Best 3” lift for 285s...
Discussion in 'Suspension' started by Jpiskura, Oct 14, 2018.
  1. Oct 14, 2018 at 5:17 PM
    Jpiskura
    Jpiskura [OP] Well-Known Member
    This has prob been covered a bajillion times.. but I was thinking a Fox 2.0 or 2.5 setup would be ok for my daily driver.. I don’t use it too much for off-road.. a little, Not a lot.. Just looking to stuff a set of 285 under the wheel well and have a better ride than stock.. Any suggestions, or advice?
  2. Oct 29, 2018 at 8:26 AM
    Ccrames2018
    Ccrames2018 Jack of some trades.
    Caden
    Nor Cal
    06 DCLB TRD Sport
    -Bilstein+OME suspension, ARB bumper w/Smittybuilt XRC winch, Aero exhaust, CMC, oddball size 275/70R17 General Grabber ATXs on 17x8 0 offset Pro Comp wheels, etc.
    If you don't do much off-road, I would not spend the big money for external bypass shocks. To buy a full Fox/King/Icon setup can be like $3,000 even before labor. If I were you I'd look into something like the Toytec 3 inch lifts or something comparable. Same ride height options, just a decent bit cheaper and a little less plush ride. The only thing those bypasses give you is when you're off road with high amounts of suspension travel it helps keep your shocks from overheating.
  3. Oct 29, 2018 at 12:56 PM
    Jpiskura
    Well, i would be doing labor myself and as far as being plush is concerned I would like it to be plusher than factory but still have some stiffness where it needs to be.
