BenWA's 2005+ Power Sliding Rear Window Quick Install Kit
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by BenWA, Aug 13, 2011.
  1. Mar 9, 2012 at 3:59 PM
    #381
    firulice
    firulice Well-Known Member
    james
    utah
    05 DC SWB 4x4 Sport
    3 inch lift (coilovers, leaf pack and shocks Katzkin leather interior Nfab Steps Gibson Exhaust Nfab light bar with piaas and hellas Rear power window Tonneau sport cover
    I'll take a kit minus the switch
  2. Mar 9, 2012 at 4:11 PM
    #382
    BenWA
    BenWA [OP] Well-Known Member
    Boston burbs
    '06 Double Cab TRD Off Road 4X4
    All current orders have shipped! :thumbsup:
  3. Mar 9, 2012 at 4:13 PM
    #383
    BenWA
    Boston burbs
    Roger that. Not sure when my next production run will be completed but I'd guess we're looking at about 3 weeks out.
    If you want to get the ball rolling, shoot me a PM with your zip code and let me know if you have the stock storage cubbies behind your rear seats, or if you have some other arrangement (such as aftermarket sub box, amps, etc).
    Thanks!
  4. Mar 9, 2012 at 4:17 PM
    #384
    firulice
    james
    utah
    05 DC SWB 4x4 Sport
    pm sent, thanks
  5. Mar 9, 2012 at 4:22 PM
    #385
    BenWA
    Boston burbs
    So here are a couple of OEM switch options that may work, if you are willing to spend the coin. My local dealership quoted me $84 on the Tundra down-sliding window switch, and that does not include a harness connector. Not exactly sure what the 84152 switch is below but it looks like it may be a side slider switch.
  6. Mar 9, 2012 at 6:21 PM
    #386
    HonoluluTaco
    HonoluluTaco Well-Known Member
    Koi
    Reston Virginia
    10 TRD 4x4 OffRoad DC/SB
    2010 TRD OffRoad DC/SB, 285/70/17 KM2's, Mickey Thompson Classic Locks, Total Chaos UCA's King 2.5 RR Coilover 3" AllPro Leaf Pack, 2.0 Fox RR, Ubolt flip kit, MBRP dual cat back, URD TCAI and MAF Calibrator, TRD Sport Hood w/ scoop, E&G Classics Custom Stainless Grill, Color matched grill and door handles WeatherTech floor mats, FormulaOne Pinacle 15%+Air blue windshield Tint, RedLine hood struts, TRD 3rd Brake light Decal, Relentless Fab Hybrid 2 piece Sliders with Kick out Relentless Fab Aluminum Front bumper, Relentless steel rear bumper, Relentless Steel IFS B.A.M.F LCA Skids, w/ Rear Diff Skid ordered In my Spare room waiting to be installed sits, Wet Okoles, Illuminated 4x4 switch mod, SockMonkey Hawaii TRD OffRoad Decal, Big box of Rammat, Speakers and Custom Sub from Mr.Marv,
    I am very interested but curious how you keep the latch from locking?
  7. Mar 9, 2012 at 6:34 PM
    #387
    BenWA
    Boston burbs
    It's a little hard to explain, but basically the window is open 1/8" (i.e., just shy of being latched) when the power window regulator is in its fully closed position. The window is still fully sealed by the weatherstripping and it is thus fully weatherproof, and also can't be forced open against the resistance of the motor and cable system, much in the same way that your drivers door power window can't be forced open.
    One of my customers removed the latch from the glass completely using a chisel, but I don't recommend it, as the chances of breaking the glass are significant enough.
  8. Mar 10, 2012 at 9:55 AM
    #388
    Shemicals
    Shemicals Well-Known Member
    Concord - East Bay CA
    '07 5-Lug Black Sand Pearl Access Cab 2WD
    Build Page
    again please tell me if this will work with an a c
  9. Mar 10, 2012 at 12:10 PM
    #389
    BenWA
    Boston burbs
    We don't have an AC version available yet but we are working on it. :)
  10. Mar 10, 2012 at 8:34 PM
    #390
    GregLee98
    GregLee98 Well-Known Member
    Greg
    08 Tacoma TRD Sport
    TRD Cold Air Intake TRD Cat-back Exhaust URD MAF Calibrator 3 inch Top Gunz Customz Lift Spidertrax 1.25" Wheel Spacers Goodyear Wrangler MT/R w/Kevlar (275/75R/17) Tires Power Tailgate Lock linked to power door locks Back-up Sensors Bakflip F1 DIY Auto-dim Rearview Mirror Power Sliding Rear Window Mod by BenWA 4x4 Switch Light Mod 400W Inverter Anytime Mod 110V In Cab Mod with 25' Extension Cord Rear Differential Breather Relocation Mod Chirp on Lock Mod A/C Off with Defrost Mod Brighter Reverse Lights Mod Tailgate Theft Deterrence (Clamp) TRD Seat Covers Extra D-Rings in front of bed
    You keep the window open about the 1/8th of an inch that BenWA said, but its fully closed. All the weather stripping keeps out all water. I have had zero problem. Love this mod. not sure about removing the latch, I would worry about breaking the window.
  11. Mar 11, 2012 at 10:02 AM
    #391
    whereismymind
    whereismymind Well-Known Member
    Don
    Broomfield, CO
    2012 Tacoma SR5 MGM D-cab
    Toytec Ultimate lift,Spidertrax spacers,Light Racing Control Arms,285/75/16 Duratrac's
    Is the latch basically held on with double sided tape or some type of glue?
  12. Mar 11, 2012 at 10:09 AM
    #392
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Ben's method works fine, but you can also use the linear actuator method. Get a few small rubber washers and put a small zip tie thru them. Place the washers behind the latch and tighten the ziptie down some. Washers keep the latch up. Get a black ziptie and its not very visible. Downside is that keeping the spring compressed that much may make the spring permanently compressed.
  13. Mar 11, 2012 at 2:54 PM
    #393
    GregLee98
    Greg
    08 Tacoma TRD Sport
    You do not have to modify the latch at all the way we did it (Ben's method). Since you have the window open 1/8" it never lets the latch get to the edge and clamp down and lock. It stays right on the edge and smoothly slides open and closed with no leaking or binding. No modifying the latch at all. Easy.
  14. Mar 14, 2012 at 4:01 PM
    #394
    BenWA
    Boston burbs
    By "latch", are you referring to the bracket that slides the window glass? If so, it is secured with adhesive.
    Or are you referring to the actual window latch itself? As far as I know, the latch is secured to the glass with similar adhesive as to what is used to hold a rearview mirror onto a windshield.
  15. Mar 14, 2012 at 5:41 PM
    #395
    knine00
    knine00 Well-Known Member
    Hudsonville, Mi
    12 PreRunner DC TRD Sport
    Stock for now
    Thanks ben, received my kit today. Installing this weekend!
  16. Mar 15, 2012 at 7:28 AM
    #396
    whereismymind
    Don
    Broomfield, CO
    Yes the window latch. I understand that nothing needs to be done with it for your system to work. Just thought it would look even cleaner if you could remove it. I'm going to take a closer look at it once I take delivery of mine.
    Thanks Ben!
  17. Mar 15, 2012 at 8:43 AM
    #397
    Lurkin
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Might want to search around some, I recall seeing a thread on removing the latch and, if I recall correctly (suspect!!), it did not turn out well.
  18. Mar 15, 2012 at 1:10 PM
    #398
    1GR
    1GR Toyota Dealer Technician
    Scott
    BC, Canada
    2012 Tacoma DCLB TRD Sport
    Sub'd
  19. Mar 15, 2012 at 1:59 PM
    #399
    BenWA
    Boston burbs
    You can remove the latch carefully with a naked utility knife blade, carefully working it thru the adhesive between the latch and the window glass. You will be left with a black patch on the glass that you can't get rid of, though.
  20. Mar 15, 2012 at 2:13 PM
    #400
    whereismymind
    Don
    Broomfield, CO
    ^^^I guess it would have to be on there pretty good otherwise people could just break into your truck easily.
    It must be installed different than the rearview mirror. Glass companies have to remove the mirror to replace windshields.
