Benefits of removing sway bar?
Discussion in 'Suspension' started by jr114, Jan 16, 2010.
  1. Jan 16, 2010 at 12:23 PM
    jr114
    jr114 [OP] Well-Known Member
    Jon
    SoCal
    Truck
    Icon Ext travel CO, Icon tubular uniball UCAs, Maxtrac Spindles, Icon RR rear w 2"aal.
    been reading that alot of ppl on here are removing their sway bars. kinda thinking bout taking mine off now. what are the benefits? might as well take it off now cause once the spindles go off itll come off than anywany..i think
  2. Jan 16, 2010 at 12:30 PM
    Holling
    Holling Well-Known Member
    West Coast
    2021 DC TRD Sport
    You roll your truck and your insurance may deny your claim. I do NOT know this as a fact but I wouldn't do it. I'm going to lump sway bars with airbags, seat belts and ABS. All put there for safety reasons.
  3. Jan 16, 2010 at 12:33 PM
    Anathollo
    Anathollo www.saveadane.org
    Houston
    07 Tacoma TRD Sport
    Icon coilovers, Rear Fox Resi-shocks, 285/70/17 Toyo A/T's, Touchscreen JVC Headunit, Custom Rhino-lined sub box, Rocksford Fosgate components and Dual Rockford Fosgate 10" shallow subs, Pioneer and Rocksford Fosgate amps, 1250 watts total, Autometer Volt and Trans gauges with Lotek A-pillar, K&N Drop-in filter, WO Seat covers, Tint, NST WP pulley, Hi-lift jack, Diff breather mod, horn relocation mod, extra "D" rings, de-pinstriped, carrier bearing drop, Rear backup 886 bulbs, Camburg UCA's, AMW Catch can, BHLM, OME Dakars with AAL, Procomp 7089's, Front single hoop Demello bumper, Superwinch Tiger Shark 9500, Amsteel 3/8th synthetic line
    Benefit: more upward travel for your front tires.
    But once you remove it, your truck will not be as stable in turns and will sway more at high speeds. Also if you tow a lot then it's best to leave it on.
  4. Jan 16, 2010 at 12:42 PM
    TA06CO
    TA06CO TA06CO
    Arvada, Colorado
    06 TRD O/R, 3in. Pro Comp Lift
    Brush Guard, 3 Stage Tonneau Cover, Side Steps, Silverstar Ultras, 3in. Pro Comp Lift w/ AAL, ES3000 & ES9000 Pro Comp Shocks, 285/75/R16s Yoko GEOs, Differential Drop, Carrier Bearing Drop...
    Or...make a "quick connect" sway bar. You might need some access to a welder. Though I have never done it I have seen it done before. My advice, keep it on.
  5. Jan 16, 2010 at 12:48 PM
    lilgerber
    lilgerber Well-Known Member
    Aaron
    Fresno, CA
    06 4x4 off road Speedway blue
    Front: Total Chaos 3.5 4x4 LT kit, Engage off-road one piece hood, Caged front end, TC gussets. Rear: Fiberworks fenders, King 14" 3.0 triple bypasses, boxed/braced frame, extended brake lines, 63" chevy leaf springs, U bolt flip kit, TC lower shock mounts. Preformance: URD intake, Doug Thorley headers, Flowmaster 40, 2.5 tubing. Interior: Weather techs, LED's, Double DIn, kicker 10" subs, Kicker componet speakers, Exterior: Method wheels with OMF beadlocks, Custom made bumpers, Retro headlights.
    i dont have mine on, and i dont notice a body roll or turns etc, only when a big rig flys by i fell it move a little bit, and i drive more city so works perfect for me. try it off its only 6 bolts, very easy.
  6. Jan 16, 2010 at 2:39 PM
    jr114
    Jon
    SoCal
    Truck
    think ill try it drive it around a little and see how it reacts and handles. thanks for all input
    PvilleJohn likes this.
  7. Jan 16, 2010 at 9:35 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
  8. Jan 16, 2010 at 9:37 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    take it off, your gonna "have" to anyway with the spindles :p not really but seriously take it off
  9. Jan 16, 2010 at 9:46 PM
    08pretaco
    az
    ^ or having fun and going fast around corners if you want haha
  10. Jan 16, 2010 at 10:14 PM
    Janster
    Jandy
    Lancaster, PA
    It's not the on-road manners I'm referring to.
    In a panic situation where you gotta steer around something quickly..... that swaybar could keep the wheels on the ground. Without it - you could flip over and kill you & your family and whoever else is in the area surrounding you.
  11. Jan 16, 2010 at 10:17 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    this
    tho i dont have a sway bar on my truck...i have a lot of other shit to make up for it...on top of my truck not being a daily driver
    the combination of the steel weight ive added to my truck, along with my 675lb coilsprings and some other crap...i dont notice the increased body roll during a panic maneuver...
  12. Jan 16, 2010 at 10:34 PM
    jr114
    Jon
    SoCal
    Truck
    well was planning on doing trying it this week but just got ordered in for another 48 day off then another 48. so there goes that idea.
  13. Jan 16, 2010 at 10:34 PM
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    What Janster posted applies to the majority of our trucks. The sway bar serves to help stabilize the truck especially during highway speed emergency steering maneuvers. Side note (The 5th gen 4Runner has factory installed electronic sway-bar disconnects)
    Removing the sway bar makes sense only if the truck is to be wheeled a majority of the time. For the rest of us who use our trucks on the highway and wheel occasionally, then investing in a pair of disconnects is the optimum solution.
    For me personally I want maximum articulation in my truck's IFS but I'm not willing to create the possibility of an unsafe situation by removing the sway bar to achieve that goal.
    I imagine if someone took out their sway bar and was late to work and drove fast, they'd look like a clown driving around with their truck rolling around the turns in the streets :laugh:
    I'll either find quality disconnects for the 2nd gen taco, or build some.
  14. Jan 16, 2010 at 10:43 PM
    Dellosa89
    Dellosa89 Love peace and Taco Grease
    Brian
    Murrieta CA
    07 Prerunner TRD Off Road
    Fox 2.5 Coilovers, Camburg 1.25" UCA's, Icon RR, Icon aal,EVS foam bump stops, Borla Catback, HID Headlights and fogs, Defiant light bar, 3 hella 700 hid, Satellite Radio, Sony hu with 10'' sub, custom jetski rack, TRD seat covers, secondary air filter removed.
    Well if you dont offroad that much or that hard leave it in. But for me i push my truck a little harder than most. After i took my sway bar off and took my truck through midium size whoops, i was thoroughly convinced to never put mine back on. Because on any natural turain the trail is very uneaven and since i took my sway bar out my truck stays much more stable at high speeds in the desert. Even though i will admit my truck leans a little bit on paved roads i could care less.
  15. Jan 17, 2010 at 7:37 AM
    08pretaco
    az
    I will tell you this jon, make sure your comfortable without the sway bar to help decide if you want to order the spindles without the attachment possibilty for the sway bar. When I backed my truck out after installing them and drove it around the broke :eek: I was scared that I made a mistake not being able to use my sway bar. The more I drive with the setup now the less I notice or feel the lean because either I have adjusted my driving habits or I'm just used to it. Eitherway I am happy with the decision to take and keep it off. If your going to be runinng spindles I am guessing your gonna want to use your truck and enjoy the mid travel, so take and leave the damn thing off and be done with it!
    Also to add, my sway bar bolts that held it to the fram are currently in use for my driveshaft carrier drop brackets haha
  16. Dec 11, 2013 at 5:43 PM
    Djande91
    Djande91 Well-Known Member
    Dallas
    Arizona
    2010 Silver 2wd Tacoma
    2x10" rockford subs 17x9" XD addict rims 265/70/r17 BFG's King shocks Mid travel
    I have been thinking about doing this too but where the sway bar connects to my spindles it appears that there is no way to take them off the spindle. Any answers?
  17. Dec 27, 2013 at 7:29 PM
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    I'm going to guess that you have a Pro Comp 6" kit with Pro Comp spindles otherwise the sway bar simply bolts throughout the OE spindle. With the heavy duty Pro Comp spindle the sway bar link screws straight into the spindle itself. To remove it simply remove the small bracket for the brake line on the back of the spindle and that will expose a hole that lines up with the sway bar link. The end of the link inside the spindle is hollow and it is a 5mm or 6mm Allen wrench to loosen it. It can be really hard to take off because it either has red thread lock on it or a decent amount of rust. To loosen the thread lock use a torch to heat the spindle where the bolt is just enough to loosen the bolt. If rust is your prob soak it through that hole in the back of the spindle with a penetrant lube and let it soak in maybe even spray it multiple times for a couple days before you try. Last but not least if the Allen head does not work vise grips of the link at the front of the sway bar are you last hope.
