Best 2nd Tacoma lift on a high school budget?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Parker4x4, Dec 20, 2019.
  1. Dec 20, 2019 at 9:25 AM
    Parker4x4
    Parker4x4 [OP] Member
    Parker
    2009 timberland mica Tacoma TRD offroad
    Hi I’m in high school and I’d absolutely love to lift my truck 1.5-3 inches. Only problem is I don’t have much money everything I makes does right into my passion of the outdoors. What lifts should I consider with my tight budget
    Hobbs likes this.
  2. Dec 20, 2019 at 9:28 AM
    Alexely999
    Alexely999 Well-Known Member
    Alex
    Bay Area, CA
    2015 DCSB 4X4
    Keep an eye out for some used 5100s, and an AAL for the rear
  3. Dec 20, 2019 at 9:29 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    5100's all around and an AAL.
    Please no blocks no spacers. If you stick with the 1.75in setting up front you can get away without the need for aftermarket UCA's
    20somethingwidataco and DrFunker like this.
  4. Dec 20, 2019 at 9:31 AM
    eccracer104
    eccracer104 O.G. Member
    San Diego, CA
    2016 Tundra 4x4
    Bilstein 5100s
  5. Dec 20, 2019 at 9:33 AM
    DaveInDenver
    DaveInDenver Not Actually in Denver
    David
    Grand Junction
    2008 Super White TRDOR AC 6MT
    Unexceptional
    I'd save your money for tires & gas. But yeah, 5100s and AAL, anything cheaper is throwing it away.
    ABNFDC, DrFunker and BuddyS like this.
  6. Dec 20, 2019 at 9:45 AM
    Parker4x4
    Parker
    Could I get anyway with only front 5100s?
  7. Dec 20, 2019 at 9:46 AM
    Hobbs
    Hobbs Anti-Lander from way back…
    Yep…
    Rock Bangen', Desert Tamin', Gold Findin' Machine!
    Welcome to The Forum Parker! :thumbsup:
    Gritto and TRDSport10 like this.
  8. Dec 20, 2019 at 9:47 AM
    eccracer104
    San Diego, CA
    2016 Tundra 4x4
    That’s what I did in high school. Front 5100s set at 2.5”
    Alignment was never quite right, she’d wander on the highway, but I liked it overall.
  9. Dec 20, 2019 at 9:54 AM
    Muddinfun
    Muddinfun Well-Known Member
    On a 10 year old Taco, it’s very likely that the alignment cams are rusted. Replacing them is a medium sized chunk of money. If you lift it even 1/2”, the alignment cams will need to be rotated.
  10. Dec 20, 2019 at 10:41 AM
    Parker4x4
    Parker
    Thanks I appreciate your help!! I’m so glad I didn’t go for rough country.
  11. Dec 20, 2019 at 10:55 AM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Are you 2wd or 4wd? If 2wd check out maxtrac spindles
  12. Dec 20, 2019 at 11:02 AM
    Green Jeans
    Green Jeans 6MT AC TRD OR 1GR-FE FTMFW
    Oregone
    '13 TRD Off-Road
    3'rd gen TRD OR take-offs. They're pretty much free.
  13. Dec 20, 2019 at 11:07 AM
    DG92071
    DG92071 Well-Known Member
    Do you take it offroad? How hard do you drive it off road? Tire size?
    I'm still trying to wrap my head around the idea that cranking up a spring's preload is called a lift kit. Sounds to me that should be called adjusting ride quality and the lift is a by product. The same goes for AAL, they change the spring's rate.
    But whatever you do - do not write about actual lift kits because they are no bueno amigo.
    Clearwater Bill likes this.
  14. Dec 20, 2019 at 11:08 AM
    WoodsGhost
    WoodsGhost Well-Known Member
    PA
    2017 DCSB OR:2016 4Runner
    Spacers are fine if you are staying on pavement/gravel roads.
    Offroad go for Bilstein 5100 and AAL.
    Id say just go with the 5100 and AAL for a good piece of mind.
    Oh and when I say AAL i recommend the 3 leaf progressive
  15. Dec 20, 2019 at 11:25 AM
    15TACOSPORT4X4
    15TACOSPORT4X4 Well-Known Member
    Stan
    2015 Black Tacoma TRD Sport 4x4
    3" lift on 33 inch Nitto's with 18" Fuel wheels. N-Fab step bars. Husky floor liners.
    I don't get why everyone is always hatin on spacers. Now if you are a serious off road guy I understand but for every day and light off road no problem. I lifted my 15 Taco 6 months after I got it brand new. I spent less than 200 bucks for spacers and AAL and lifted it 3" put 33x18's on it and it still drives great today. Yea one day I plan on upgrading but if you are tight on cash to me its the way to go. I did do the work myself as well 200 parts 20 in beer and 8 hours of my time. DONE.
    Daedae, DG92071, James710 and 2 others like this.
  16. Dec 20, 2019 at 11:39 AM
    nd4spdbh
    SoCal
    because for not much more... you can get the job done right and not have to worry about bottoming shocks before hitting bumpstops causing catastrophic failure.
    20somethingwidataco and j_sav115 like this.
  17. Dec 20, 2019 at 12:04 PM
    NOLAYota
    NOLAYota Active Member
    Tyler
    NOLA
    09 PreRunner SR5 TRD OR
    K&N Intake, OEM Roof rack, Nerf bars, 5100 Coilovers, OME Dakar Leaf Springs, All Pro Expedition rack w/ fabed bike mounts, RTT, many more planned.....
    I second 5100s with aal in the rear or beefer springs if you can afford.
    Food for thought be ready to replace other things with a lift. I put a toytec kit with 5100s on all 4 corners and dever leafs in the rear, shortly after I had to replace all my u joints, center bearing and my upper and lower control arms. I had envisioned a simple lift but with the angle changes the costs added up pretty quickly.
    When adding the lift get a center bearing drop kit or make one with shims. Had I done that from the get go I think my driveline components would have lasted longer.
    Good luck and drop us some pics once it's all done!
  18. Dec 20, 2019 at 12:43 PM
    '14RC
    '14RC WA State
    Seattle
    2014 4x4 Regular Cab 5MT
    2" Lift & 32" tires w/ Camping Setup (see details) Suspension: Dobinson 2" Coils (PN: C59-316) 4x Bilstein 5100's (base setting) SPC Upper Control Arms Deaver J66 Leaf Springs Ride-Rite Airbags Archive Garage Hammer Hangers Poly Leaf Spring Bushing Camping: SnugTop Canopy ARB awning Built a Camping Shelf in the Bed Yakima Mega Warrior Roof Basket Interior: Bucket Seat Conversion Acoustically Insulated Interior Added Cruise Control Rear Storage Organizers Traction: Yellow Wire Mod Alloy's with 265/75/16 Towing: Aftermarket Class III Tow Hitch Trailer Wiring Brake Controller (wired, not installed) Misc: ECGS Bearing NH Oil Undercoating
    Assuming you are an access cab or double-cab, I'm also going to vote the 3rd Gen take-off suspension. Most the time they go for $200 and you get front coils, 4x shocks, and leaf springs. It should give you 1" lift in front, and if you get yourself a 1" block for the rear, this is a nice little lift that you will still be able to align correctly without sacrificing drive-ability (or purchasing upper control arms.) Trust me, these trucks are really sensitive to the amount of lift you add when it comes time to do alignment. If you throw in a set of 1.25" wheel spacers front and back, you're looking at $500 max for everything, and it'll look sharp and drive nice.
    Good luck!
  19. Dec 20, 2019 at 2:36 PM
    Parker4x4
    Parker
    Thank for all the information. I am a big fisherman take it on dirt and gravel to get to spots every weekend. Nothing super serious
  20. Dec 20, 2019 at 3:03 PM
    TVH475
    TVH475 Well-Known Member
    Montrose CO
    I have my factory struts with a 1" spacer for when I need to send my 2.5s in for service, all good!
