Benchtop....
Discussion in 'Garage / Workshop' started by Pster, Apr 13, 2009.
  1. Apr 13, 2009 at 12:29 PM
    Pster
    Pster [OP] Well-Known Member
    Charlotte, NC
    2006 Tacoma 4x4
    Bak Flip bed cover, shorty antenna, Peripheral iPod interface, Garmin 750 mount, add'l bed tie down rings, Westin nerf bars, hitch safe, tailgate lock, Ideal 1 3/4" turn-key clamp to secure tailgate from removal, Spare tire security cable, spare tire stainless air hose extender, Fumoto oil drain valve, Amp Research Bed X-Tender w/Schlage Cable Lock, bed mat, Redline hood struts
    I have a workbench that is 8 ft long and 36 inches deep. It is very heavy 1.5" or 2" MDF, so dimensionally very stable. But...I want to put a sheet of steel on the top to have a heavy duty work surface. Possibly stainless. Has anyone done this? If so, how did you attach it (bolts, industrial adhesive, etc.) and most importantly, where did you get it and how much? I am thinking I am going to have to find a metal supply and fabrication shop to do this for me (two of the four corners are rounded).
  2. Apr 13, 2009 at 12:40 PM
    cvillechopper
    cvillechopper Jackass to the masses
    Charlottesville, VA
    '24 DCSB TRD Off-Rd, Premium Package
    Console lock-box, Studly Driver
    You can get sheets of 18ga (16ga if you really want to go nuts) from Lowe's or similar hardware store. Just use a propane torch and mallet to shape it then glue it down. I'm thinking of trying that once I get my new workshop built.
  3. Apr 13, 2009 at 12:48 PM
    Pster
    Charlotte, NC
    2006 Tacoma 4x4
    Cool! Cville....you really think/know that Lowes sells these sheets? I'll check it out....this would be great. I can cut/grind down the corners....
  4. Apr 13, 2009 at 4:17 PM
    cvillechopper
    Charlottesville, VA
    I've picked up 4'x4' sheets from Lowes plenty of times and I'm pretty sure that I've seen larger sheets there. I'll check next time I'm there.
  5. Apr 13, 2009 at 4:20 PM
    TacoNut
    TacoNut IgnoringChrisWatchingEdLi veVicariouslyThroughMJP2
    Adam
    Denver, Co
    16 TRD OR DCSB Quicksand
    Last I bought ( a couple of weeks ago) a 4X8 sheet of 16 Ga. hot rolled was $61
  6. Apr 13, 2009 at 4:30 PM
    Pster
    Charlotte, NC
    2006 Tacoma 4x4
    Cool, thanks guys.......
  7. Apr 13, 2009 at 4:32 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Just curious...Why a metal top??
  8. Apr 13, 2009 at 4:38 PM
    Pster
    Charlotte, NC
    2006 Tacoma 4x4
    I was fixing the brass manifold and backflow preventer for my irrigation system this weekend (brass valve just split....bad forging) and it ripped the shit out of the top of my workbench. I have always thought a steel top, polished and coated, would look good and hold up a lot better. My workbench is entirely metal except for the top. It is a Craftsman with metal pegboard backwall. I mounted an electrical strip on it and recently installed a Utilitech overhead light.......
  9. Apr 13, 2009 at 4:50 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    ::nods:: Makes sense....I wasn't thinking about an in general workbench...Cause metal could mar car parts if you were working on there...but makes sense cause you can throw a mat or something down to protect car parts....but having a metal top to avoid damaging a wood work surface makes sense.
    Thanks!!
  10. Apr 13, 2009 at 4:54 PM
    Pster
    Charlotte, NC
    2006 Tacoma 4x4
    Yep, I have rubber mats to put down when I work on more delicate items. But I want something I can hit with an errant screwdriver or hammer and not be bothered. I do EVERYTHING on my workbench....except wifee (and I wish she would)? :D
  11. Apr 13, 2009 at 4:58 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    That sounds like a failure on your part....lol.:cool:
  12. Apr 14, 2009 at 6:26 AM
    Pster
    Charlotte, NC
    2006 Tacoma 4x4
    You got that right.....I've either lost my touch or her expectations are unreasonable. Perhaps some of both. :p
  13. Apr 14, 2009 at 6:41 AM
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    I worked at a lawnmower shop and they put a stainless top on all their workbenches. That was probably 15 years ago, so my pricing will be pretty bad. Call around to a few different shops and get quotes. Some places really want the work and have taken the dropping steel prices into account.
    You don't want to do two different sheets, so you'll have to order it from a metal distributor. I would have them put two breaks (bends) in the metal to wrap around front edge, then have them shear(cut) the other side. They'll probably debur(smooth the edges) it, but request it anyway. It would take them about 15 minutes to do everything and the results are much better than you with the jigsaw out. Once you get the top delivered you can cut curves out with a jigsaw.
  14. Apr 14, 2009 at 7:08 AM
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
    :eek:
  15. Apr 14, 2009 at 7:32 AM
    longbow
    longbow I see you now..................
    Bill
    Indiana
    05 Tacoma Silver Mica TRD 4 Door
    Toy-tec Coil over lift, Eibach 700 lb springs, Sway bar relocate, Total Chaos UCA's, Moto metal wheels, BFG mudterrians, HID, custom 3 piece grill, Highlift jack w/custom mount, Highlift jack cover, bed matt, de-badged 100%, storage box lock mod, using defrost w/o AC mod, short antenna mod, horn re-locate, Tire Gate flat spare tire mount, engine cover painted, bed light (1) mod, wreck bar carrier, Blue Sea 5026 fuse block, center console outlet, flash light mod, Blue Sea inline fuse, Shrockworks sliders, All-Pro front bumper, Piaa 510 driving lights, Warn shackles front, Kennesaw rear bumper, "Tag Boltz" plate lights, Warn shackles rear, Warn M8000 winch, devil horns, BHLM, weathech liners front and rear.....T.W. sticker of course. Custom Sock bed decal for Michele
    I used a thick sheet of alum., but that was some years ago. To cut down on the shine I took an orbit sander with 80 grit, and did a jewel patteren on it. Held up for many many years, when I started working on guns I build a solid 3" thick 8' long, 30" wide red oak table top. Soaked it in linseed oil for a week. Would take serous hits with no worries.
  16. Apr 14, 2009 at 7:37 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    My last bench, I just used some heavy gauge sheet metal, and some 3M Super 90 adhesive...worked well.
  17. Apr 14, 2009 at 11:05 AM
    Hotdog
    Hotdog
    Wet Okole Underwear
    the thought of having a metal edge exposed on the front of the workbench gives me the shivers just thinking about it. I'd be the guy that slices open my stomach and spills my guts all over my tools. :eek:
  18. Apr 14, 2009 at 1:02 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    LMAO!!!! I used some rubber molding to cover the sides. I had a small lip of rubber going over the sheet metal. Worked for head bumpage, and keeping things from rolling off of the table. One thing to consider, though, is becarfull when working with electronics that have exposed leads on a table with a steel top. I never cut or bumped my body in a bad way, but I did manage to spot weld a metal ruler to my table, and I somehow started a small fire.
  19. Apr 14, 2009 at 1:50 PM
    Pster
    Charlotte, NC
    2006 Tacoma 4x4
    In my case, the steel would be on top of MDF and I would buff edges.....radius corners.....grit polished for a nice swirl and then clearcoated.
  20. Apr 22, 2009 at 5:57 PM
    Pster
    Charlotte, NC
    2006 Tacoma 4x4
    I am now thinking about covering the bench with vinyl garage floor tiles. The benchtop is 24" deep, so 12"x12" tiles would work. Has anyone done this?
