Bent Wheels Studs?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Notkyle21, Aug 22, 2020.
  1. Aug 22, 2020 at 4:21 PM
    Notkyle21
    Notkyle21 [OP] Member
    Lyle
    2005 Indigo pearl Tacoma sr5
    Pro comp series 69 wheels, ebay headlights, Bilstein 5100 leveling shocks
    Hi all, I recently got some new alloy wheels for my 05 Tacoma and went to go torque them down after driving on them for a few hours. I haven’t gotten a torque wrench yet so I wasn’t able to properly do it. Instead, I put an adapter that came with my new lug nuts on the end of my OEM lug wrench. It had a bit of play to it so when I went to torque them down it made it so that pressure was being applied downward or toward me on the wheel studs, and quite hard. I can’t really tell if after I did this the wheel studs are bent or not, but I’m kind of worried that I did bend them. How easy is it to bend wheel studs on these trucks? Would it have been possible?
  2. Aug 22, 2020 at 6:00 PM
    Bleep100
    Bleep100 TOYOTA 4 LIFE
    17 Sport
    I doubt you bent them . They are your wheels and very important so you should take it to Walmart or somewhere and have them check them out and torque . Probably $20 to safe not sorry .
    Hi welcome and good luck .
    Notkyle21[OP] likes this.
  3. Aug 22, 2020 at 6:45 PM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Got any pics?
  4. Aug 22, 2020 at 6:47 PM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    you'd of probably snapped one off before bending them
  5. Aug 22, 2020 at 7:07 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    More than likely you didn’t bent a stud.
    The chances of marring up a lug nut are more likely.
    The farther away you get form the lug nut to the wrench, the more likely this is to happen.
    The OEM lug wrench fits way back off the nut to begin with, adding the socket didn’t help you any.
    I personally carry a dedicated 1/2” breaker bar and correct socket in my truck.
    I never had like using the OEM Wrench, you really need to be careful and support the “head” while using it.
  6. Aug 22, 2020 at 7:23 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    I've popped a wheel stud before by over tightening. It just pretty much fails axially, or in a straight pull. The lug nuts are supported enough that the studs don't really flex sideways.
  7. Aug 22, 2020 at 7:23 PM
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    should never take extreme effort to install correctly
    can lead to afuture failure
    beam torque wrenches tho not fancy are cheap
  8. Aug 22, 2020 at 7:23 PM
    TnShooter
    Deogee
    STOCK
    FWIW, I’ll try to explain what OP is saying.
    Imagine using a long extension and NOT supporting the head of the ratchet.
    That’s what OP did, I doubt he did anything to the studs.
    Notkyle21[OP] and whatstcp like this.
  9. Aug 22, 2020 at 7:41 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
  10. Aug 23, 2020 at 7:45 AM
    Notkyle21
    Lyle
    I have a torque wrench being delivered on Monday, so after this weekend I should not have to worry
