Bending inside fender well to remove UCA bolts
Discussion in 'Suspension' started by rshackelford, Apr 24, 2023.
  1. Apr 24, 2023 at 1:42 PM
    rshackelford
    rshackelford [OP] Member
    Colorado Springs
    '23 DCSB OR
    Anyone who didnt cut the bolts and instead bent the inside of the fenders to remove their bolts, did you do any cleanup on them? Bend them back, grind/sand, paint, etc? Necessary at all? Any post-actions you did to them?
  2. Apr 24, 2023 at 1:58 PM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    2021 Tacoma TRD Off-Road 4x4
    I put tape over the fender areas and taped my pliers before bending and then bent them back after. No visible damage or chips, just a little bit of waviness in the panel and small indents from the jaws. The fender liner hides the section afterwards anyways though.
  3. Apr 24, 2023 at 1:59 PM
    TacoTuesday1
    FL
    I did not but you can. I might've wrapped them in a towel to bend.
    Thin sheet metal weak enough to bend in the first place, and known to tear from the weight of a battery or two
