Bending Shifter
Discussion in '1st Gen. Tacomas (1995-2004)' started by Toynbyu, Nov 2, 2008.
  1. Nov 2, 2008 at 3:16 PM
    Toynbyu
    Toynbyu [OP] Active Member
    I want to put a slight bend in my main gear shifter. I have taken out the shifter boot assembly, and now I can see that the shifter lever seems to be "pushed" into rod of sorts that goes into the gearbox. Now, the top part of the shifter seems to move in the rod that goes into the gearbox but won't unscrew. I don't want to force anything nor do I want to heat it up to make a slight bend while still attached. If your wondering why I want to do this it's because I've installed a twin shifter for the transfer case and 4th and reverse are hitting. I only need to bend the main shifter about 1.5"
    Any Ideas?? I would appreciate any help.
    Thanks.
  2. Nov 4, 2008 at 4:10 PM
    Monkeysuncle
    Monkeysuncle My Cat's breath Smells like Cat Food
    Kevin
    Florida
    99 Tacoma SR5 4x4 5 speed Manual Hubs
    Diff Breather,CB thingy,GPS,Cop Shocks,Cop Breaks, old Man Emu 881's Dakar Leaf Springs and Nitro sport shocks. Deck Plate mod
  3. Nov 4, 2008 at 4:13 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    yep......a little heat(maybe a small torch), then place a block of wood behind said shifter, then bend a bit.....let it cool off then put everything flammable back on(shift boot, shifter knob).
  4. Nov 4, 2008 at 4:15 PM
    06Bluez
    06Bluez Well-Known Member
    Phoenix, Arizona
    06 4x4
    Icon Coil-overs, TC UCA, with Bilstein 5150 and Icon 3 leaf pack. 17" Moto Metal 951 4.5" Backspacing wrapped in 285/70/17 BFG AT's. Demello front bumper and Avid offroad sliders.
    No heat ^^^
  5. Nov 4, 2008 at 4:17 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    hell....heat is gonna be about the only way to do it, cause if you just try bending it.....it could bend too far and break.......with a little heat, you can put a little bit of a crook in there the way you want it.
  6. Nov 4, 2008 at 4:17 PM
    -TRDMAN-
    -TRDMAN- ΜΟΛΩΝ ΛΑΒΕ
    Greg
    Clarion Pa
    F-150
    You almost have to use heat!!! they will break trust me!!! been there!!
  7. Nov 4, 2008 at 5:33 PM
    350TacoZilla
    350TacoZilla Well-Known Member
    Hancock MD
    1997 3RZ 5spd 4x4 Reg Cab
    2.7L 3RZ,K&N filter, 4" deck plate mod,flowmaster 40 series,3" suspension lift, hybrid 52"chevy/toyota rear springs.
    yeah but the shifters in first gens should just un bolt from top of trans with 4 bolts.... take the whole shifter setup to work bench secure in vise... use piece of 3' long pipe and give slow increasing pulls on it in direction you want to go... adding little heat does help hate to say but can be done without
  8. Nov 4, 2008 at 6:09 PM
    Toynbyu
    Thanks All.
    Get this: Brought it to the shop and the old man put the took off the shifter knob, moved the seat back braced himself with his big old foot on the lever then pushed until it was where I wanted it. Put the knob back and I was on my way! less than three minutes. You never know.
    Thanks again.
  9. Nov 4, 2008 at 6:28 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    cool deal!!!
