Bend fuel door hinge???
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Korywithak, Nov 25, 2018.
  1. Nov 25, 2018 at 1:09 PM
    Korywithak
    Korywithak [OP] Well-Known Member
    Central Pa
    2024 TRD Sport Premium in Windchill
    So I got gas the other day.... went to close the fuel door and its a MESS. All bent out of alignment and fitment. I didn't understand, but looking closer it looks like the pin in the hinge corroded to the hinge itself and bent it as I opened it!!!
    Of course its not screwed on, so I can't take it off to correct... anyone else have this problem?
    For the record: 16 with 36xxx miles
  2. Nov 25, 2018 at 1:13 PM
    HacksawMark
    HacksawMark Well-Known Member
    Mark
    OREGON
    2018 Silver Tacoma V6 DCSB TRD OffRoad traded for 2019 Ford XLT 3.5L EcoBoost SC
    Do you live in an area that uses salt on the roads in the winter? That would explain the corrosion. I make it a point to clean the inside of the fuel door when washing.
    kgilly and Nunya Bizness like this.
  3. Nov 25, 2018 at 1:17 PM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    take it back before the warranty runs out
    kgilly likes this.
  4. Nov 25, 2018 at 1:19 PM
    HacksawMark
    Mark
    OREGON
    Might be past warranty mileage already. Not sure if corrosion is covered for 36K?
  5. Nov 25, 2018 at 1:31 PM
    Dens71TA
    Dens71TA Well-Known Member
    2014 SR5 ACLB 4x4 2.7L A4
    Common issue on Tacomas. I believe the owner's manual suggests lubricating hinges and latches every 6 months under the maintenance section. I always give the fuel door hinge a shot of Fluid Film a couple times a year on my 2014 Tacoma and it still moves nice and smooth.
  6. Nov 25, 2018 at 1:38 PM
    Whitetail Assassin
    Whitetail Assassin Well-Known Member
    Tedric
    West Virginia
    2024 Underground TRD Off-Road 6 Speed MT
    shakerhood likes this.
  7. Nov 25, 2018 at 2:12 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    You are supposed to lubricate it regularly. Once it started to get harder to open, several weeks ago, you lubricate it. Takes five seconds. I use a dry lock lube but anything is better than nothing. I will use some white lithium grease before it gets too cold.
  8. Nov 25, 2018 at 2:15 PM
    BillsSR5
    bill
    2014 SR5
    I used Silicone spray on mine
    hiPSI likes this.
  9. Nov 25, 2018 at 2:59 PM
    Raeburn
    Raeburn Well-Known Member
    2017 ORDCSB
    Mine needed a lube spray after about a year, started getting stiff to open. Definitely want to lube it before it gets too bad
  10. Nov 25, 2018 at 3:00 PM
    DeltaBravo
    DeltaBravo Do you know what nemesis means?
    Waste Management's residential dumpster rental allows you to quickly find the right size dumpster for your project, schedule delivery and pay, all in just a few steps.
    The vehicle commonly referred to as "The War Rig" is a 78 foot 18 wheeler based on a Tatra T815
  11. Nov 25, 2018 at 3:21 PM
    Korywithak
    Central Pa
    Sorry, I tried to search but I couldn't find anything.... maybe I am not searching right.
    It look pretty much like the pics in the other thread... I tried to bend it back, but I can't get it back to were it was... GRRR.
    So frustrating. I will definitely lube it from now on...
    I wish I would have know about this "issue"... I never once lubed any other fuel door on any vehicle (all toyotas) I have ever had before. :(
  12. Nov 25, 2018 at 3:24 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    It's not an issue, it's a maintenance item. There are lots of maintenance items on this truck. Read up.
