Bent frame?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JeffBoyardee, Apr 13, 2022.
  1. Apr 18, 2022 at 6:13 PM
    #41
    Timthesignman
    Timthesignman Member
    Tim
    Chesapeake
    2010 TRD sport tacoma access cab 4x4
    Factory level kit
    Have you do a car fax on it to see if its been in a accident?
  2. Apr 18, 2022 at 6:15 PM
    #42
    Cryptictoy
    Cryptictoy Well-Known Member
    Esperance, N.Y
    The hood looks like the hinge torqued up, shutting your hood with a tool or what ever will do that. I just did that on my old runner this past winter with ice/snow. Most likely a new hinge will fix it. If the hood is colasped on the front of hinge you can use the old hinge to pull it back out. I wonder if your control arm is bent? Is coil spring seated in the collar properly on the high side? If not that would preload the spring and give more lift.
  3. Apr 19, 2022 at 7:00 AM
    #43
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Is the hood to fender gap equal on both sides with the hood closed?
