Belts Screeching
Discussion in '1st Gen. Tacomas (1995-2004)' started by stinkyspice, Sep 25, 2022.
  1. Sep 25, 2022 at 2:26 PM
    stinkyspice
    stinkyspice [OP] Well-Known Member
    Okay guys I need some help. On my 3.4L I’ve changed all my belts twice with new belts. Currently have the continental belts installed. I’m trying to find the source of screeching when I turn the truck on. It lasts about 5-30 seconds seems like when I throw it into gear it quiets down and goes away. And seems to only happen after the car sits. So screeches at a cold state. I’ve changed belts twice. Changed the AC tensioner yesterday. Could it be a issue of the belts being to tight? Thinking maybe it could be the alternator bearings but it’s not a consistent sound or some other pulley. But it run very quiet and smooth once the screeching stops. Any ideas would be super helpful. I’ve taken off and on belts and tightened and loosened so many times .
  2. Sep 25, 2022 at 4:03 PM
    02hilux
    Planet: EARTH
    Get a can of silicone spray and spray each moving pulley.
  3. Nov 16, 2022 at 11:01 AM
    Sfish2002
    Sfish2002 Well-Known Member
    Stanley
    2003 2wd M/T regular cab Tacoma
    Topper w/racks, bug/rock shield, hood thermal mat, bed liner, hitch
    I had almost the same exact issue that turned out to be a bad bearing. In my case it was the alternator. After it is done squealing shut it down and put your hand on the alternator, fan, and compressor bearings and see if any of them are particularly warm. It may be an omen of bearings to fail. It was for me.
  4. Nov 17, 2022 at 10:47 AM
    4xdog
    4xdog Well-Known Member
    Santa Fe, NM
    03 DC TRD OR, 15 DC TRD OR, 08 RX350, 62 TR3B
    It's been the AC compressor on a couple of vehicles for me over the years.
    My automotives professor at university, Doc Schraeder, used to say, "When they start talking to you, they're getting ready to break." That's generally been true -- but as you've done the belts, that's probably not your case. Check your tensions, yes, but then start looking for a bad bearing in one of the driven components.
  5. Nov 17, 2022 at 11:24 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Sitting is causing one of those bearing to get tight . Heavy load on the alternator after starting.
    Have any of the belts glazed on the inside compounding the problem a squealing belt is a slipping belt
