Bent rear axles?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jluu44, Mar 25, 2010.
  1. Mar 25, 2010 at 6:39 PM
    jluu44
    jluu44 [OP] Well-Known Member
    Jon
    North County San Diego, CA
    2016 Tacoma DCSB 4x4 off-road
    I took my truck to the shop to do a tire rotation and they noticed a problem..
    My rear terra grappler tires have been wearing out unevenly.. the tread on the inside are already worn out after 15k miles on them.
    They told me the tires on the back cannot have camber wear.. and since I have not rotated them since they were on brand new, they think my tie rod or axle may have been bent somehow.
    What do you guys think can be wrong with it? Don't they require a significant amount of force to bend the rear axles? I have never taken my truck off roading or anything.
    I don't want to install new tires on the rear and have them go to waste in 15k miles again...
  2. Mar 25, 2010 at 6:51 PM
    gtrotter
    gtrotter Well-Known Member
    Interlake, Indiana
    2009 Regular cab 4x4, ARB's, 4.88's, bumpers, 2017 DCSB SR5 stock
    locker,mud tires, lifted, toolbox
    Did you buy it new? If so, ever been in an accident or jumped it? I bent my axle in a wreck, but it was pretty extreme.
  3. Mar 25, 2010 at 6:54 PM
    SC4333
    SC4333 Well-Known Member
    Grant
    San Antonio, TX
    2016 TRD Off-Road 4x4 DCSB - Super White
    Well, there is only one way to find out. Put a dial indicator to the rear axle and measure the run out. It wouldn't be the first time a rear axle has bent.
  4. Mar 25, 2010 at 6:56 PM
    Timber
    Timber Crankey Old Yacht Jockey
    Tim
    San Pedro Bay Ports
    just a couple comfort items.
    Sound fishy to me, but if they are worn like that and they have not been rotated I guess it possible. Seems like there would be other problems like bad axle seals or bearings maybe even rear end noise. Might take a bit of investigating like some friends and a couple straight edges across the axle end flats and a tape measure top to top and bottom to bottom. there is really no way to adjust it but maybe a alignment shop could confirm how much its out. What year is the truck how many miles and are you the original owner?
  5. Mar 25, 2010 at 7:09 PM
    4x4Runner
    4x4Runner Now with more Oi Vey! Moderator
    Drunken Sailor
    Somewhere between Maine and Florida
    2017 4Runner Smashed Ass Edition
    KDSS
    With my complete lack of engineering this does not make sense. If the axle was "bent" wouldn't the wear spots on the tire be on the inside and outside of the tire and 180* off from each other? Wouldn't there have been a vibration from the wobble from the bent axle? I agree that there should be some bad seals/bearing with excessive play in the rear axle if in fact the axle was bent.
    What were the tires aired up to? While it seems that the wear on an overinflated tire would be the center... Why would it wear on the inner edge?
  6. Mar 25, 2010 at 7:47 PM
    jluu44
    Jon
    It is a 2005 trd sport prerunner with approx 65k miles.
    It was involved in a slight collison which was mostly cosmetic..
    The tires were aired to the recommended psi on the tire wall. I checked it about every month or so.
    Could there be any other possibility of uneven tread wear for the rear tires?
  7. Mar 25, 2010 at 7:58 PM
    desertdude59
    desertdude59 CRAZY 4WHEELER
    From the Mojave desert now in Wild and Wonderful W
    1991 toyota 4x4 sr5-lost but not forgotten
    4" lift after market front bumper bed mount lightbar/roll bar (4)6" kc's on the roll bar (2) kc flat back bumper mounts f/r gears for the 33's
    Your truck lifted? If your axles were bent you would probably have a hellish vibration. Could be non balanced tires. Hard to say. You don't have tie rods in the rear end though.
  8. Mar 25, 2010 at 8:02 PM
    Asgard
    Asgard Well-Known Member
    06 PreRunner DC SR5 w/LSD
    If they said your tie rods in the rear might be bent, I would take it to another shop.
  9. Mar 25, 2010 at 8:15 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Check your wheel bearings
  10. Mar 25, 2010 at 8:16 PM
    desertdude59
    Sounds like they wanted to make an xtra buck. They probably rotated the tires front to back and then said , " Your tie rods are bent in the back." What a bunch of dummies. lol. I imagine thats why the tires were worn on the inside if there was never any rotation.
  11. Mar 25, 2010 at 8:17 PM
    jluu44
    Jon
    It is at stock height and supension.. I will try another shop to get another look.
  12. Mar 25, 2010 at 8:18 PM
    jluu44
    Jon
    They didn't rotate them yet because I was watching them lifting up the truck and thats when they noticed the uneven tread on the rear tires
  13. Mar 25, 2010 at 8:19 PM
    desertdude59
    I would. Those guys seem dumb!
  14. Mar 25, 2010 at 8:20 PM
    nuckinfuts
    nuckinfuts NyQuil on the rocks.
    Pacific NW
    '06 AC TRD Off-Road
    DT Long Tube Headers, Empire O2 simulator, catback, Shrockworks Sliders, Old Man Emu 3" lift with 885 coils (with 1/2" top plate spacer and Dakar Leaf packs), Hi-lift mounted in bed with 4XRAC mounts, WT floor liners, other stuffs
    Sounds like an alignment related problem. I'd get someone else to take a look, it's hard to know what they did if they're saying your rear tie-rods are bent. Did they fill your blinker fluid and check your muffler bearings too?
  15. Mar 25, 2010 at 8:23 PM
    desertdude59
    Bahahahahahhaahahaha. Good stuff:D
  16. Mar 25, 2010 at 8:24 PM
    PA452
    PA452 Well-Known Member
    Western PA
    15 Access TRD Offroad, V6, 5spd Auto, 4x4
    :D
