Belts lasting 100+ k miles?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NmapFE, May 27, 2022.
  1. Dec 3, 2024 at 9:02 AM
    #41
    GorgeRunner
    GorgeRunner Out There
    2005 PreRunner
    I am replacing the tensioner pulley bearing.
  2. Dec 3, 2024 at 9:08 AM
    #42
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Yup… that’s what exploded on me 300 miles from home.
  3. Dec 3, 2024 at 9:23 AM
    #43
    TacoTuesday1
    SD CA
    I think as of recently 99% is done.
    did pulleys. Belt on order again. Compressor alternator pump.
    only thing left I plan to do is crank pulley. I’ve seen report(s) of those breaking on here with bad results and I don’t want to go through that. I believe it is rubber dampening material so that can’t last forever.
    serpentine tensioner was easy to do with the compressor and whatnot out of the way when replacing compressor.
    Also need to do compressor clutch as to my surprise (should’ve listened to the pic I guess) new denso dealer compressor did not come with a clutch on it.
  4. Dec 4, 2024 at 8:00 AM
    #44
    GorgeRunner
    2005 PreRunner
    When I have to dismantle a good part of the truck, I replace everything within reason while I'm in there.
    Steves104x4[QUOTED] likes this.
  5. Dec 5, 2024 at 3:56 PM
    #45
    ThatguyJZ
    ThatguyJZ Instagram: thatguyjz
    Jim
    TRIAD, NC
    2014 MGM DCSB 4x4 TRD Off Road
    A TRD OR built into a Baja/PRO hybrid
    My drive belt still looked good at 100k. Changed it anyway just with the miles.
  6. Dec 5, 2024 at 4:27 PM
    #46
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Kolter45 and Steves104x4[QUOTED] like this.
