BenWA's 2005+ Power Sliding Rear Window Quick Install Kit
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by BenWA, Aug 13, 2011.
  1. Feb 19, 2012 at 5:49 PM
    #301
    GregLee98
    GregLee98 Well-Known Member
    Greg
    08 Tacoma TRD Sport
    TRD Cold Air Intake TRD Cat-back Exhaust URD MAF Calibrator 3 inch Top Gunz Customz Lift Spidertrax 1.25" Wheel Spacers Goodyear Wrangler MT/R w/Kevlar (275/75R/17) Tires Power Tailgate Lock linked to power door locks Back-up Sensors Bakflip F1 DIY Auto-dim Rearview Mirror Power Sliding Rear Window Mod by BenWA 4x4 Switch Light Mod 400W Inverter Anytime Mod 110V In Cab Mod with 25' Extension Cord Rear Differential Breather Relocation Mod Chirp on Lock Mod A/C Off with Defrost Mod Brighter Reverse Lights Mod Tailgate Theft Deterrence (Clamp) TRD Seat Covers Extra D-Rings in front of bed
    Unseasonably warm today. Rolled with the back window open. My daughter like askign me to open and close it to watch is go.
    Best mod ever. :)
  2. Feb 19, 2012 at 6:05 PM
    #302
    CrazyCooter
    CrazyCooter Hold My Beer!
    Johnathan
    Virginia
    me likey! and want. def going on mod list for sure.
  3. Feb 21, 2012 at 10:15 AM
    #303
    gov875
    gov875 WahooTaco
    Pacific Beach, CA
    TRD Sport DCLB
    Wet Okole's (front & rear), Weathertech Floormats (front & rear), cheap tailgate theft mod, extra d-rings, low profile toolbox (flat black), Thule Roof Rack (58" load bars), Thule Ski/Snowboard Roof Rack, Blacked Out Badges, Fishing Bobber Trailer Ball Cover, AVIC-X930BT w/ XM & steering controls, 5100s All Around (front set at .85), Eibach Coils, Rear TSB, rear AAL, LR UCAs, Toytec Diff. Drop, Mudflap Delete, Tailgate Reinforcement, Spidertrax (all 4), 285 Nittos, Rear Diff Breather Extension, TRD Exhaust, Powered Rear Sliding Window, DeeZee Bedmat, rear-view anytime mod, trailer bracket relocate, fog light anytime mod, redline hood struts, Satoshi with Homertaco Custom TRD Mesh, Hella 500s behind the grill, Brighter Reverse Lights
    ben, has anyone mounted the switch between the two map lights before? is there something behind it that prevents that location? my kit should get here this weekend so i'm trying to plan it out in order to bother you as little as possible during the install :)
  4. Feb 21, 2012 at 10:20 AM
    #304
    BenWA
    BenWA [OP] Well-Known Member
    Boston burbs
    '06 Double Cab TRD Off Road 4X4
    Nobody has installed one of my switches there (to my knowledge, at least), but TacomaDad installed a similar window rocker switch for Engineerlt's linear actuator mod.
    The switch is very similar in dimension to mine, so mine would probably fit too. I would definitely suggest doing some reconnaissance up there to see how deep the space is between the lights, though. The one drawback is that it would be kind of a pain to route the wiring up there, I would think. :notsure:
  5. Feb 21, 2012 at 10:38 AM
    #305
    gov875
    gov875 WahooTaco
    Pacific Beach, CA
    TRD Sport DCLB
    yea it would be tougher but i can't imagine it's that much more of a pain than runnin it over under the AC controls which is my current thought. I want it to be easy for the passenger to operate. I'll do some recon and take some pics of what i find. Might also PM TacomaDad to see what his experience was. That location just seems like the most natural place for the switch to be put... then again i do still one day dream of a sunroof in the truck :cool:
  6. Feb 21, 2012 at 11:09 AM
    #306
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Running the wires to the OH console is no more difficult, IMO, then running them to the AC panel area, just need more wire.
    Take the OS handle off, run the wire from the driver's side kick panel up to the OS handle area, lift the headliner up a bit by the windshield and push the wires to the console.
    Personally, I didn't do it that way since I did not want to make a hole in the console. My switch is in the switch blank area under the HVAC panel.
  7. Feb 21, 2012 at 12:12 PM
    #307
    BenWA
    Boston burbs
    I forget -- did you use one of the Firgelli automations rocker switches like in the above pic? Or did you use the type of switch that I provide? I can't recall. I'm guessing you used a Firgelli switch, since you originally had the LA mod. I ask because somebody who posted above was wondering if one of my switches will fit in the switch blanks under the HVAC panel, and I didn't have a good answer.
  8. Feb 21, 2012 at 12:23 PM
    #308
    Lurkin
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Firgelli, and I had to Dremel out the switchblank hole to get it in there.
  9. Feb 24, 2012 at 5:02 AM
    #309
    gov875
    gov875 WahooTaco
    Pacific Beach, CA
    TRD Sport DCLB
    got my kit in the mail yesterday! thanks Ben! now if only i wasn't traveling for the next 3 weeks i could get the thing installed... i'll snap some pics as i go and if i do the other switch location.
  10. Feb 25, 2012 at 6:19 AM
    #310
    Nick54
    Nick54 Well-Known Member
    Nick
    Mentor Ohio
    2010 Tacoma TRD Sport
    ARB Rear Locker & Compressor, Bakflip F1, Antennex 13" flexable antenna, WeatherTech Floor Liners, WeatherTech Side Window Visors, Tacoma Bed Mat, Demello Rock Crushers, Dynamax Ultraflow SS Muffler, TSB 4-Pak Leaf Springs, AFE Pro Dry Filter, Redline Hood Struts, Color Matched Angry Eyelids, Combo Lock Bed Compartments, Bed Mat, Pop-N-Lock, Wet Okoles, Goodyear Duratracs on ProComp 7033's, M101A2 Trailer, Grillcraft Mesh Grill, Light Racing UCA's, King OEM Performance Remote Reservoir Adjustable Front & Rear Shocks, JVC NT3HDT, Blue Sea Aux Fuse Panel, BAMF Behind Grill Light Bracket, Kragen 55W 7" HID's, CBI Front Receiver, Home Link Garage Door Opener, FlyEyez Light Unit, Bud Built Front to Back Skids...
    I purchased one of Ben's kits and am waiting till spring to install it. I was considering many options for switch location and the one I'm leaning toward is on the front side of the center console between the front seats. With your arm on the arm rest, reach over the edge and toggle the switch in the direction you want the window to travel. I do have a console safe installed so I'm not sure there is enough room for the switch body between the the safe and the console, but the wires sure would be easy to run to that point. Welcome insight from others.
  11. Feb 25, 2012 at 6:41 AM
    #311
    GregLee98
    Greg
    08 Tacoma TRD Sport
    I thought about that too. If you have the safe, you probably don't have room for the switch that comes with the kit.
    You may consider and easy to run wires to it, its the cup holder, close to the console. I thought about it, but didn't want to get any moisture near the switch and risk shorting the system out.
  12. Feb 28, 2012 at 4:02 PM
    #312
    BenWA
    Boston burbs
    I don't have any advice to offer other than -- if you end up mounting it there please post pics! :D
  13. Mar 2, 2012 at 9:39 PM
    #313
    knine00
    knine00 Well-Known Member
    Hudsonville, Mi
    12 PreRunner DC TRD Sport
    Stock for now
    Do you have any kits made up yet?
  14. Mar 2, 2012 at 10:43 PM
    #314
    BenWA
    Boston burbs
    Will be restocked by middle of next week. :)
  15. Mar 2, 2012 at 10:52 PM
    #315
    jbclarke16
    jbclarke16 Well-Known Member
    Josh
    Moncks Corner, South Carolina
    06 Silver DCSB
    Double Din touch screen radio, and one 10" Kicker Sub
    Someone may have already asked this but do you think this kit would work with AC models?
  16. Mar 3, 2012 at 2:13 PM
    #316
    bskin
    bskin Well-Known Member
    Eagle River AK
    2016 DC TRD Off Road MT
    I could make a day trip over to Seattle if you need to use my AC, not sure how long you would need the truck....I have a 2010.
  17. Mar 4, 2012 at 9:33 AM
    #317
    knine00
    Hudsonville, Mi
    Stock for now
    Think I am going to get one soon.
  18. Mar 4, 2012 at 1:21 PM
    #318
    GregLee98
    Greg
    08 Tacoma TRD Sport
    Dude, I would get it. I love mine. Finally was able to smoke my cigars in my truck while wheeling down trails because I could open the back window and let the air flow through.
    Definitely worth it :)
  19. Mar 4, 2012 at 3:57 PM
    #319
    BenWA
    Boston burbs
    PM replied! :)
  20. Mar 4, 2012 at 3:58 PM
    #320
    BenWA
    Boston burbs
    Not yet. Working on an AC version!
