"Bent" TRD exhaust - Need help on how to fix
Discussion in '2nd Gen. Tacomas (2005-2015)' started by pbcolt, Dec 15, 2013.
  1. Dec 15, 2013 at 11:53 AM
    pbcolt
    pbcolt [OP] Well-Known Member
    Colton
    San Diego
    2024 F250 Tremor
    FWC Hawk
    Went camping a few weekends ago and ran over a tree stump/log a little funny. Ever since my exhaust tip has been touching my rear shackle and rattles when the truck comes to a stop. I can't figure out if the exhaust, the exhaust hangar or the truck's hangar actually got bent. I know I could probably take a BFH and hit any one of those things to make it work, but I'd rather fix the one that actually is messed up.
    I've attached a couple pictures. Any help would be really appreciated.
  2. Dec 15, 2013 at 1:08 PM
    lj973gm
    lj973gm Sold it, dont miss it yet.
    Ohio
    06 DCSB 4wd
    Looks like it bend the hanger that is welded to the exhaust where it is a single piece of rod before it splits off to two pieces.
    Pull it out of the hanger, heat it with a torch and bent it back. Beating on that will not be all that easy since the whole system is suspended and isolated in rubber mounts.
    If you do not have oxy/ace torch set you can get by with a mapp gas torch. It will cherry a 1/2" rod after 5-10 minutes.
  3. Dec 15, 2013 at 1:30 PM
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Kings bruh
    Or if you plan on offroading is suggest cut it little bit after the axle and make it to a turn down
  4. Dec 15, 2013 at 7:34 PM
    pbcolt
    Colton
    San Diego
    2024 F250 Tremor
    FWC Hawk
    Thanks. I'll go buy a torch and see if I can bend that part of the hanger a little.
  5. Dec 15, 2013 at 7:52 PM
    lj973gm
    Ohio
    06 DCSB 4wd
    Might be easier to stop at muffler shop and pay them 20 bucks to do it for you.
  6. Dec 15, 2013 at 8:11 PM
    HBtaco02
    HBtaco02 Well-Known Member
    Allen
    Huntington Beach
    02 4wd SR5 TRD
    ARB Front Locker grey wire mod Camburg UCA's Extended Kings All-Pro expo's 10" Bilstien Brute Force Hybrid front bumper Smitty XRC8
    Cut it off just after the rear axle.
  7. Dec 15, 2013 at 8:17 PM
    Socalduckslayer
    Socalduckslayer Pelfreybilt Off-Road
    Tyler
    San Diego, Ca
    12 Tacoma
    Odds and Ends
    Come by the shop, we will cut that shit off where it should be and all of you worries will be gone
