Bent exhaust valve at 130k miles! Why???
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tanderson20, Jan 22, 2015.
  1. Jan 22, 2015 at 11:51 PM
    Tanderson20
    Tanderson20 [OP] Member
    Tanner
    Washington
    1999 SR5
    My truck is a 1999 Toyota Tacoma 2.7L 4X4 (3RZ-FE) with 135k miles. Problem became clear when I got a cylinder 2 miss fire... So I did a compression test and all cylinders were at 190psi except for cylinder 2 which was at 85psi. So I pulled the head and valves... Upon inspecting the valves I had a bent exhaust valve in that cylinder. I plan on using Plastigage to check the clearance of my camshaft caps, and the timing chain looks to be in great condition. The valve clearances seemed to be off, could that cause a bent valve? I did not see any spots on my pistons where the piston might have contacted the valve. What causes this, and what steps should i take to make sure this does not happen again??
  2. Jan 22, 2015 at 11:57 PM
    Idaholandho
    Idaholandho The other white meat
    3 Now - 2022 Trail Edition, 2015 TRD 4x4 and a 2006 SR5 4x4
    2015 Tacoma, Magnuson Supercharger, Bully Dog Flash and GT, Safari Snorkel, Toytec BOSS 2.5 Coil Over Front, Toytec BOSS Aluma 2.5 Rear, Toytec 10 Leaf Pack, Stainless Brake Lines, Icon UCA's, CBI Reverse Adj Shackle Mounts, CBI Ubolt Flip Kit, Timbren Bump Stops, CBI Bushmaster 2.0 Front Bumper w/ Warn M8000S Winch and SR2 Rigid Flood Lights, CBI Bushmaster 2.0 Rear Swingout Bumper, Rigid SR2 backup lights and Dual RotopaX / Fuel/First Aid Pack, CBI Rock Sliders, CBI Full Skids and CBI Rear Diff Armor, BAMF LCA Skids, FrontRunner Outfitters Slimline II Roof Rack w/ Rigid SR2 40" Combo Light Bar, Rock lights, Rigid pods in Bed Rack, Intelligent Battery System w/ Dual NorthStar batteries, Spod Power Distribution, illuminated switch panel in sunglasses holder, Viar Extreme Duty On-Board Air w/ 2.5 Gallon Tank under bed, Air 2 Air Sys, Magnaflow Exhaust, Fuel Off Road Trophy Wheels, 285/75/17 Toyo Open Country R/T, Diff breather mod, FX-R BHLM Demon Eye headlights, Esuse LED Fog Kit, Pelfreybilt Camera Relocation mount, Pelfreybilt ax/shovel bed mount, Debadged, tint, a 2006 Tacoma SR5 and a 2022 Trail Edition
    Timing chain?
  3. Jan 23, 2015 at 12:00 AM
    Tanderson20
    Tanner
    Washington
    1999 SR5
    Also... The valve stem itself was not bent, just the head of the valve. And only one of the exhaust valves in that cylinder was bent. I dont think the previous owner ever had the valves adjusted. When I brought the engine to TDC and pulled it apart, all timing marks seemed to line up correctly and #1 and #4 piston appear to be fully extended.
  4. Jan 23, 2015 at 12:07 AM
    Tanderson20
    Tanner
    Washington
    1999 SR5
    Im not sure... Should I replace the chain? I have limited skills, all self taught (mostly from reading and youtube/haynes/youtube)
    So far I have ordered new exhaust valves, cleaned the head, lapped all valves (except for those I have ordered)...
  5. Jan 23, 2015 at 12:35 AM
    Idaholandho
    How many miles since it has been done? I suppose more importantly, has the chain ever been replaced? Hope so.
    It is most important that this is done.
  6. Jan 23, 2015 at 12:44 AM
    Tanderson20
    Tanner
    Washington
    1999 SR5
    Not sure, I bought the truck 6k miles ago... It has probably never been done!
  7. Jan 23, 2015 at 1:03 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Usually, the 3RZ-FE doesn't ever require a chain change, it isn't like a 5VZ-FE or a 1GR-FE (which are belt driven) the chain only needs changing if it breaks or gets too slack. People generally change the chain on their way to a deeper part as precautionary maintenance, but it isn't required like on a belt driven engine.
    Generally if the chain is too slacked that means you'll have more than a one valve issue. I would suggest you have your valves properly clearanced (after buying a new valve) as the exhaust valves have a tendency to tighten up as the motor ages which can cause cracks in the head (and may even be the cause of your bent valve). Possibly have the cam checked as well (probably not necessary)
    Also, it may be a good idea to have the timing checked as it is possible it slipped a tooth (if the chain is truly and utterly fucked... very unlikely but easy to check)
    Sounds like you are on your way to getting it figured out. Good luck
  8. Jan 23, 2015 at 4:05 AM
    Moco
    Moco Well-Known Member
    Eric
    NoVA
    96 Regular Cab 4x4 5spd
    Seems unusual for a 2.7L to have a bent valve at 130k. Check the exhaust manifold to see if there is a big ol crack near vicinity of #2.
    Otherwise, since you have the head off, just replace the chain as preventive maintenance.
  9. Jan 23, 2015 at 10:44 AM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    it may be as simple as something fell in the cylinder during a spark plug replacement and that bent the valve before it exited out the exhaust.
    is this a sudden problem that arose or you noticed or were you just trying to get it to run better? how long have you had the truck and was it running any different during that time?
    in other words do you think its possible you bought it with this existing problem already there?
    by the way plastigage is a wax string you mash between bearing journals to check clearances, its not used for valves, for valve clearances you use a regular blade style feeler gage like this: http://www.ebay.com/itm/LASER-2481-...277?pt=LH_DefaultDomain_0&hash=item58b8c3b775
  10. Jan 23, 2015 at 10:52 AM
    hetkind
    hetkind Well-Known Member
    Howard
    Johnson City
    2011 SR5 Access Cab, white with Leer Cap
    bilstein set at 1.75, Racho 5000 rear with 4 leaf kit, floor mats, high lift jack, pull hook in hitch, bed rail corner braces, severe duty brake pads and devil horns on the grill....
    or a sticking valve in the guide, weak valve return spring and my favorite? excessive RPM.
    Howard
