Belts & Hoses
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Billo, Aug 22, 2017.
  1. Aug 22, 2017 at 8:08 AM
    Billo
    Billo [OP] Member
    I have a 2012 Taco, 4wd, Dbl Cab 6 cyl. SR5 Package. It was purchased new. The truck has 64,000 miles on it. At what point should I have the belts and hoses changed? Thank You
    Billo
  2. Aug 22, 2017 at 8:13 AM
    MurderedTacoV2
    MurderedTacoV2 Booty Admirer
    Adam
    Hudson, New Hampshire
    06 Taco TRD OR
    3 inch lift, B110’s, Dakars, Dirty5’s, Dual Locked
    serp belt 70k-90k max i would say. Mine shredded at 92k but better to do it sooner than later.
    hoses though i have no idea im at 98k and my hoses are mint
  3. Aug 22, 2017 at 8:25 AM
    Jeffs68
    Jeffs68 Well-Known Member
    2015 PreRunner TRD Sport DC
    Stock
    Asian hoses last forever...
  4. Aug 22, 2017 at 9:06 AM
    Tex-Tac
    Tex-Tac Well-Known Member
    TEXAS
    2008 Tacoma V6 PreRunner SR5 Extended Double Cab Desert Sand Mica
    Installed Overhead Compass and Temperature Display along with outside temperature sensor and wiring; LED lights reverse backup; LED license plate lights; Added GTA Bluetooth Audio kit to stock radio for iphone audio; Spare tire steel braided air hose extension connection to rear bumper; Installed new headlights along with new bulbs PIAA H4 XTreme and for fog lights PIAA H10 XTreme bulbs. Installed new hood with "hood-scoop". Installed Predator Side Steps. Replaced front chrome grill with customized color matched (Desert Sand Mica) grill with added TOYOTA lettering (also in matched color), installed and secured tailgate anti-theft devices. Also installed a new external TPMS monitor for all 4 tires.
    Hahaha!..70K-90K max!.......I recently changed the belt on my 2008 Tacoma which has well over 200,000 miles on it and quickly coming up on 10 years old now. Hose's look fine too.
    Seriously though, check/inspect your belt (using a flashlight helps) and make sure there are no visible cracks, nicks, stress lines, etc. If you see even what may appear to be anything suspect, then change it out. It's quick and easy to do, just double check and make sure you get the right belt for your engine type. Better yet just buy it at the dealership parts department.
    I married my tacoma likes this.
  5. Aug 22, 2017 at 9:12 AM
    80schild
    80schild Well-Known Member
    Chad
    Flori-Bama
    2007 TRD Sport Access Cab
    I change belts at 60k miles.
    Hoses I replace at ten years old, no matter what they look like on the outside.
    I married my tacoma and Tex-Tac like this.
  6. Aug 22, 2017 at 10:28 AM
    Muddinfun
    Muddinfun Well-Known Member
    And put your old belt in the truck. It's always good to have a spare belt with you. You never know when you might need a belt at midnight, or on a holiday, or 20 miles out in the woods.
  7. Aug 22, 2017 at 11:59 AM
    Tex-Tac
    TEXAS
    I totally agree 100% because, well you just never know. That's what I did with my old belt, have it stashed in the back compartment.
