Best 2G Aftermarket Headlight Assy?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by inAjet, Nov 29, 2022.
  1. Nov 29, 2022 at 2:32 PM
    inAjet
    inAjet [OP] Member
    Vancouver, BC
    Silver 08 Acc Cab 4x4 SC V6
    TRD supercharger Chassis Unlimited Octane front bumper Smittybilt winch Tuff Stuff RTT
    I have a 2008 Taco, currently running Eagle Eyes black housing headlight assemblies with FCKLightBars LED lamps. Problem is, the geometry of the assembly is obviously slightly different than OEM and rubs agains my Chassis Unlimited steel bumper.
    Looking for an alternative, so just curious about your opinions on the best aftermarket headlight assembly manufacturer...
  2. Nov 29, 2022 at 2:58 PM
    BlueCollarNerd
    BlueCollarNerd Member
    Maine
    2015 TRD OR
  3. Nov 29, 2022 at 6:08 PM
    inAjet
    inAjet [OP] Member
    Vancouver, BC
    Thanks for the link! Lots going on in that thread. Are you referring to the guy that disassembled and painted the inside of his OEM headlight assemblies? Unfortunately I don't have the OEMs, so am looking for a good aftermarket option - or, if the best truly is the OEM, then paying $$$ for a replacement set. I'll be using my FCK LEDs either way, so really just looking for a recommendation on the housing/assembly. My only current issue is that the shape of my current set is causing them to rub against the bumper, which makes me think the bumper was designed around the OEM part.
    EDIT to clarify that I have no problem shelling out the $$$ for the OEMs if they really are the best option...
  4. Nov 29, 2022 at 7:01 PM
    JMcFly
    JMcFly Well-Known Member
    Central FL
    2012 Tacoma SR5 4x4
    OEM with the headlight upgrade harness and bulbs is the best. its on my list to do next
    reallifedog likes this.
  5. Nov 30, 2022 at 4:05 AM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    Yes, OEM is truly the best option if you're looking for a very well designed, engineered and manufactured housing that will both last and put maximum usable light on the ground. The Ultimate Headlight Upgrade will improve performance even more. LED bulbs are not recommended though.
  6. Nov 30, 2022 at 4:10 AM
    FishaRnekEd
    FishaRnekEd Well-Known Member
    New Orleans, LA
    2005 4.0 6spd 4x4 Dbl Cb short bed
    There are many articles about how led bulbs do not project light properly from a housing not designed for led bulbs.
  7. Nov 30, 2022 at 5:13 AM
    BlueCollarNerd
    Maine
    2015 TRD OR
    No, but since you don't have the OEM you could buy a set of the blacked-out housings if you like them better.
    Like the others said and described in crashnburn80's thread LED's are better suited for a projector style housing vs a reflective. Give that thread a good read its very informative and then decide. It really comes down to if you want looks or if you want your headlights to perform and be safe for on road use.
    Also I don't believe the LED bulbs would benefit as much from the upgraded harnesses. They draw less and don't react the same to drops or increase in voltage. I could be wrong, someone will correct me if I am hopefully.
  8. Nov 30, 2022 at 9:58 AM
    inAjet
    inAjet [OP] Member
    Vancouver, BC
    Thanks for all the replies.
    I appreciate all the tips on LED bulbs, but my issue here is not lamp efficacy; I have plenty of lighting power on my truck. My original post was for recommendations on headlight assembly/housing options - specifically to address the issue of my current assemblies rubbing on the bumper due to their shape.
    Thank you. This is good info on the OEM.
    I do like the look of the black housing better, but the look is secondary to build quality and shape being close to OEM so that they fit.
    I'm still interested in any recommendations on best aftermarket housing manufacturers based on personal experience.
    Too Stroked[QUOTED] likes this.
  9. Nov 30, 2022 at 10:41 AM
    Naveronski
    Naveronski Well-Known Member
    Fort Worth
    2014 MGM DCSB TRD:OR
    My experience is people who put LED bulbs into headlights end up blinding everyone on the road.
