Bench to 60/40 Swap...seat belt receivers do not match the latch...what to swap next?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Chango feo, May 13, 2015.
  1. May 13, 2015 at 10:16 AM
    Chango feo
    Chango feo [OP] Member
    Boring, Oregon
    2001-2.7L- Standard Transmission-Regular Cab
    Hello all
    I recently did a seat swap from a '01 bench to a set of '98, 60/40 seats. As I found out after installing the seats, the male end on the seat belt does not work with the 98 receivers that are bolted into the bucket style 60/40.
    My option now is to switch the seat belt/ seat belt assembly to a 98 by getting into the inner of the cab wall where I am unsure about the compatibility between '98 and '01 bolt up scheme. Or swap the receiver end on the seats themselves to an '01. There seems to be a "star" like screw with a nub in the middle which attaches the receivers just to make things a little difficult for a simple receiver swap. I am not sure the which would be less trouble, or the easier way to go. I also heard it is possible to shave down the buckle itself...
    Any ideas or advice would be much appreciated.
  2. May 13, 2015 at 12:46 PM
    outdoorames
    outdoorames Member
    NorCal
    Toytech Ultimate Lift (set at 3"), OME Dakar leafs, 265/75/16 DuraTracks, Deck Plate Mod, UltraGauge, Kenwood head unit
