Bent frame
Discussion in '1st Gen. Tacomas (1995-2004)' started by Johnnyboy3921, May 15, 2020.
  1. May 15, 2020 at 3:36 PM
    Johnnyboy3921
    Johnnyboy3921 [OP] Member
    2002 xtra cab Tacoma
    After market exhaust
    Hey there, I recently bought a 2002 xtracab Tacoma and found out after buying it that it has a bend in the frame behind the front passenger wheel. I was wondering if there is anyway I could get this fixed. Any and all ideas will be appreciated.
  2. May 15, 2020 at 3:55 PM
    Wulf
    Wulf no brain just damage
    rock raisin
    Take it to a frame shop to have them assess the damage and prepare an estimate
  3. May 15, 2020 at 5:25 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Welcome to TW John
  4. May 15, 2020 at 6:21 PM
    Wsidr1
    Wsidr1 Well-Known Member
    Indiana
    2 x 95.5 Ext 2.7L & 3.4L A/T 4x4
    I came into a later 80's Toyota truck (4x2) that the PO had ran off the road on the right side. Bend the frame back to where the tire was against the rear part of the fender opening.
    Body shop charged me $700 to straighten the frame. I had to buy torsion bar, lower control arm, and a few other parts. I found used parts. I was out approx $1000 total to get it right. I got the truck free, fixed it, and sold it for $1400. That was 4 years ago and the new owner lives near me and is still very happy with the truck.
  5. May 16, 2020 at 3:51 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Is it destroying the front tires ??
    Impossible to get an alignment ??
    It would be nice to see pictures what is the rest of the truck like ?
    Running Board Man likes this.
  6. May 16, 2020 at 7:20 AM
    Johnnyboy3921
    My apologies I should’ve thought of that. It’s not currently possible for it to be aligned. It does not seem to be wearing the front tires too much but I have not owned it long so it is possible that they are. The rest of the truck is in good condition.
  7. May 16, 2020 at 7:39 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    I have seen worse but it can be hard to make a call without being up close and person.
    Body shop that pulls frames gotta be some gossip about which shop is the best in your area .
    maybe who the body shops out source there frame work to.
    cruxofthebisquit likes this.
  8. May 16, 2020 at 7:48 AM
    Johnnyboy3921
    We have two body shops near me that have pullers. I am not sure which of the two is better. I live in Southwest VA if there are any reputable shops that you all know of close by I’ll take it there.
  9. May 16, 2020 at 8:02 AM
    PyritePirateBill
    PyritePirateBill Well-Known Member
    Bill
    North Myrtle Beach, SC
    2014 pyrite mica TRD Sport 4x4 AC
    OME 886 Nitrocharger lift, Dakar HD leaf pack, u-bolt flip kit, Bilstein b110 rear shocks, Wheeler's super bumps,18x9 Worx Havoc, 35/12.50/18 Nitto Ridge Grapplers, ENVE Grille with LED lightbar & raptor leds, ditch lights, 6k hid, tinted tails, AtTheHelm bed stiffeners, SOS Concepts rear bumper, Demello baja front bumper, Smittybuilt 9.5k winch, Mobtown weld-on sliders, AllPro IFS & transm. skid, Mobtown transfer case skid, led fogs, led lights in rear bumper, 54" Bulldog hi-lift jack, Razorback shovel & axe on Quickfist mounts, Cobra CB w/Firestik antenna, Yellow wire mod for 4Lo, URD y-pipe, 2.5" custom exhaust w/ Borla muffler, Viair portable air compressor, Kryptek Typhon seat covers, AJT dash knobs
    I've been a frame tech for 40 yrs. Fixed many of those. When it bends there, it is usually from a direct frontal impact on the wheel. When it bends in that spot, it also moves inward the part of the frame that the rear of the LCA bolts to thus decreasing caster. Also check the cam tabs at LCA bolts to see if they are bent/flattened
    May also diamond the frame as well depending on severity of hit.
  10. May 16, 2020 at 8:04 AM
    PyritePirateBill
    Bill
    Being it's an '02, what kind of shape is the rest of the frame in? Is it rusted very much?
  11. May 16, 2020 at 8:21 AM
    PyritePirateBill
    Bill
    If you can get it to northern VA, I can pull the frame for you. We have 3 frame machines in our bodyshop, along with computerized lazer measuring system
    This is when I repaired my own to prevent it from being a total loss back in 2017. Was rear ended by a work van. Before & after photos.
    JasonLee, SR-71A, ireymon and 8 others like this.
  12. May 16, 2020 at 8:24 AM
    Johnnyboy3921
    Thank you for your advice. The rest of the frame is in very good shape. For the year model it is not rusted very much at all.
    PyritePirateBill likes this.
  13. May 16, 2020 at 8:25 AM
    Johnnyboy3921
    Where in VA are your shops located? Also do you have any idea ballpark how much it would be to have it fixed?
  14. May 16, 2020 at 8:34 AM
    scocar
    scocar hypotenoper
    Cool pics, I've never seen a frame shop in action.
  15. May 16, 2020 at 8:41 AM
    PyritePirateBill
    Bill
    We are at:
    Caliber Collision
    202 Lane Ct, Suite A
    Sterling, VA 20166
    Price would be about $350 for measure & frame pull. If frame also has diamond, add another $50.
    You will probably need a new lower control arm as well. (You figure if that control arm pushed back with enough force to bend the frame, then the bushings and ball joint in it are damaged too) Then we'd get into whether the cam bolts are seized up or not, so you could need new bolts, etc.
    Bigdaddy4760 likes this.
  16. May 16, 2020 at 8:50 AM
    Johnnyboy3921
    Woah you weren’t kidding when you said northern lol. Unfortunately you are a little to far away from me. However, I do really appreciate all your advice it has been most helpful but I think I’m gonna have to look into some shops closer to home.
  17. May 16, 2020 at 9:40 AM
    TRD493
    TRD493 Well-Known Member
    Dave
    Texas (DFW)
    17 TRD Sport DCLB 4x4 / 01 4x4 V6 Extra Cab TRD SR5
    Nice work!
  18. May 16, 2020 at 10:41 AM
    Loctite77
    Loctite77 Well-Known Member
    Zeek
    NC
    2097 mashup vroom vroom bigwheelieee
    Some rust, runs good.
  19. May 16, 2020 at 11:03 AM
    Johnnyboy3921
    Well I certainly hope I can get mine fixed. Thanks for the input though.
  20. May 16, 2020 at 11:05 AM
    Loctite77
    Zeek
    NC
    I’m sorry man. Didn’t mean to be a Debbie downer! I would add that I drive my truck crooked like that for 7 years, it wasn’t perfect but it was okay.
