the hole, the water pump is fine. Even on my shitty Ford Ranger I had before I got my awesome Tacoma, the water pump lasted the life of the truck.
