BenWA's 2005+ Power Sliding Rear Window Quick Install Kit
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by BenWA, Aug 13, 2011.
  1. Jun 18, 2016 at 6:05 AM
    #1701
    Wes0311
    Wes0311 Well-Known Member
    Wes
    Denver, CO
    '13 SR5
    Toytec BOSS loft kit, add-a-leaf, AntennaX 13" antenna, 285/75's on MB wheels, and more to come
    Yeah, but I figured it was worth a try
  2. Jun 18, 2016 at 8:00 AM
    #1702
    Healyj7
    Healyj7 2010TRD Cape Cod
    Cape cod MA
    2010 Tacoma 4x4 crew cab...
    Led third brake light All bulbs changed to LED Blue... Bed cover Extra tie downs in bed Borla 3' aftermarket excuast Blacked out front grill Smoked front lights White turn/running lights Bed security Mod 2 inch front lift and level with bilstein front and rear shocks... 1 Inch wheel spacers BF Goodrich AT tires 270/75/17
    Interested if he ever comes back or someone has another solution....
  3. Jun 18, 2016 at 8:13 AM
    #1703
    Ohiophil
    Ohiophil This space intentionally left blank
    Phil
    Central Ohio
    2015 Tacoma PreRunner
    Give me some money so I can fill in this info
    Maybe people can hire this guy to sit in the back seat and open/close the window as needed.
  4. Jun 25, 2016 at 11:20 AM
    #1704
    Up2NoGood
    Up2NoGood Well-Known Member
    Jaimes
    BC, Canada
    2014 TRD Sport DCLB
    My guess (could be wrong) is he has dropped this project. He isn't very active anymore and the last time he posted anything at all about this mod was over a year ago.
  5. Jun 25, 2016 at 11:29 AM
    #1705
    Sleipnir
    Sleipnir Still havent found that stupid snipe
    I'm a horse
    Asgard
    Furd Rangero Ecoboost
    Yea that's true. Someone with the time and resources could pick it back up and get us all sliding windows! I really don't want to have to do this myself and I'm relying on the drive of someone else cause you know...lazy
  6. Jun 28, 2016 at 3:29 PM
    #1706
    Healyj7
    Cape cod MA
    Let's find a fabrication place and see if they will do a group buy!!!!
  7. Jun 28, 2016 at 3:36 PM
    #1707
    big_jarv
    big_jarv Well-Known Member
    2020 TRD Pro
    +1
    metrick1215 likes this.
  8. Jun 28, 2016 at 4:28 PM
    #1708
    Wes0311
    Wes
    Denver, CO
    '13 SR5
    X2!!
  9. Jun 28, 2016 at 6:39 PM
    #1709
    kashtyaatsi
    kashtyaatsi DieselDub
    Asher
    Bitterroot, MT
    LPC's
    Broken
  10. Jun 28, 2016 at 8:00 PM
    #1710
    GDOLBOI
    GDOLBOI Under Qualified And Overpaid
    Concord Ca
    2020 DBL cab LB Trd Offroad 4x4
    King, BAMF, SCS,
    I'm in. I can only talk my kids into it for so long lol
  11. Jul 28, 2016 at 7:24 AM
    #1711
    CliffordBRD
    CliffordBRD Well-Known Member
    Cliff
    Tampa, FL
    09 DCLB 4x4 Pyrite Mica
    I know this is old and all that jazz, but I am still having trouble wrapping my head around this whole tension issue.
    I still haven't ordered the motor/track from the Ridgeline, but I'm going to today.
    When it comes in, I'm going to mount it under the rear panels on the passenger side. I will cut 5" off of it to match the 12" track width of the Tacoma slide.
    Couple questions hopefully someone can help out with:
    How do I apply tension and keep it to the motor so I can have as little tension possible when installing the pull-pull bracket-I saw zip ties, but how do they apply tension?
    How do the bicycle cable adjusters play into all this because they seem to be the better route instead of moving a bracket and keep drilling into the window wall?
    Which are the best/better type of cable adjusters to use?
    I've got my pull-pull bracket made so just need to get the other bits and pieces and I can look forward to actually opening my rear window!
  12. Aug 14, 2016 at 6:05 PM
    #1712
    kashtyaatsi
    Asher
    Bitterroot, MT
    LPC's
    Broken
    Now that the 2017 has a power window think we'll be seeing some kits come out?
    jmaack and Bentrodder like this.
  13. Aug 17, 2016 at 4:06 PM
    #1713
    Acka
    Acka Well-Known Member
    Andy
    Longmont, CO
    '10 DCSB TRD Sport
    The motor has strong springs at each cable exit from the motor housing. These springs supply the system tension unless enough slack is reached to where the springs have extended to their natural length. The zip ties you saw in some pictures are just to hold the springs compressed during installation, then they are snipped off and the springs pop back into supplying tension. The bicycle cable adjusters cannot take the place of the springs, they only make assembly easier. This is because ideally you want the springs starting off almost completely compressed. To assemble a system with zero slack is almost impossible. With the bike adjusters you can assemble the system with the springs compressed, but don't have to stress about them relaxing slightly as soon as you finish the install - as you can re-compress them by extending the bike adjusters to a point where the spring is near fully compressed again.
  14. Aug 17, 2016 at 4:11 PM
    #1714
    jmaack
    jmaack Well-Known Member
    Justin
    Helena Alabama
    Skewped hood silver 4runner
    Ome, Sqeak free dakars, arms, skids, sliders.
    Wiring is the easy part as long as the window isn't crazy expensive.
  15. Aug 17, 2016 at 5:39 PM
    #1715
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    As Acka noted, the zip ties are there purely to hold the springs compressed until you finish the installation. Get long zip ties, like 12"ers. I used one to go around the cable just tight enough to act as a shim that pushes the spring down and another zip tie to go through the one around the cable to the back of the motor assy. I happened to use a regulator/motor from a 2010 Ram but the concept is the same. Paint the bracket black so it isn't as noticeable in the window. I also used 3M black super weatherstrip adhesive to glue the bracket to the window because the bracket will lift slightly when the window hits the stops. Good luck - you'll really like being able to actually use the window.
    DistortedAxis likes this.
  16. Jan 23, 2017 at 5:10 PM
    #1716
    seoulja99
    seoulja99 Well-Known Member
    E.J.
    Oahu
    2012 DCSB 4x4 V6 TX Baja (1GR-FE)
    all things mall rated
    wish someone would sell this kit.
    Charles135, Norton and kgarrett11 like this.
  17. Jan 23, 2017 at 5:50 PM
    #1717
    kashtyaatsi
    Asher
    Bitterroot, MT
    LPC's
    Broken
    Was hoping someone would come out with a new kit considering the 17's come with one.
    seoulja99[QUOTED] and Norton like this.
  18. Jan 23, 2017 at 6:41 PM
    #1718
    kgarrett11
    kgarrett11 Master Yoda
    Garrett
    CA desert
    2015 DCLB
    Amen!
  19. Jan 24, 2017 at 7:51 AM
    #1719
    kickasssloth
    kickasssloth The Texan from Australia
    Jesse
    Dallas
    06 Silver DCLB TRD Sport
    Give me a week.
    Going to see if its possible to small scale manufacture the brackets required.... Can't be that hard. The motor and wiring are easy, its just mounting it all together to the window that is hard, but with the right part could be easy... I think.
  20. Jan 24, 2017 at 8:25 AM
    #1720
    gibby11
    gibby11 Well-Known Member
    Andrew
    Las Vegas, NV
    2nd gens are better, change my mind.
    I'm in for one if this turns out
    kickasssloth[QUOTED] likes this.
