Bent frame/leaf mount on my 2009. Dealer tells me to go to Ford?!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Ends, Mar 26, 2010.
  1. Mar 26, 2010 at 2:05 AM
    Ends
    Ends [OP] Well-Known Member
    Allright guys, i have a serious WTF here. Rant below.
    I got my 2009 4 bannger (sr5 4x4) suck in the yard last week with a full load. While trying to unload on the top of a hill, i hit some slick mud and found myself sliding down to mud up to my wheel wells. To make a long story short, i was STUCK. Had to get her towed out, from the rear.
    I finish my job, unload the truck, and hit the hwy. My rear end/whole truck was vibrating like crazy. Like someone jumping up and down in the bed. Stopped, and looked under the truck.
    I didn't take any pictures, but my rear leaf mount was completely twisted and fu*ked. Not drivable over 80km/h.
    I make my way to the dealer, calling ahead to let them know the issue. The collision guys say no issue, while the mount is on the frame, they can bent it back for me. whatever, just fix my truck.
    I spend 500$, and they re-bend the mount. Get the truck back, and hit the hwy. Same shit, no difference. I get back, get them to do an alignment, and turns out that all 4 are out. the rears are more then 0.20 degrees of an allowance.
    Now what comes next, really pisses me off. The service manager tells me that he really has no idea what to do, or how to fix my problem. I talked to a few of the mech's< where i was told to bring my truck to a ford dealership across town because they deal with more trucks?!?!
    I don't get it. I would think that if i bring my truck to the stealership i bought it from, they would at least know some sort of frame repair they deal with, and take it on my behalf. But no, i got no answers and advice to take my truck elsewhere.
    I have no idea what to do. This is a little more of a rant, but any suggestions out there? I will be calling the head of the dealership tomorrow, along with toyota canada, and some frame shops around town.
    Anyone hear of anything like this? All the mech's seem to be floored with a twisted leaf mount.
    Suggestions, advice, comments, directions?? I need some help guys.
  2. Mar 26, 2010 at 2:17 AM
    Sparky4.0
    Sparky4.0 Well-Known Member
    Aaron
    WestTexas
    01 trd beat to hell
    LMFAO... what do you expect from a 19 yr old that got a job at stealership because he said I can change oil!!!! that sux bro. but ANY welding/machine shop will be of much more help than the stealership. ps. where did you hook up the strap to get extracted ? shackle?
  3. Mar 26, 2010 at 4:52 AM
    Fortech
    Fortech Well-Known Member
    CANADA
    2005 Toyota Tacoma TRD OR
    Bilstein 5100's, rear TSB, Firestone bags
    Since this is something that was the fault of the owner and not a warrantied issue, the dealer is likely sending you off to a facility that can better serve you with more specialized tools. Just because your dealer sold you the vehicle doesn't mean they can fix everything on that vehicle in every situation, especially when it comes to bent frames. As for getting the dealer to take it somewhere on your behalf - why waste your time and theirs? If you use the dealership as a middle man, they are going to want their piece of the pie as well ($$$). Cheaper to deal with the repair facility yourself.
    Exactly what problem do you have here? I really don't see an issue? If the frame is bent and cannot be fixed by your dealer, take it to somebody who can?:confused: It isn't a factory defect so really your dealer has no obligation to correct it if they aren't equipped to do the repair.
    You got pulled out from the rear. Where did you attach the tow strap/rope?
    EDIT: Is there any of that mud you spoke of still inside your rims? That will throw your wheels out of balance and shake your truck like nobody's business.
  4. Mar 26, 2010 at 4:55 AM
    08TRD Sport
    08TRD Sport ROOTIN AROUND
    Joshua
    Augusta, Georgia
    10 5th Gen 4Runner
    I would go somewhere else anyways the stealership is going to rape you even more!!!
  5. Mar 26, 2010 at 6:16 AM
    Breadbox
    Breadbox Well-Known Member
    Northern VA
    TRD Sport, MT, 4X4, SR5
    4" lift; ION and Camburg, custom progressive rear springs no overload; ION Bumps; Roadmaster Active suspension, quick disconnect sways front and rear, Nitro 4.10s, Detroit TrueTrac, ECGS bushing, Aluminess Rear bumper w/swing outs and flood lights, 285/70/17 on ProComp Steelies, Kenwood NAV, URD Short Shifter, CB, front rally bar with LED flows and fogs, RockSliders, FWC.
    I think to recommend possible fixes we need some pix?
    Anyway, I know some custom off-road shops around here would actually weld new mounts for really large lifts. I bet if you do a local search you might find a shop set up to do such a job. If they can't be un-bent maybe weld up new mounts?
    :worthless:
  6. Mar 26, 2010 at 6:40 AM
    wlmuncy
    wlmuncy Well-Known Member
    William
    Knoxville, TN
    2007 Double Cab Manual 4*4
    So the dealership gave you the best advice they have "The service manager tells me that he really has no idea what to do, or how to fix my problem. I talked to a few of the mech's< where i was told to bring my truck to a ford dealership across town because they deal with more trucks?!?!", and you are still upset with them. Maybe that is where they send their trucks. Sometime we all need to be adults and stop expecting someone else to fix our fuck-ups and stop crying when others don't want to. This is not a Toyota or dealership problem it is the OP problem to fix.
  7. Mar 26, 2010 at 6:44 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    You are on the hook for the damages. I would want the best results I could pay for. If the dealership tried to fix it and couldn't- I would take their recommendation and go somewhere else to get it worked out.
    I'm not going to lie- Frame issues always seem to leave gremlins when then "Just bend it back" You are going to have a good long while before it settles out- and it will NEVER be the same as it was before.
    I'd get over the dealership not being able to deal with your mistake and go find somewhere to get your truck fixed.
  8. Mar 26, 2010 at 6:57 AM
    bigburrito
    bigburrito Local Man
    DuPage County
    '09 TRD OR
    Demello sliders, fog lights anytime, 265/75R16 Duratracs, 60" HiLift, VIAIR OBA 2.5 gallon tank, FM Super 44, TSB springs, 5100s at .85, bent tailgate
    good point. mud or even snow stuck in your wheels will throw your wheel balance out the window
  9. Mar 26, 2010 at 8:55 AM
    nvdeserted
    nvdeserted Well-Known Member
    Reno, NV
    2009 Tacoma TRD OR Access Cab
    Electric Dynolock tailgate, TrailGear Slides, , 285/75-16 Yoko Geolanders on Wheelers Type B, SAW 2.0 front and back, Camburg b/j UCA, 1.5" AAL, Ubolt flip, ARB bump.
    That does suck but it does seem like it's beyond the spectrum of the average Taco mechanic. See an alignment specialist, or suspension shop.
  10. Mar 26, 2010 at 8:58 AM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    maybe the FORD shop has a frame rack?
  11. Mar 26, 2010 at 9:00 AM
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2011 DC TRD SPORT Prerunner
    3” spacer lift, 285/75/17 KO2, Spidertrax 1.25” spacers
    Go to Ford? The hell... If they are not qualified to work on trucks, they shouldn't sell them.
    Hey! I'm 19 and trying to get a job at a dealership so I can change oil... Beats my current job.
  12. Mar 26, 2010 at 9:06 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    '06 TRD Access Cab, v6, 6-speed
    Scaffolding and a painted grill
    My thought exactly. Might need to have the frame straightened.
    If the leaf mounts got bent, replace them with something more sturdy. Bending them back will only weaken them more.
  13. Mar 26, 2010 at 9:27 AM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    Time to do a shackle swap!
  14. Mar 26, 2010 at 11:04 AM
    Fortech
    CANADA
    I still like to hear where the tow rope/strap was attached to the truck. No point in more than one member having to go through this. As a rule I never attach anywhere but the tow hitch. I see lots of people attaching to one frame rail or the other, or around the rear axle, and cringe every time I see them being yanked out at an angle.
  15. Mar 26, 2010 at 11:52 AM
    MikeDeason
    MikeDeason Well-Known Member
    Trying to picure your "LEAF MOUNT"...have any pics????
    Here's mine.
  16. Mar 26, 2010 at 9:46 PM
    Isthatahemi
    Isthatahemi Well-Known Member
    TRD OFF ROAD
    BFG AT's, Weathertechs, Hoppy's brake controller.
    Strange replies considering that a vibration has nothing to do with any stationary parts (ie:the frame). If you have a vibration, it is a bent or broken moving part, (wheel, axle, driveshaft, brake drum...) or an out of balance part (wheel, driveshaft, or brake drum). My guess is likely there is a big chunk of mud stuck to the inside of one of your wheels....
  17. Mar 27, 2010 at 5:44 AM
    JKD
    JKD Well-Known Member
    Where are the pictures?
  18. Mar 27, 2010 at 8:42 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    While I agree with you about it possibly being mud- A misalignment cause cause a vibration- and if the leaf hanger is bent- that will cause a misalignment....no??
  19. Mar 27, 2010 at 9:47 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    It could be me but from your description of events I can not figure out how did you manage to bent mount.
    Those mounts dont bent when they dragged over rocks yet you manage to bent them in mud ???:confused:
    When you have bent frame or leaf mount you will not get vibrations.
    Either your wheels out of balance due to mud (like others stated) or your driveshaft is full of mud and out of balance.
    Bent frame will force truck to go to one side but not vibrate at some speeds. Vibrations means something is out of balance. So you need to tell us what did you hit and where .. ;)
  20. Mar 27, 2010 at 10:48 AM
    Fortech
    CANADA
    Maybe someone wrapped the tow strap around just one side of the frame or maybe even around one side of the rear axle and yanked the truck out. Such sudden stress on only one side COULD bend something out of alignment, especially considering the truck had a load in the rear and stuck in mud. Maybe the tow vehicle gave a quick "pluck" instead of an evenly slow pull? God forbid the strap was placed around the spring pack itself and the truck pulled out.
    I asked this question earlier, but no reply yet. I know the OP has been browsing the thread though because they were online yesterday afternoon and the active users at the bottom of the page indicated they were reading this thread. After being in such a panic about the situation and browsing the thread but not posting, I assume they feel either really bad about their rant/actions or just started the thread as a troll. Not assuming one or the other but that's the way I interpret it...
