Best 1st gen mods?
Discussion in '1st Gen. Tacomas (1995-2004)' started by 01stgentaco, Jul 9, 2024.
  1. Jul 9, 2024 at 10:04 PM
    01stgentaco
    01stgentaco [OP] Deacon
    Deacon
    Looking to start a prerunner build on an 01, toss some ideas out there !
    (how shes currently sitting)IMG_7473.jpg[​IMG]
    SecureIT2021 likes this.
  2. Jul 9, 2024 at 10:48 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    New lower ball joints
  3. Jul 9, 2024 at 11:01 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    Basic maintenance is the best mod to do first with a new truck for sure.
  4. Jul 10, 2024 at 12:28 AM
    chango
    chango Well-Known Member
    Nu’uanu, Hawai’i
    2023 SR5 4x4 & 2001 SR5 TRD 4x4
    OEM ball joints or are there better more reliable aftermarket ones?
  5. Jul 10, 2024 at 12:48 AM
    ChargedSHOTaco
    ChargedSHOTaco Well-Known Member
    4WD Conversion.
    nate27, otis24, mlcc and 1 other person like this.
  6. Jul 10, 2024 at 6:47 AM
    The gold standard
    The gold standard Well-Known Member
    Western mass
    Green 03 v6
    Oem
  7. Jul 10, 2024 at 7:01 AM
    jrallan26
    jrallan26 Well-Known Member
    Iowa
    2004 White D-Cab TRD
    Spray on bed liner and Corolla steering wheel.
    Dalandser likes this.
  8. Jul 10, 2024 at 8:10 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    https://www.tacomaworld.com/threads/lower-ball-joints-brand.341767/
    If you’re talking about building an actual prerunner OP and not just a truck that is a prerunner in name, then 2wd will save a lot of money and work just fine.
    Check this out.
    https://www.tacomaworld.com/threads/1st-gen-long-travel-discussions.750980/
    Don’t waste your money on things like fiberglass, focus first on a quality front LT kit or at least quality front shocks and a spring under kit / parts from Deaver and source various parts from Total Chaos etc. But start with new lower ball joints for sure.
  9. Jul 10, 2024 at 9:14 AM
    Red_03Taco
    Red_03Taco Well-Known Member
    Jerad
    2003 Tacoma Xtra Cab 4WD
  10. Jul 10, 2024 at 12:46 PM
    Parkvisitor
    Parkvisitor Do you know midnight?
    Juan
    So Cal
    It’s a truck
    stuff
    Tundra front brakes
  11. Jul 10, 2024 at 2:01 PM
    FixMyTaco
    FixMyTaco Well-Known Member
    Lee
    Alaska
    96 ext cab 4wd mt 3rz 400k mi.
    Rebuilding seats with leather from furniture and extra padding. Might put leather on the dash and other interior parts.
    I put sound deadening stick-on stuff in my doors. Clean and lube inside door. Added pop rivets to tabs on window guide channel where spot-welded.
    01stgentaco[OP] likes this.
  12. Jul 10, 2024 at 5:06 PM
    LanceRN
    LanceRN Well-Known Member
    Lance
    1998 Purple Tacoma TRD
    Delete the LPSV.
    Good seats.
    Under body armor.
    Really good suspension.
  13. Jul 10, 2024 at 5:12 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    This is my friend's truck where he only tied the rod from the LSPV up to its highest point with safety wire and cut it off at like 3" and the truck brakes fine and performs great. That said there's no one way to do it (for instance I'm remaking all braided and hard lines so I'll be using a manual proportioning valve in that regard). Prioritize suspension imo
    https://www.tacomaworld.com/threads/anthonys-99-tacoma.175933/
  14. Jul 10, 2024 at 6:45 PM
    02hilux
    Planet: EARTH
  15. Jul 10, 2024 at 8:17 PM
    Nano909
    Nano909 Stirrer Of Pots
    Xcab 3.4 4wd 5MT
    FYI maintenance is not a mod.
    4wd swap, front/rear lockers > everything else
  16. Jul 10, 2024 at 8:19 PM
    Nano909
    Xcab 3.4 4wd 5MT
    The Total Chaos uniball conversion kit is a lot stronger.
    chango[QUOTED] likes this.
  17. Jul 10, 2024 at 8:40 PM
    02hilux
    Planet: EARTH
    IFS elimination is strongest :anonymous:
    Nano909[QUOTED] likes this.
  18. Jul 10, 2024 at 8:45 PM
    Nano909
    Xcab 3.4 4wd 5MT
    Strongest on your wallet too :spending:
  19. Jul 10, 2024 at 8:51 PM
    ChargedSHOTaco
    :rofl:
  20. Jul 10, 2024 at 9:10 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    If he wants to build a prerunner you are really not helping... poor guy's going to not know what to do and end up burning his truck to the ground when he puts the wrong windshield wipers on his truck at Oreilly's.
    @01stgentaco are you trying to build a desert prerunner or you just want to build a truck that is a Tacoma Prerunner for general offroading - it can be confusing if you're not 100% clarifying what you're building here. People will misinterpret and it won't help you.
    Madjik_Man likes this.
