Bench Seat
Discussion in '1st Gen. Tacomas (1995-2004)' started by 1GenTaco, Jul 7, 2017.
  1. Jul 7, 2017 at 7:13 PM
    1GenTaco
    1GenTaco [OP] Member
    Ezequiel
    01 Toyota Tacoma SST
    Trying to go to a pull-a-part to get buckets seats for my truck . But they don't have tacomas so is there any other Toyota vechicle that I can swap with ? Or do you have any ideas what I could do ?
  2. Jul 7, 2017 at 8:39 PM
    toyota700
    toyota700 Well-Known Member
    Dan
    cos, co
    01 3RZ Reg
    3rd Gen (1996-2002) 4Runner seats will be very close to a factory fit (i.e. 3 out 4 bolt holes per seat). 1st gen Tacoma seats will be the only thing ones that line up perfect, but anything is possible with a torch, BFH, cutoff wheel, welder, and a grinder.
    Makes it even harder that they changed the colors between '00 and '01. Good luck.
  3. Jul 7, 2017 at 9:38 PM
    Mark D.
    Mark D. Well-Known Member
    '96 base 4 cylinder Tacoma standard bed
    Added ARE fiberglass raised cap & Sony CD head-unit w' aux-input
    Do the standard-cab early ('96) Tacomas, with bench seats, have the extra mounting points for bucket-seats?
    Happy Motoring, Mark
  4. Jul 7, 2017 at 10:54 PM
    Mark D.
    Found a good write-up on Tacoma seats in the DIY thread at the 'sticky' section here.
  5. Jul 8, 2017 at 6:42 AM
    toyota700
    Dan
    cos, co
    01 3RZ Reg
    can't speak for early first gens, but my '01 reg cab w/ bench had the forward, inside mounting points in place (drilled with a welded nut). Inside, rear mounting points were stamped for reference but had to be drilled.
  6. Jul 8, 2017 at 11:20 AM
    kg4tri
    kg4tri New Member
    James
    I am in same boat need bucket seats for 98 Toyota Tacoma has slit bench with the bucket seat hardware just need cushions and seat back Toyota or after market will work
