BenWA's version of a power sliding rear window retrofit >>>
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BenWA, Jun 24, 2011.
  1. Jun 30, 2011 at 9:57 PM
    BenWA
    BenWA [OP] Well-Known Member
    Boston burbs
    '06 Double Cab TRD Off Road 4X4
    Whether stock or modded, the first thing that will break is the glass, so it's equally vulnerable compared to stock. There is no way to force the regulator/trolly assembly to move, so the glass is the weakest link.
    As I wrote in my OP, the glue joint failed on my original version with the plastic piece, so I came up with the aluminum bracket idea which works great. With the seatbacks locked in their upright position, you can't see any of the "business".
    p.s., thanks for the good words! :)
  2. Jul 1, 2011 at 10:41 AM
    BenWA
    Boston burbs
    bump for updates
  3. Jul 1, 2011 at 11:15 AM
    horwitzs
    horwitzs Well-Known Member
    Seth
    Dayton, WA
    TX Pro
    Supercharger, OME lift w/ LR UCAs, running boards, toolbox, extinguisher mount, skidplate, N-Fab light bar, 40" R.I. LED bar, WO seat covers, TRD intake, Weathertech mats and visors, stubby antenna, hood struts, LED interior lighting, Hella Supertones, and other stuff I'm forgetting.
    Maybe I missed it while scanning through the OP, but did you have to do anything to the latch, so it would release when pulling open? Or does it unclip itself when the glass starts sliding?
  4. Jul 1, 2011 at 11:25 AM
    BenWA
    Boston burbs
    Good call, I forgot to mention that. Kind of hard to explain, but I mounted that aluminum bracket that snaps onto the window glass in such a way that the trolly is at the end of its travel in the closed position before the latch clips. In other words, I opened the window pane about 1/16" when I fine-adjusted the mounting position of the aluminum bracket -- so when the trolly is at the end of it's travel, the window ends up being just shy of fully closed. It's still completely sealed by the weather stripping and everything, it just doesn't quite make it to the latched position.
    I have been trying to think of a way to remove the latch from the glass altogether (simply for a cleaner look), but I don't think it's possible.
  5. Jul 1, 2011 at 11:54 PM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    Am I seeing daylight on the bottom in a couple of the last photos?
  6. Jul 2, 2011 at 2:37 AM
    BenWA
    Boston burbs
    Yeah... I could have mounted that bracket a little lower but didn't want to let it get too close to potenially rubbing/riding on the window frame when it actuates, because there is already enough inherent friction in the window as it is. I didn't see it as a big deal but if it bothers you I think you could definitely mount a similar bracket lower so that there is no daylight. My personal feeling is that it's all hidden behind the seat anyway so who really cares what it looks like, but YMMV.
  7. Jul 2, 2011 at 2:40 PM
    BenWA
    Boston burbs
    Here's a vid of the window with the seatback folded down so you can get an idea of what it looks like:
    http://www.youtube.com/watch?v=kzMPcvDu2jE
    TacomaTakeover2k11 likes this.
  8. Jul 2, 2011 at 2:48 PM
    brian
    Elizabeth City, NC
    I'm not gonna dog on ya, you did a great job and I really like it, but I can't have any openings like that, my alma mater is the one of the rainest towns in the nation. Don't need water gettin in!
    Too bad I'm not still up in Astoria, I would have gladly come see it in person.
  9. Jul 2, 2011 at 7:11 PM
    scollins
    scollins Well-Known Member
    Scott
    Renton WA
    2019 Ford F450 STX 6.7L Powerstroke
    Very nice!!! So, how much installed? I'm local!
    :D
  10. Jul 2, 2011 at 7:46 PM
    Tacoyota
    Tacoyota senile member
    North of Cali, South of Canada
    08 4wd
    4.56 gears, rear trutrac,DT header, 235/85r16 Duratracs, 2nd filter pulled, inter.wipers, Cruise control, Factory alum. whls/winter tires(2nd set), Afe pro Dry-S , Dumbo eared flaps cut down.
    I say well done , mod of the year so far. In my reg cab I dont even have to look to open it one handed. Coming from a crew cab chev though, i can easily see the value fo the mod.
  11. Jul 2, 2011 at 8:09 PM
    kd8awe
    kd8awe Well-Known Member
    Rocky
    Ohio
    4x4 TRD Off Road
    Fog mod, 3" lift, ShoMe stobes, MicroLight LED Strobes, HiLift Jack, RCI 2950, Yaesu 8900r, 20% Tint, ScanGauge II, Weathertech Side Window Deflectors, *** New Mod's (parts on the way) *** U-Bolt flip kit. Tom Woods 1 Piece Double Cardan Drive Shaft. 3* Axel Shims
    I like it.
  12. Jul 3, 2011 at 9:45 AM
    BenWA
    Boston burbs
    Wait....what do u mean?? There's no actual opening or risk of leaking. Everything closes such that it is sealed.
  13. Jul 3, 2011 at 9:55 AM
    BenWA
    Boston burbs
    Hey if u can get all the parts and a half rack of dos equip id help you with install :)
  14. Jul 3, 2011 at 10:01 AM
    TacoDawgfan
    TacoDawgfan Hunker Down You Hairy Dawg!
    Georgia
    2011 Silver 4x4 TRD Sport w/JBL
    5100's at 1.75, Rear leaf TSB, Moto Metal 951 16x8, BFG TKO2 265/75/16, AFe Stage 2 CAI w/pro dry filter, Kenwood DDX374BT installed with Idatalink Maestro kit, Access Loredo tonneau cover, N-Fab steps, Tinted windows, EGR in channel vent visors, UGA drink coasters in the front cup holders, and a Graco car seat in the back seat
  15. Jul 3, 2011 at 10:16 AM
    #35
    paintdiddy
    paintdiddy Machine gun shits
    shithead
    nj and not from "the jersey shore"
    silver bullet
    I dig everything except the gap on bottom of glass.this thread should be a sticky
  16. Jul 3, 2011 at 10:38 AM
    #36
    jedrovsky
    jedrovsky say NO to BRO!
    San Diego, CA
    07 PreRunner
    DIY stuff
    this is one great work..its true...not all of us have 6ft arms!! I say STICKY :)
  17. Jul 3, 2011 at 3:39 PM
    #37
    BenWA
    Boston burbs
    Yeah, that gap could easily be eliminated by mounting the bracket a little lower. Would be a no brainer to tweak that aspect of it.
  18. Jul 5, 2011 at 9:38 AM
    #38
    BenWA
    Boston burbs
    So, after talking to a couple of folks via pm's and e-mails, and with reading a couple of the posts here, I think I need to clarify some confusion about the daylight at the bottom of the window:
    THERE ARE NO ACTUAL GAPS IN THE GLASS OR WEATHER STRIPPING AROUND THE WINDOW AND THERE IS NO RISK OF WATER LEAKING IN.
    Watch the second video carefully. That "daylight" under the bracket is NOT an actual opening to the outside that weather can come through. I did nothing to change the size of the glass, or the size of the window opening, or to the position of how the glass sits within the opening.
    If you don't like the cosmetics of the daylight between the bracket and the window frame, you could easily mount the bracket lower on the window glass so that there is no cosmetic gap.
    Sorry for any confusion.
  19. Jul 13, 2011 at 10:40 PM
    #39
    BenWA
    Boston burbs
  20. Jul 14, 2011 at 6:40 AM
    #40
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
