Bent Input Shaft Manual Trans 3rd Gen
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Craig&Fred, Dec 14, 2024.
  1. Dec 16, 2024 at 8:30 AM
    Rusty66
    Rusty66 Ain’t Afraid
    Rhode Island
    19' Limited 4x4 (01' TRD OR, 97’ SR5 V6, 88’ SR5 Extra Cab)
    The only time I’ve ever seen a bent input shaft is when the trans was removed/installed and the tech let it hang off the back of the engine before bolting up the bell housing.
    shakerhood, Big tall dave and Chew like this.
  2. Dec 16, 2024 at 8:50 AM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    Doubtful, was just wondering if the transmission lived a regularly serviced life. If the fluid was never changed or something I could see the bearings going bad is all.
    Did they pull the transmission a second time to confirm the bent shaft they claim or is that just a guess after the first round of parts didn't work?
    Chew likes this.
  3. Dec 16, 2024 at 9:32 AM
    Craig&Fred
    Craig&Fred [OP] Member
    Craig
    '17 Taco TRD OF Manual
    Got it. Love the idea of it just being a bearing.
    They did not pull the transmission after they installed the new parts. That was just their guess based on the noise.
    So it technically has not been diagnosed as a bent input shaft.
  4. Dec 16, 2024 at 9:34 AM
    BLtheP
    Plano, TX
    Well, a bearing I’m thinking of would be internal and would essentially be a “rebuild” of the transmission which probably not many shops will be willing to do. Although maybe. Hard to say.
    I’d probably be looking for used nearby. If you’re anywhere near Texas, I’ll have one in Dallas available soon.
  5. Dec 16, 2024 at 9:37 AM
    Craig&Fred
    Craig
    Ok right on. Good to know. I'll keep an eye on it and plan on sourcing a used transmission in the near future. For now I guess I'll just drive it until I can't.
    shakerhood and auskip07 like this.
  6. Dec 18, 2024 at 6:14 AM
    lbhsbz
    lbhsbz Well-Known Member
    If the input shaft was bent, you'd have issues with the clutch failing to fully disengage.
    If your noise goes away when the clutch is depressed (release) and the vehicle is stopped, you have a bearing failing inside the transmission on the input shaft
  7. Dec 18, 2024 at 8:27 AM
    STEELeR43
    STEELeR43 Well-Known Member
    Hawaii
    2023 Tacoma TRD 4x4 6MT
    3" Icon Lift, SPC UCA, B&M Sport Shifter, OTT Tune
    If never change transmission oil, never hurt to change it out, can check it’s confition. Can do it yourself, but make sure it is GL-4 gear oil, and the fill plug of manual transmission can be removed.
