Bent Body Mounts?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Justing86, Jun 13, 2016.
  1. Jun 13, 2016 at 2:10 PM
    Justing86
    Justing86 [OP] New Member
    2016 Tacoma TRD
    Hi guys, I'm new to the site but have really enjoyed all of the useful information so far.
    I took my 2016 Tacoma in to the dealership for a vibration/clicking noise today. They just called me back after 6 hours and said that my body mounts are bent. I only have 3,800 miles on the truck. I've never heard of this problem but the technician said this is the second 2016 Tacoma they have seen with the same problem. I would think this is a factory defect. Could this cause other problems down the road? They are taking care of fixing the problem but I am just not knowledgeable about bent body mounts.
    Has anyone else had this issue?
    ***1. Update: Bent Body Mount Brackets is the diagnosis, he has to order the parts and the dealership will install them on Friday. I'll try to get the old brackets and post a pic.
  2. Jun 13, 2016 at 2:37 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Bummer...
    What were the symptoms?
    I can't recall any body mount threads, but there are quite a few mystery clunk reports from the front passenger suspension area.
  3. Jun 13, 2016 at 2:40 PM
    Pigpen
    Dan
    Northwest Montana
    @trd1221, @JB700 ????
    Body mounts are rubber so that they flex. They can't be bent. Mechanic is full of shit and wants to empty your wallet. I replaced mine, so I know exactly what they look like and how they work. They might be cheap rubber garbage, but they can't be bent.
  4. Jun 13, 2016 at 2:46 PM
    CanadaToy
    CanadaToy Well-Known Member
    Greg
    Toronto
    17 DCSB TRD OR Alpine
    TRD Pro grille & skid, OEM tonneau and roof racks
    Maybe he meant the sheetmetal where the body mounts is bent. Also, it's under warranty, not sure they are emptying any wallets other than Corporate's...
  5. Jun 13, 2016 at 2:48 PM
    Clearwater Bill
    Billy
    Largo Florida
    Body mounts? Or bed mounts?
    Ask him to show you the old parts. Post pics.
  6. Jun 13, 2016 at 2:52 PM
    Justing86
    2016 Tacoma TRD
    Update: Bent Body Mount Brackets is the diagnosis, he has to order the parts and the dealership will install them on Friday. I'll try to get the old brackets and post a pic. I'm still a little leery of the diagnosis, I thought it could be U Joints after all the threads about those.
  7. Jun 13, 2016 at 2:58 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    ChadsPride, scottalot and George1441 like this.
  8. Jun 13, 2016 at 3:02 PM
    EDDO
    EDDO                         
    Eric
    San Jose, CA
    19 TUNDRA
    Have you considered a buy-back offer from Toyota?
    This is the only remedy you should accept.
    MadDaddy, Pigpen, Lawfarin and 2 others like this.
  9. Jun 13, 2016 at 3:13 PM
    Pittrider
    Pittrider Pitty, those needing correction.
    Greg
    B.C.
    2016 MGM LTD LB
    Do you need to know, or care?
    Where does that statement from Toyota come from and what kind of environmental factors would result in bent body mounts?
    Unchained 5150 likes this.
  10. Jun 13, 2016 at 3:14 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
  11. Jun 13, 2016 at 3:19 PM
    EDDO
    EDDO                         
    Eric
    San Jose, CA
    19 TUNDRA
    That was not a real statement. My post was intended to mock the OP using nonsense posted in this thread.
    ChadsPride likes this.
  12. Jun 13, 2016 at 3:20 PM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    Those are usually welded to the frame. Last thing I would want this then torching the frame and welding new ones on. Maybe the tacomas are different. Either way I would be pretty pissed. Anyone have pictures of their body mount brackets? Perhaps they is part of the reason we are seeing people with cab/bed alignment issues?
    Maybe I'll stick with a full size
  13. Jun 13, 2016 at 3:53 PM
    Hiluxski
    Hiluxski Well-Known Member
    Ventura California
    2022 Lime green TRD Pro
    The cab/ body mounts are welded on the frame the body mount is molded into the sheet-metal of the body. with a body bushing in the middle. I think the terminology or the name that were calling things is obviously different because no way they got bent and no way the dealer would try to change those and you probably can't get them separate.
  14. Jun 13, 2016 at 3:58 PM
    bobrown14
    bobrown14 Well-Known Member
    Bob
    Philadelphia
    Gen 3
    bunch of stuff - Bro Pro style
    Wait, what?? Tacoma forum... your sig says FORD?? WTF?
    First, haven't seen any bed alignment issues that didn't look like someone's bumper wasn't well bumped and tried pass it off as some sort of defect that just showed up one day??
    Body mount brackets... how would they get bent? likely someone dropped the truck down on a lift from 6' full speed drop. It's a 4wd truck, thats going to be a hard sell to me if it was my truck. I'd be asking how in the world that could actually happen and watch the service managers eyes drop to the floor and lie his ass off. Just sayin...
    Just looked at mine... no way the BRACKET gets bent... that would have to be some very serious stress and the welds would break first, pics or it never happened. There's bushings maybe they are cracked not the mounts. Seriously there's some stink to this thread .... someone is bullshitting so I call it!
    EDDO and Hiluxski like this.
  15. Jun 13, 2016 at 4:02 PM
    EDDO
    EDDO                         
    Eric
    San Jose, CA
    19 TUNDRA
    That is a great plan. The incoherent ramblings of someone on the internet really helped you dodge a bullet today.
    Sbpark and Unchained 5150 like this.
  16. Jun 13, 2016 at 4:12 PM
    El Duderino
    El Duderino Obviously, you're not a golfer.
    Jeremy
    HI->PNW
    19 nautical blue SR5 premium 4x4
    Stuff, things, this, an ADS
  17. Jun 13, 2016 at 4:23 PM
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    Ugh ...yet another thread with piles of bad info and people not reading between the lines or terminology of the OP because they are more interested in being instant forum bullies than providing an actual solution.
    OP - not saying this is for sure what it is but it seems that the dealer is probably referring to the body mount bushing not " bracket". They may be calling it that but it is simply a rubber bushing with some washers that is sandwiched between the body and the cab mount on the frame. The body mount bushings are in fact notorious for being worn out or flattened out even on brand new trucks still on the lot. ( BTW - this is the #1 cause of the infamous " taco lean " and crooked bumpers and hoods too. ) The left front core wall body bushing that is right under the battery is the worst and that bushing can be squashed by a full 1/4" = the mount is then very loose. Although I have not heard this about the 2016's yet it is super common on the 2005's and up ( all second gens ).
    The easiest way to diagnose this yourself is to simply grab a tape measure and measure the gap between your body mounts and the cab. There are 6 body mounts - 2 out at the core wall ( radiator core support wall ) 2 right at back of your front wheel wells and 2 right at the very back corner of the cab. So IE: the most common problem is that the right front core wall bushing is around a 1/2" but the drivers side one under the battery has been flattened to just 1/4".
    DaveInDenver, Pigpen and JB700 like this.
  18. Jun 13, 2016 at 4:38 PM
    JB700
    JB700 Huntin, Fishin, Loving everyday
    Jeremy
    Lox Florida
    2016 4Runner Trail
    Wow it did not take you guys long to give someone else crap.
    OP i feel bad for you i delt with two treads of crap, and now they want more people to crap on.
  19. Jun 13, 2016 at 4:45 PM
    splitbolt
    NW Arkansas
    Bottom of the top bushings, there are thin stamped brackets that bolt to the frame.
  20. Jun 13, 2016 at 5:17 PM
    Justing86
    2016 Tacoma TRD
    Wow, newsflash guys I am not a mechanic. The repair is scheduled for this Friday, Toyota had to order the parts. I will update this thread with the old parts if I can get a pic as well as the detailed invoice.
