bench seat storage / arm rest
Discussion in '2nd Gen. Tacomas (2005-2015)' started by daggertats, Nov 1, 2010.
  1. Nov 1, 2010 at 1:47 PM
    daggertats
    daggertats [OP] Well-Known Member
    arden nc
    2010 tacoma 4x4 reg cab
    undercover tonneau ,bug deflector, removal of all tacoma emblems added a set of component speakers behind the rear seat egr in channel window visors
    one of the few things i hated about my truck was the bench seat and no storage or armrest. i found a box that fit perectly between the seat belts and covered it,unfortunitly it was too tall making it hard to shift and left a gap at the bottom of box where seat was curved. that being said i seen a post on here one day of a homemade one. thanks to whoever made this and gave me the idea to cut the wood to fit perfect against the seat. i made the box taller in back and shorter in front to make it sit a lil more level. it probably coulda been a lil shorter still but it worked out pretty good. the first box i had covered in vinyl which i found a lil tough to work with. i covered this one in a rug type fabric which is alot more forgiving for the less than perfect appolsterer i am. my spelling sucks too btw. anyways heres cpl pics if anyone needs some ideas.
  2. Nov 1, 2010 at 1:50 PM
    matt86
    matt86 Well-Known Member
    NC
    2008 Tacoma SR5 4x4
    Looks good :thumbsup:
  3. Nov 1, 2010 at 1:56 PM
    BradleyScottETC
    BradleyScottETC Class IV Category 8 Elite VIP Member (Only)
    Bradley
    Lake County, FL
    10 4.0 AC 4x4
    +1 rep that looks awesome man, great job.
  4. Nov 1, 2010 at 2:02 PM
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    I'm building my own armrest very soon, so I was curious...what are the basic dimensions you used for height, width, and depth. Thanks in advance.
  5. Nov 1, 2010 at 2:36 PM
    daggertats
    arden nc
    10 inches wide. that goes from line to line on the middle of the seat and leaves enough room to fasten seatbelts. the bottom is 11 and 1/4 from back of seat to front top is 8 and 3/4 height is 7 inches in back and 6 in front ,that includes a thin piece of foam for padding on the lid. as you seen i didnt make the whole lid open because on the first box i had, (the one i bought) it wouldnt lean open enough and kept shutting on me . you can buy a 12 inch hinge and cut it to size for the lid.
  6. Nov 2, 2010 at 5:16 PM
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    Finished mine today. Just need to add some padding to the top and wrap the rest in fabric.
  7. Nov 3, 2010 at 2:16 AM
    daggertats
    arden nc
    nice... be sure and take a few pics when its installed.
  8. Nov 3, 2010 at 2:19 AM
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    Will do.
  9. Jul 4, 2011 at 7:01 PM
    otter
    otter Well-Known Member
    Rob
    MI
    09 4 cyl Reg Cab
    Old thread but I figured I'd add in what I built today. Thanks to the OP for the idea on how best to go about it. Coated the inside with Plasti Dip so it'll be easy to clean. Later this week I'll take it to get upholstered (or buy the materials and do it myself if it ends up costing too much). Will post finished pics when done, but here's how it is so far. The top isn't actually attached yet, better to do that after the fabric work is done. The top is level and it's taller because I'm a pretty tall guy, my elbow sits higher.
  10. Jul 4, 2011 at 7:22 PM
    113tac
    113tac Well-Known Member
    Stephen
    Northern Virginia
    2017 Magnetic Gray Tacoma
    Mostly Stock for now, 265 75 16 Falken AT3W, Tinted fronts...
    really good idea, looks good guys. subbed for later
  11. Jul 4, 2011 at 7:33 PM
    drtydru
    drtydru Well-Known Member
    Dru
    Oakland
    08 4x4
    Bucket seats, Variable speed wiper switch, 09 led Tail Lights, Satoshied front grill, DDM HIDs, Fog light install, Mud flaps removed, 1.5'AAL, Billie 1552, Toyotec front coilovers w/Billies, B.A.M.F welded sliders w/kickout,
    These all look great. I am wonderng if you guys are attaching these in any way or doe these simply sit on the bench?
  12. Jul 4, 2011 at 8:17 PM
    ouyin2000
    ouyin2000 Well-Known Member
    Nova Scotia
    '11 DCSB TRD Sport
    Leer 100XL Canopy, OEM Side steps, TRD Oil Cap, TRD License Plate Cover, WeatherTech Digital Fit Liners, Elite O/R Hitch Shackle, Katzkin Leather Interior, LED Interior Lighting, Foglight Anytime mod, Illuminated 4x4 switch, Grom Audio Aux adapter, Redline Goods leather shift boot console cover and door handle pulls, Sockmonkey bedside decals, Dynolock electric tailgate lock
    Plasti Derp FTW!
  13. Jul 4, 2011 at 9:05 PM
    otter
    Rob
    MI
    09 4 cyl Reg Cab
    Just sits. On mine, if you look at the pic of it sitting on the work bench, you'll see there's extra wood sticking out of the back. That part is meant to wedge between the seat and seat back. With fabric/carpet covering it I really doubt it'll budge unless I want it to.
  14. Jul 5, 2011 at 2:22 AM
    daggertats
    arden nc
    mine just sits on the seat as well.it barely moves unless i lean over it to roll passenger window down etc. the second i attached it id probably have to get somethin from behind my seat . thats the main reason i left mine just sitting there.
  15. Jul 10, 2011 at 1:56 PM
    otter
    Rob
    MI
    09 4 cyl Reg Cab
    Here are the completed pictures. Fabric is some Tundra material I found online, which I had a hunch would be a close match to ours, and thankfully I was correct. The color is nearly spot on; main difference is that the Tundra fabric has a slightly different pattern and is softer to the touch (good thing). Affixed fabric using a mix of spray adhesive and a staple gun. Padding is a piece of 3" "nu-foam", which is a foam alternative that is supposed to stand up much better over time and felt a bit more dense than regular foam (more comfortable for my elbow). Also used some thin pink insulation foam around the box to soften the feel a bit and round out the edges.
    I also had no clue on how fabric is measured so I have a TON of extra :rofl: Bought 2 yards, as I wanted extra if I screwed up, but I didn't realize that the bolts were over 6' long. I have about 1.75 yards leftover.
  16. Jul 10, 2011 at 5:02 PM
    justinhw
    justinhw Well-Known Member
    Turlock, CA
    06 Regular Cab 4x4 2TR-FE
    Wow that looks amazing, great job!
  17. Jul 11, 2011 at 2:07 AM
    daggertats
    arden nc
    nice job...looks real good
  18. Jul 11, 2011 at 2:30 AM
    babytruck
    babytruck Babytruck, babytruck...I've got a babytruck :)
    NorCal
    2010 Barcelona AC 4x4 4.0 6spd
    Looks great and matches real well! One question though. With the padding on the lid does it hinder the ability to open it? Does the box move forward when you lift the lid?
  19. Jul 11, 2011 at 3:22 AM
    2TRunner
    2TRunner Snoop Dad
    My House Usually
    I just used a cardboard box, stuffed it with air pack and covered with 2 hand towels and gorilla tape. Just an armrest. It's strapped down with the middle seat buckle. I've got one of those little padding things that supposed to go on a seat belt taped to the top of the box for "arm padding."
    Works perfect.
  20. Jul 11, 2011 at 6:15 AM
    otter
    Rob
    MI
    09 4 cyl Reg Cab
    I can open the lid about 4" without having to disturb the placement of the console which is enough to see inside and get your hand in there. Both the bench and the armrest padding have some give in them. Not a big deal if I need to open it more, either, since the console is merely wedged into the seat and not permanently mounted in any way.
