Best 0W-20
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 23DinJarin, Dec 21, 2023.
  1. Dec 27, 2023 at 4:51 PM
    #161
    C0ma
    C0ma Well-Known Member
    Next time I visit my doctor, I'm going to tell him to stop drawing my blood samples and analyzing it for potential health problems. There's more that goes on in a body than scanning of liquid a beaker in a lab...
    You should tell me how any of these professionals arrived at their conclusions. You'll be surprised that they did so by analyzing the oil for wear and stability. The naked eye cannot spot issues in an engine, but apparently your eyes can because "it looked brand new inside".
    "Doctor, there's nothing wrong with me. I look and feel great!"
  2. Dec 27, 2023 at 4:56 PM
    #162
    C0ma
    If you guys will notice in the owner's manual, the crappiest driving habits can still get you to 5K miles, especially with today's oils and oil filters. If you don't find yourself practicing these bad habits continuously, e.g. extensive idling, busy city traffic, dusty roads, 10K miles is perfectly fine.
    The reason you change oil at all is because contaminant levels are reaching their threshold and/or the oil is losing stability. In either case, not changing the oil will result in significant engine wear. You will not know the exact status of the oil unless you get it analyzed.
    Engine oil education: https://bobistheoilguy.com/forums/
  3. Dec 27, 2023 at 5:01 PM
    #163
    golfindia
    golfindia Well-Known Member
    Yes.
    pickup truck
    YouTube.
  4. Dec 27, 2023 at 5:08 PM
    #164
    TacoTuesday1
    SD CA
    by looking in the engine
    exactly. There's a lot of stuff bloodwork doesn't reveal.
    your eyes can see staining, varnish, sludge, abnormal wear, premature component failure due to poor lubrication, etc.
    timing chain wear is directly related to OCI practices for example. Or piston rings clogging resulting in oil consumption and bore scratching.
    if you care about your engine you can even add WMI and use water to clean the combustion chamber to prevent carbon buildup and hot spots.
    sig says '20 6" lift 18" fuel wheels 33"
    checks out
  5. Dec 27, 2023 at 5:16 PM
    #165
    Barsoom
    Barsoom Well-Known Member
    NW GA OTP
    Add Lubro-Moly's Oil Saver to your next oil change. Best seal conditioner.
    For stuck piston rings, look up the MMO piston soak (marvel's mystery oil)
    Dark_Taco[QUOTED] likes this.
  6. Dec 27, 2023 at 5:20 PM
    #166
    TacoTuesday1
    SD CA
    I wonder if it does the same to just simply put some MMO into the oil.
    Have done an MMO piston soak on another car, it's kind of a PITA.
    Remove plugs. Disable fueling. Pour in some MMO. Let soak. Vacuum out. Put towels and crank (fuel disabled) to get MMO back out of there to prevent hydrolock
    reassemble, start (smoke)
    vs. just put some in oil
    BG also has an additive, MOA
    Barsoom[QUOTED] likes this.
  7. Dec 27, 2023 at 5:23 PM
    #167
    Barsoom
    NW GA OTP
    Mmo thins out the oil. Go up a grade if you add it to oil.
  8. Dec 27, 2023 at 5:40 PM
    #168
    DavidSmothers
    DavidSmothers Well-Known Member
    David
    Olive Branch MS
    2021 Tacoma TRD SPORT
    Go to YouTube there are dozens and dozens of guys that do tests.
    You can watch them do the tests and see how they come to their conclusions but the good testers all start with lab analysis, then do multiple tests from there.
    Bobs The Oil Guy
    The Motor Oil Geek
    Project Farm
    On The Work Bench
    These guys go way beyond just reading a spec sheet they test them head to head.
    There are tests of dozens of oils testing down to one final winner.
    A lot of oils that people “think” are great are actually not that good.
    Liquimolly was mediocre?
    But some Amazon and Walmart oil tested out very well.
    Redline has an Over the Top additive package but didn’t test that well.
    Watch some of the tests and draw your own conclusions.
  9. Dec 27, 2023 at 5:49 PM
    #169
    CLVol1255
    CLVol1255 Well-Known Member
    Tennessee
    2017 TRD Sport DCSB
    Bilstein 8112/8100 ICON RXT Stage 2 JBA UCAs Archive Garage HH w Shackles Archive Garage U Bolt Flip kit Nitto Ridge Grapplers 255/80/R17 TRD Front Skid and RCI Transmission Skid Kenwood DMX 1057XR Head Unit Focal Utopia WM 3 way plus WM10 Sub Mosconi 5/30 and Genesis Dual Mono Amp
    Here is what I’ve ran and my favorite from top to bottom. I recently changed to 0w30
    1st Amsoil Signsture Series
    2nd Pennzoil Ultra Platinum/Valvoline Extended Performance
    3rd Valvoline Advanced Synthetic
    4th Mobil One
  10. Dec 27, 2023 at 6:26 PM
    #170
    Dark_Taco
    Dark_Taco Well-Known Member
    2023 TRD Pro
    Stock
    The 2az-fe engines are known to burn oil. Has to do with bad piston rings. Mine did not start to burn oil until after the warranty timeframe. Had it started burning earlier Toyota would have replaced the piston rings under warranty. So yes I now use Supertech in that engine.
  11. Dec 28, 2023 at 5:59 AM
    #171
    22Coma6MT
    22Coma6MT Well-Known Member
    2022 TRD Sport AC 6MT
    surprised no one ever mentions napa brand oil or schaeffer's. napa is easy to get, although i am not sure of the price. schaeffer's has been around since 1839, they say, but not cheap.
  12. Dec 28, 2023 at 6:23 AM
    #172
    smikski
    smikski Well-Known Member
    2016 4x4 2.7 - 3 pedals
    skid plates , leer cap , thule roof rack , tires 1 size up
    Lets start this thread up again tomorrow in DETAIL , so this gentleman get a good idea of what kind of oil to use
    TacoSR523 likes this.
  13. Dec 28, 2023 at 7:42 AM
    #173
    BillyE
    BillyE Well-Known Member
    Ok. I’ve seen some but never any that were that interesting. Most of the ones I’ve seen fall into two categories. First, some kind of scar test that really doesn’t simulate an engine environment very well. Usually the more viscous oil will win here. The other is a basic pour test at one low temperature. Doesn’t tell you much that you couldn’t infer from the PDS. None of these tests that I’ve seen test anything other than virgin oil. I don’t put much into these tests. If anyone is doing any real engine tests, I’d be interested. I haven’t seen any.
    Barsoom likes this.
  14. Jan 8, 2024 at 9:37 AM
    #174
    Barsoom
    NW GA OTP
  15. Jan 8, 2024 at 11:44 AM
    #175
    BillyE
    That's really good. I got a similar Castrol oil when it dipped to $25/5qt recently:
    https://www.amazon.com/gp/product/B084TCS8FC
  16. Jan 8, 2024 at 11:52 AM
    #176
    Barsoom
    NW GA OTP
    BillyE[QUOTED] likes this.
  17. Jan 8, 2024 at 12:03 PM
    #177
    ace_10
    ace_10 Well-Known Member
    Rural NoVA
    1st Gen, Best Gen X2
  18. Jan 8, 2024 at 12:29 PM
    #178
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    I have 150 quarts of Schlitz Malt Liquor in my garage.
    e_engstro, Barsoom, BillyE and 2 others like this.
  19. Jan 8, 2024 at 12:51 PM
    #179
    Barsoom
    NW GA OTP
    Pic of your house?
    Squirt likes this.
  20. Jan 8, 2024 at 1:10 PM
    #180
    4for1
    4for1 Well-Known Member
    I just ordered and received Amsoil Synthetic OE, truck has Signature Series in it now. My justification is I always aim to change at no more than 5k miles so, IMO, I dont see the need for Signature + I kinda enjoy wrenching on the truck anyhow. Curious to know why you use Amsoil Signature rather than Amsoil OE Synthetic ?
