Best 2"-2.5" Lift Kit
Discussion in '2nd Gen. Tacomas (2005-2015)' started by sull625, Aug 29, 2015.
  1. Aug 29, 2015 at 7:03 PM
    sull625
    sull625 [OP] Well-Known Member
    Dave
    Montana
    12 TRDOR DC Spruce Mica
    I am looking for a 2"-2.5" lift kit. I also want the truck to sit level. I believe the TRD Baja suspension (Bilstien 5100s with the rear reservoir shocks) may achieve this, is that correct?
    I don't want to go higher than that. Any help is appreciated.
    ChadsPride likes this.
  2. Aug 29, 2015 at 9:16 PM
    Flannel_Lover
    Flannel_Lover Your resident questionable advice giver
    Lucas
    Greenville, IN
    2011 sclb base 4x4
    Alpine component speakers Rockford Fosgate 10" sub Pioneer DEH-X6800BT Kicker CX 300W amp Extang Trifecta Big Country Brush Guard
    just get a set of 5100's and a rear AAL
    Kolter45 and ChadsPride like this.
  3. Aug 29, 2015 at 11:28 PM
    derickt
    derickt Active Member
    Derick
    Los Angeles
    Same here. Wanted 2.5" lift with no rear sag. Went with Bilstein 6112's front, 5100's rear, Wheelers 1.5" AAL, and overload springs left in.
    FJ to Taco and ChadsPride like this.
  4. Aug 29, 2015 at 11:36 PM
    tommyhd03
    tommyhd03 Well-Known Member
    tommy
    spartanburg
    Sport Tacoma double cab long bed
    885 coils, blistein 5100 front and rear, 1 1/2 AAL. SCSI sr8 wheels, 285/70/17 cooper discover at3 tires.
    bilstein 5100 with 885 coils and 1 1/2 aal in the rear for me
    QMEDJoe, Kolter45 and Joshthebarber like this.
  5. Aug 30, 2015 at 2:56 AM
    sull625
    Dave
    Montana
    Nice looking trucks. I found the 2.5" kit from Bilstienlifts.com its out of stock as we speak but ill keep my eye on it.
  6. Aug 30, 2015 at 3:27 AM
    Jeffvt0508
    Jeffvt0508 Well-Known Member
    Jeff
    Anderson, SC
    2015 DCSB 4x4 trd offroad
    Ome 887s, dakars, lr uca,sliders, konig countersteer,
    Check vendors on here.. toytec .headstrong off road.. and wheelers off road.. price check them all..
    blairrad and Kyitty like this.
  7. Aug 30, 2015 at 3:29 AM
    sull625
    Dave
    Montana
    I'll do that, thank you!
  8. Aug 30, 2015 at 5:05 AM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Define "best." Also, knowing your budget would help.
    2WD and ChadsPride like this.
  9. Aug 30, 2015 at 7:21 AM
    TACOVRD
    TACOVRD I Identify As A Prius
    TW Addict
    AZ/WA
    2019 T4R ORP - Formerly 2013 DCSB OR Spruce Mica
    Workin' on it....
    Tag to follow
  10. Aug 30, 2015 at 7:29 AM
    Josh828
    Josh828 Well-Known Member
    Josh
    Avery NC
    14 White TRD Off road, Mid travel mountain truck
    FOX 2.5 extended travel, Fox 2.0 rears, LR UCA, XSPX rims, some light bars, and switches
    "Best" would be something like KING, ICON, FOX ect.... best lift on a budget...
  11. Aug 30, 2015 at 7:37 AM
    El Tano
    El Tano i am the one who knocks
    Pasadena. CA
    10 Tacoma TRD sport
    Corvette homelink FRONT: 5100 Blinstein set at 0 Procomp 3" leveling kit Allpro UCA’s. REAR: Icon Multi Rate RXT Leaf Pack 5100 Blinstein. 17x9 kMC wheels 0 BS 285/70 17 Wildpeak A/T4W C range Amp research steps. and a bunch of TSB's
    Do not use the 5100's on the highest setting, you will get 2.5 but the ride is very harsh, it really rides like a pogo stick.
    Justinlhc, FJ to Taco and Jeffvt0508 like this.
  12. Aug 30, 2015 at 10:34 AM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    It will level the truck yes, but no it does not use 5100s. The Baja TX Pro suspension uses costom TRD tuned versions of Bilstein 6112 and 5165s, which are a significant upgrade from 5100s. It also runs a stiffer 650lb spring than is often run 5100s, though obviously you can get any spring you want.
    I dislike level because if you load the bed you get rear squat/nose high. So I also added a 3 leaf progressive 1.5" AAL on mine, which I think pairs well with the stiffer front coils.
    5100s are popular because of their pricepoint and they get the job done, however I don't think anyone would refer to them as best. Going much over 2" and you will be approaching the max UCA alignment limits, which may require spending $400+ on aftermarket UCAs. It all really depends on your budget
    lo2hi and Tacotj like this.
  13. Aug 30, 2015 at 1:45 PM
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    2015 Tacoma DCLB Better Than TRD
    See Build Page
    No such thing as "Best". Everything has it's pros and cons. It's all about your budget and desired use.
    3" OME Lift (887 Coils & Full Dakar rear leaf pack)
    Using 885's as recommended by OME would provide around 2.5" lift with no extra weight (skids, steel bumper, winch, etc)
    Look through a few forum threads. This question is asked several times a week. :)
    ChadsPride and ManBeast like this.
  14. Aug 30, 2015 at 2:02 PM
    Bluegrass Taco
    Bluegrass Taco Politically incorrect low tech redneck
    Bill
    Mt Washington Ky
    2011 DCSB, TRD OR, 5100's, 885's 285/75r16 Cooper STT PROs.
    Define "best" as it applies to your individual needs. There is a reason why there are dozens upon dozens of "kits" on the market. What fills my needs may not work at all for you, and vice versa....
  15. Mar 10, 2016 at 11:09 AM
    ensaladas
    ensaladas DarthT8er
    ‘23 Trail Edition
    what setting are you 6112s on? Looks great
  16. Dec 20, 2016 at 2:07 PM
    MurderedTacoV2
    MurderedTacoV2 Booty Admirer
    Adam
    Hudson, New Hampshire
    06 Taco TRD OR
    3 inch lift, B110’s, Dakars, Dirty5’s, Dual Locked
    Headstrong is the best strong, good prices and free shipping. Just do it man put together your own lift package thats what im doing.
  17. Dec 20, 2016 at 2:25 PM
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 Super White S/C DCLB TRD SPORT
    Bilstein 5100 all around, fronts set at 2.5" on stock TRD SPORT coils and TOYTEC AAL in the rear.
    rob86miller, Kolter45, NateDB and 2 others like this.
  18. Dec 20, 2016 at 2:27 PM
    TegoTaco
    Ontario, Canada
    Wrong, mine rides a little stiffer than stock. Not rough or harsh at all.
  19. Dec 20, 2016 at 2:28 PM
    TegoTaco
    Ontario, Canada
    How much did you pay?
  20. Dec 20, 2016 at 4:13 PM
    Big Sky Country
    Big Sky Country Well-Known Member
    Montana
    2013 DCSB TX Pro
    Century topper, OME 885x, Nitrochargers, full Dakars
    2012Tacoman, Kolter45 and FJ to Taco like this.
