Bent rear drum backing plate
Discussion in 'New Members' started by afuller, Jul 26, 2019.
  1. Jul 26, 2019 at 8:20 PM
    afuller
    afuller [OP] Member
    Drew
    2002 Tacoma TRD ext. cab
    Custom subframe/3” suspension lift
    Hey everyone,
    I recently had my wheel bearings replaced and the shop that I had press the bearings bent the backing plate while pressing. Now the drum cover is grinding away at the inner ring of the backing plate that fits in the groove of the cover. Has anyone had this and successfully bent it back before? If so, any tips? Im trying to avoid pulling the axle shafts and having to buy more gear oil, have everything pressed out and repressed again, etc.
  2. Jul 26, 2019 at 8:28 PM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Welcome to TW!!
    Taco critter likes this.
  3. Jul 26, 2019 at 8:36 PM
    afuller
    afuller [OP] Member
    Drew
    Thanks!
  4. Jul 28, 2019 at 8:14 AM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Welcome to TW! What did the shop say when you mentioned this to them?
  5. Dec 3, 2024 at 5:56 PM
    Trdsandycheeks
    Trdsandycheeks New Member
    Colin
    23 OR MT
    I know this is an old thread but from experience always replace the backing plate. I recently had a hard hit on a rock crawling trail and my handbrake stopped working. Tried to tighten the handbrake up but still nothing. On the way to my buddy's garage, I lost all braking power. Turned out that the shoe and the backing plate were bent and with a little more wear they caused the cylinder to fail and leak fluid inside the drum.
    So if you like being able to stop when you press the pedal. Fix all of it
  6. Dec 3, 2024 at 6:00 PM
    SecureIT2021
    SecureIT2021 Well-Known Member
    06 Tundra SR5 LTD CC 4.7 V8 AT 2WD
