Best $2000 off-road upgrades.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by perfect_disturbance, Jan 11, 2021.
  1. Jan 11, 2021 at 9:57 AM
    RyanDCLB
    RyanDCLB Well-Known Member
    4/19 DCLBOR
  2. Jan 11, 2021 at 9:58 AM
    perfect_disturbance
    perfect_disturbance [OP] Member
    For sliders something to protect the rocker or something I could jack off of would be nice.
    ghostleaf likes this.
  3. Jan 11, 2021 at 10:09 AM
    LivinOnEdge
    LivinOnEdge ¯\_(ツ)_/¯
    Land of The Lost
    Four wheels and a refrigerator
    o_O
    You may want to look into bolt on sliders with a kick out. You can pull them off when you want to and they can double as a good decent bed step.
    ghostleaf, IndyTac and Tacoma091919 like this.
  4. Jan 11, 2021 at 10:12 AM
    perfect_disturbance
    Do you have a model you recommend?
  5. Jan 11, 2021 at 10:13 AM
    LivinOnEdge
    Land of The Lost
    Unfortunately I don't. I used OEM predators since my wife likes having a step to get in. Plus the only rocks I see are in the parking lot of BuyBuy Baby right now.
    Malvolio and tclavell like this.
  6. Jan 11, 2021 at 10:17 AM
    yoopersteeze
    yoopersteeze Fake it til you make it
    WI
    2017 Magnetic Gray Metallic Tacoma TRD OR MT
    Armor. Armor. Armor.
  7. Jan 11, 2021 at 10:19 AM
    perfect_disturbance
    I love the suggestions sorry for being picky. But I'm super new to this so specific models or even links would be really appreciated.
  8. Jan 11, 2021 at 10:20 AM
    yoopersteeze
    WI
    I do not have said body armor, but know people who have actual ¼" skids. Buy local if you can.
    Dirk Diggler likes this.
  9. Jan 11, 2021 at 10:23 AM
    WrecklessAbandon
    WrecklessAbandon They call me skippy
    Travis
    Olympia, WA
    Crocs with socks
  10. Jan 11, 2021 at 10:23 AM
    MattCowsmasher
    MattCowsmasher ( -_・)ᡕᠵ᠊ᡃ່࡚ࠢ࠘⸝່ࠡࠣ᠊߯᠆ࠣ࠘ᡁࠣ࠘᠊᠊ࠢ࠘
    Temple, Tx
    O3 Rubicon wrangler
    Check out sos concepts for they make great stuff for more budget friendly check out 4xinnovations for armor
  11. Jan 11, 2021 at 10:36 AM
    RyanDCLB
    4/19 DCLBOR
    Get in on the RCI group buy over here for full skid package and sliders. While you're waiting, do the exhaust reroute as seen here. You can wear down your old tires and beat on your shocks a bit more, but after installing the skid package and sliders you'll be ready for some coilovers struts and new tires. Coilovers will bring your truck back to stock ride height plus some lift/leveling, and new 255 tires will give you more ground clearance. Remove the swaybar, and you're off to the Rubicon! :mudding:
    sdpnoy, ghostleaf and nmatcek like this.
  12. Jan 11, 2021 at 11:39 AM
    CT Yankee
    CT Yankee Well-Known Member
    CT
    2021 TRD OR AC AT MGM
    Only aesthetic mods so far Leer 180 cap & Clazzio covers on order.
    Since you don't want to "impact the function of safety sense etc" this suggests you're asking about your daily driver.
    As you can see thus far, you'll be getting dozens of suggestions.
    But not knowing what type of "general off-road" driving you expect to do will make many of those suggestions either useless or just another way to throw away your $$$.
    Perhaps if you offered more info on what you're looking to do, you might get "specific" relevant ideas.
  13. Jan 11, 2021 at 11:43 AM
    79CHKCHK
    79CHKCHK Padawan of Rock Lobster
    SoCal no mo
    2018 Super White TRD Pro AT
    What kind of wheeling are you going to do and where? Your truck is fairly capable as is...use it and figure out what you need most, otherwise you may end up doing it again. This applies to a lot of things, but I feel with suspension this is especially true.
    I started with recovery gear (tire deflators, tire repair kit, compressor, recovery strap, recovery boards etc.) and moved to storage solutions (Decked drawers, ARE canopy), and then lighting/power solutions (ditch lights, side lights on canopy, hidden front bumper light, power outlet in cap) with a RTMR for future upgradeability. Finally added full aluminum skids this past November because I want to start pushing more remote for longer amounts of time, but didn't want the weight of steel. I've lost about 1/3-1/2 inch in ride height, but I have my setup where I want it. Now its time to tweak the suspension and tires to create a little more ground clearance while increasing the constant load carrying capacity and control.
    I'd recommend quality tire deflators, repair kit, compressor, recovery boards and strap to start. Dropping tire pressure will not only increase the ride quality off road, but also your traction. Compressor to re-inflate, and the rest to get you out of a jam. I generally travel solo and traction boards are a must have! Here are links to the recovery gear I use, add an axe and shovel and you'll be set:
    Tire Deflators
    Viair Compressor (I tow an off road trailer on 35s, this is overkill with stock tires and no trailer, but its also my most used piece of gear)
    Tire Repair Kit
    Recovery Boards (x2 for a total of 4 boards)
    Recovery Strap
    edit: This is around $700, but cheaper options are out there. Leaves you $1300 for other upgrades.
  14. Jan 11, 2021 at 12:29 PM
    mattleegee
    mattleegee Well-Known Member
    Tacoma, WA
    2020 TRD PRO 6sp
    here are metal tech sliders
    there are many similar sliders in the same price range, most have lead times so get one ordered ASAP
    I would suggest with $2000
    Tires
    Sliders
    hi lift jack
    Strap
    recovery boards
    air compressor
  15. Jan 11, 2021 at 12:29 PM
    #35
    perfect_disturbance
    Sure, I have another car a mini-van but I use this Tacoma along with that for daily driving. I enjoy a variety of outdoor activities and will also be using the Tacoma to get to fairly remote places for Hiking, Climbing, Fishing etc. I haven't done any dedicated off-roading but am interested in doing some. My main concern is that I don't want to get way off the beaten track and then getting stuck and have to call in the cavalry.
  16. Jan 11, 2021 at 12:39 PM
    #36
    nmatcek
    nmatcek Active Member
    Sliders (pick your brand) and RCI skid plates. Then get some better tires and you should be good to go for a while. If you're really worried about getting stuck, traction boards aren't a bad option.
  17. Jan 11, 2021 at 12:56 PM
    #37
    Thunder Fist
    Thunder Fist Well-Known Member
    David
    Birmingham, AL
    2017 MGM TRD OR DCSB
    Like, so many.
    Man, the problem is that there SO MANY options and so many of them are very good that there are no universal "YOU SHOULD GET THIS" answers. You'll lose your mind looking at suspension alone. I suggest really taking some time to read through the threads on the various possible upgrades. There are detailed threads for everything you are asking about. You'll get better, more complete answers in those threads than a general thread like this. I'll just start you on tires: BFG KO2, Duratrac, Falken Wildpeak, Nitto Ridge Grappler. I've researched a lot of these upgrades and if you want, PM me and I'll talk you though my decisions. But I can almost guarantee that no one else has made all of the same choices for their truck. That's not a value judgement, just a testament to the absurd number of options!
    tkay2009, 79CHKCHK and RyanDCLB like this.
  18. Jan 11, 2021 at 1:53 PM
    #38
    CPS-65
    CPS-65 I’m good for some, but I’m not for everyone.
    Alta Loma, CA
    2019 Quicksand TRD Off Road 4X4
    Mostly old man mods
    Add a front locker. For a DD I like the Detroit Trutrac, especially on the front.
    MattCowsmasher likes this.
  19. Jan 11, 2021 at 1:53 PM
    #39
    CT Yankee
    CT
    Perhaps some off-road miles will help you to decide what you really need.
    Obviously, don't get yourself into really tight or sticky situations before you've learned what your stock truck can do.
    I've driven my stock Gen 2 TRD ORAC into some rather 'hairy' off road places with no issues.
    Dirk Diggler and 79CHKCHK like this.
  20. Jan 11, 2021 at 1:59 PM
    #40
    TacoBoutNothing
    TacoBoutNothing Well-Known Member
    2019 White TRD Pro
    I went with C rated Ridge Grapplers and have been more than impressed. I couldn’t bring myself to e rated tires on the Tacoma...so far so good.
