Benefits of a 17in wheel vs 16in
Discussion in '2nd Gen. Tacomas (2005-2015)' started by OldManTacoFeels, Dec 21, 2020.
  1. Dec 22, 2020 at 1:42 PM
    #61
    PinktacoDM84
    PinktacoDM84 Well-Known Member
    Dan
    BC
    2015 trd OR/AC
    St Maxx on Trd pro wheels, mbrp exhaust, k&n cai, jba's, 887's over 5100's, medium dakars and 5125's.
    Would help make for the easiest suspension swap ever.
  2. Dec 22, 2020 at 1:50 PM
    #62
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    The wisdom of calling tires “wheels?” No thanks I’m good.
    The OP asked about 17” wheels. As in the metal part inside the tires. Nobody runs 17” tires on a Tacoma and larger metal wheels don’t “step over” obstacles better, larger diameter rubber tires step over obstacles better regardless of the size of the wheels inside.
  3. Dec 22, 2020 at 1:51 PM
    #63
    Alexely999
    Alexely999 Well-Known Member
    Alex
    Bay Area, CA
    2015 DCSB 4X4
  4. Dec 22, 2020 at 1:54 PM
    #64
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    1000s of Tacoma Sports have 17" wheels. I doubt if they have all replace them for a smaller set.
    rim + tire = wheel.
    You can't run a tire without a rim. You can't run a rim without a tire. Both are needed to make a wheel.
    In this discussion wheel has been equated to have the same meaning as rim.
    stonybrook likes this.
  5. Dec 22, 2020 at 1:57 PM
    #65
    Sharpish
    Brian
    Yes. And a factory off road and a factory sport have the same overall diameter tires and roll over obstacles exactly the same even though one has 16” wheels and the other 17” wheels.
  6. Dec 22, 2020 at 2:01 PM
    #66
    Knute
    Disagree.
    The wheels are the same diameter. The rims are different diameter.
    So, Yes, the two will "step" over obstacles with similar efficiency.
  7. Dec 22, 2020 at 2:14 PM
    #67
    hoffengineering
    hoffengineering Well-Known Member
    Taylor
    Orange County, California
    2015 DCLB 4X4
    Not technically correct, see my previous post.
  8. Dec 22, 2020 at 2:25 PM
    #68
    Knute
    Well. Y'all call 'em what you want.
    I know a wheel without a tire will not handle well.
    I know a tire without a wheel will be difficult to mount on a vehicle.
    What do your call a wheel with a tire? Wheel?
    Over the years.....wheel has been muddled to mean rim. The difference is usually inferred from context.
    Good luck all of you running on bare (minus tire) wheels.
    I know in the engineering world when a wheel is discussed, it is known to be a rim + tire. Rim is a separate part of the wheel. Tire is a separate part of the wheel.
    Merry Christmas to all. Or Happy Holidays to others.
    Mark77 and Alexely999 like this.
  9. Dec 22, 2020 at 2:30 PM
    #69
    Alexely999
    Alex
    Bay Area, CA
    2015 DCSB 4X4
    This thread is 3 days early
  10. Dec 22, 2020 at 2:39 PM
    #70
    stickyTaco
    stickyTaco Fuck Cancer
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Fox/Dakar with Relentless goodies and stuff
    Pretty sure these are referred to as rimz
    Do you rotate you tires or wheels? Also, you should write a letter to tire rack because they refer to that metal piece in the middle as a wheel and the rubber part as a tire (along with most anyone that understands the difference between a rim and wheel).
  11. Dec 22, 2020 at 2:44 PM
    #71
    Knute
    I rotate my wheels as an assembly which moves both the rim and tire to a different location. If I were to "rotate the tires", then I would need to remove the tire from the rim and install it on a different rim.
    Common nomenclature is to "rotate the tires".
    There are many examples of common terms that are not correct. Example: "Make a xerox of this page." actually means to make a copy. It would be silly to refuse to make it on a Savin copier.....its not a xerox. Although, Xerox has been incorporated into the Merrium dictionary.
  12. Dec 22, 2020 at 2:49 PM
    #72
    terminus
    terminus Well-Known Member
    2023 Silver TRD Offroad MT
    So many people arguing about "wheels" vs "rims," when convenient screenshots indicating that "wheels are the metal part" have already been posted. More importantly, "rims" sounds stupid.
    Also I will die on this hill.
  13. Dec 22, 2020 at 2:49 PM
    #73
    Fullboogie
    Fullboogie Well-Known Member
    Dave
    Houston
    2007 Prerunner & 2008 4Runner
    Nobody refers to a rim/tire package as a wheel. Nobody. And everybody knows that rim and wheel mean the same thing. LMAO, now we're getting a lecture on the proper use of the word "Xerox." Ignored.
  14. Dec 22, 2020 at 3:16 PM
    #74
    stickyTaco
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    @Knute, once you're done correcting Tire Rack, please send a letter to Toyota because the brochure incorrectly lists wheels when they should say rims.....
  15. Dec 22, 2020 at 4:35 PM
    #75
    stickyTaco
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    :deadhorse:
    Nope, rim has been muddled to mean wheel. Even in the days to the Oregon trail and covered wagons a wheel was a wheel and a rim was part of the wheel attached by spokes to the hub.
    Just because something is used incorrectly in the engineering world doesn't make it correct.
    Take a moment and read the link below so you can use the term correctly and win internet fights...or keep coming back claiming that everyone else is wrong and I'll dig up another company that uses wheel incorrectly for you to send a letter to.
    https://tiredealersites.com/rims-vs-wheels-what-is-the-difference/
    And back on topic, 17" wheels have more sizes available in lighter load ranges and will clear BBK. 16" wheels will give you a 1/2" more sidewall between the lip and ground when running the same height tire (265/70/17 vs 265/75/16 for example) and, when running the same tires on a 16" wheel and 17" wheel, the 16" setup it will be lighter.
  16. Dec 22, 2020 at 5:52 PM
    #76
    hoffengineering
    Taylor
    2015 DCLB 4X4
    Agreed.
    Honestly, I'm in the "engineering world"... And it's not used the way he's using it. I'm not sure what he's talking about--maybe in some circles, but in general I'd say he's incorrect, both in the "engineering world" and elsewhere. We use "rim", "wheel", and "tire" how I described earlier.
    And this is the internet, beating dead horses is probably what we do best. :rofl:
  17. Dec 22, 2020 at 6:07 PM
    #77
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    It's known to be one of the first mods to do to motorcycles. More feel, less sponginess right off the bat. Large Co's. like Toyo. are not going to put 100 dollar brake lines on mass produced vehicles, although I do find them to be better than domestics. Used to anyway. I haven't seen one pop in a while.
  18. Dec 22, 2020 at 6:12 PM
    #78
    RyanJay11
    RyanJay11 Well-Known Member
    Missouri
    09 TRD 4x4
    I clicked on this thread, read a few posts and immediately regret the decision.
    Holy shit batman.
    Sand Dog, Hyperbarics, Marc70 and 6 others like this.
  19. Dec 22, 2020 at 6:13 PM
    #79
    Mark77
    Mark77 Well-Known Member
    Mark
    2021 White TRD Off-road
    Nothing yet
    For offroading purposes, I want a smaller wheel and as much rubber as possible.
  20. Dec 22, 2020 at 6:21 PM
    #80
    Chunk
    Chunk I smell Ice Cream!
    2016 DCSB OR
    Baby Ruth
    I said it once I’ll say it again!
    WIMs and RHEELs! Y’all know what each other mean! It’s petty to argue!
    Neither side is going to be educated! No matter how valid any point is going to be!
    Hug it out!
    But, then again... it’s tradition and ya don’t fuck with tradition!
    Hyperbarics and ohcaltexscar like this.
