Bending coil springs
Discussion in 'Suspension' started by showzer, May 19, 2011.
  1. May 19, 2011 at 4:36 PM
    showzer
    showzer [OP] Well-Known Member
    Shea
    San Diego
    '98 reg cab
    fabtech UCA, Fabtech coil spring, Pro Comp es3000 shocks, flow master exhaust, K&N Intake, throttle body spacer, rhino lined, hella 500 lights, prerunner bumper in the making
    why is it doing this? sorry for the pictures being rotated all weird
  2. May 19, 2011 at 4:49 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Lower spring seat broken?
  3. May 19, 2011 at 4:51 PM
    beefcake
    beefcake J-rob
    J-Rob
    Central California
    98 4WD V6
    Debadged,Deck Plate mod, Helix throttle body spacer, magnaflow two chamber, smoked corner marker lamps, cb radio, smoked headlights, grillcraft mesh grill, URD short throw shifter, ultagauge, billstein 5100 front struts, spidertrax 1.25 spacers on all four
    thats odd... looks like the coil is too long for the shock :notsure:
  4. May 19, 2011 at 4:52 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    What coil / shocks are they ?
  5. May 19, 2011 at 5:03 PM
    beefcake
    beefcake J-rob
    J-Rob
    Central California
    98 4WD V6
    considering it says fabtech right on it, im going with fabtech
  6. May 19, 2011 at 5:12 PM
    OZ-T
    Peter North
    British Columbia
    I'm on my phone , my screen is 2" x 3" and I only see Fabtech on the UCA .
  7. May 19, 2011 at 5:16 PM
    StatutoryAPE
    StatutoryAPE Well-Known Member
    Joey
    Phoenix,AZ
    2000 Prerunner xtracab
    TRD Headers,CAI, dynomax super turbo, blacked out headlights, Smoked LED tails, Billy 5100 w/OME 881's and 5125's in rear, rear tube bumper, tint 35% front 3 windows & 5% in rear 3. fiberwerx 4.5's
    it looks like the spring is too long for that setup. that looks really bad!
  8. May 19, 2011 at 5:19 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Could be this also...
  9. May 19, 2011 at 7:35 PM
    Anthony250
    Anthony250 Ex Fabricator
    Anthony
    Rialto CA
    99 Tacoma LT Prerunner
    LSK Race Kit, King Shocks, Methods, Glassworks, Baja Designs, Built by myself.
    Or they could be cranked up all the way. they supposudly give like 3.5 inches of lift. How is the ride with them anyways?
  10. May 19, 2011 at 9:00 PM
    showzer
    Shea
    San Diego
    '98 reg cab
    they are fabtech coils and pro comp shocks. The ride is pretty stiff, im thinking that it could be that the geometry of my suspension is off, Im thinking maybe spindles would help?
  11. May 19, 2011 at 9:03 PM
    Anthony250
    Anthony
    Rialto CA
    are those extended pro comps? Becuase those fabtech coils are more extended to go with the shocks to give 3.5 inches of lift.
  12. May 19, 2011 at 9:18 PM
    showzer
    Shea
    San Diego
    '98 reg cab
    im not sure :| i brought my truck to 4 wheel parts and they set me up with the shocks
  13. May 19, 2011 at 9:30 PM
    Anthony250
    Anthony
    Rialto CA
    oh , well at least to me it looks like the shocks are too short for the coils and thus the coils are bending out .
  14. May 19, 2011 at 9:40 PM
    showzer
    Shea
    San Diego
    '98 reg cab
    yeah it could be. it was doing this before i changed out the shocks though...
  15. May 19, 2011 at 9:55 PM
    Anthony250
    Anthony
    Rialto CA
    maybe wrong shock size before too, or coils
  16. May 19, 2011 at 9:55 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Can you take a closer pic of the lower spring seat?
  17. May 19, 2011 at 10:01 PM
    Tacomanator
    Tacomanator Well-Known Member
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
    There's your problem...
  18. May 19, 2011 at 10:02 PM
    showzer
    Shea
    San Diego
    '98 reg cab
    HAHA!
  19. May 19, 2011 at 10:03 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    There are more pics in his gallery.
    I'm not familiar enough with 5 lug front suspensions, are they a coil over setup like the 6 lugs. I cant see a spring perch on those shocks.
  20. May 19, 2011 at 10:05 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Edit:
    The springs are separate from the shock....
