Best 3" front lift/ level
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MTNROMR, Aug 27, 2014.
  1. Aug 27, 2014 at 11:55 PM
    MTNROMR
    MTNROMR [OP] Well-Known Member
    Cy
    Jackson, CA
    2014 TRD Sport DCSB 4x4
    Build thread in signature.
    I want to lift the front of my 2014 Tacoma 4x4 about 3" and have looked a numerous ways. I was going to do a ReadyLift coil spacer with sway bar drop, but I heard this is terrible. I heard that it preloads the spring and makes a stiff ride. I don't want anything to crazy. I don't want a lift that is going to rip CV boots all the time either. So what is the best way to lift just the front about 3" and can any bads come out of just a 3" lift? Thank you!
  2. Aug 28, 2014 at 12:32 AM
    Tactical Tacoma
    Tactical Tacoma Well-Known Member
    Seth
    McKinney, TX
    '12 MGM DCSB Sport 4WD
    ARB air compressor, ARB rear air locker, sPOD switch panel in sunglass holder, OME Front & rear shocks, 885x coils, Dakar leaf springs, Icon tubular UCA's, Flowmaster 40 Series Exhaust, aFe Pro Dry, TRD Sport wheels powder coated anthracite, FJ TRD center caps, Thule roof rack, 886 fog lights for reverse light mod, CSjumper LED DTRL's, Nokya Yellow fogs, plastidipped lower valence, Weathertechs, Wet Okoles. And MANY MORE MODS, READ BUILD!
    You can do billie 5100's set at 2.5 with stock coils or upgraded springs and an AAL in rear or new spring pack. It will give a decent lift but stiffer ride. Personally, I recommend an OME 3" lift, but I'm partial to them
  3. Aug 28, 2014 at 12:53 AM
    Nate87
    Nate87 Well-Known Member
    Nate
    CONUS
    2013 AC TRD OR
    Just get Kings or ICON. You'll be brrraaaping in no time. You can replace the inner cv boots with those offered by All Pro or SDHQ to mitigate tearing. Or just boot slide them till they tear then replace.
  4. Aug 28, 2014 at 1:58 AM
    OKJC
    OKJC Well-Known Member
    Justin
    NWArkansas
    '10 SC 4x4 TRD Sport
    Assuming your rear is stock, 3" in the front will probably leave you quite a bit nose high. 3" is also the general rule for when you need new UCAs to get your truck aligned properly, so that is worth considering.
    That being said, I have the ride height adjustable Bilstein 5100s with stock coils set at 1.75 and am slightly nose high, but plan on an AAL for the rear soon. This route is hard to beat if you only want a small amount of lift and are looking to achieve a good ride on a tight budget. I bought mine from Wheelers for ~$200.
  5. Aug 28, 2014 at 3:52 AM
    357sig
    357sig Donut king
    dough boy
    donut shop
    Gold digger
    Final answer! !!
  6. Aug 28, 2014 at 7:49 AM
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
  7. Aug 28, 2014 at 12:51 PM
    MTNROMR
    Cy
    Jackson, CA
  8. Aug 28, 2014 at 12:53 PM
    MTNROMR
    Cy
    Jackson, CA
  9. Aug 28, 2014 at 12:53 PM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    It is highly recommended, yes.
  10. Aug 28, 2014 at 2:04 PM
    Tactical Tacoma
    Seth
    McKinney, TX
    Yes, you will definitely need new UCA's. If you're on a budget, I agree with OKJC, get the billies, set at 1.75 and do an AAL, good lift for the $$$ and not ridiculously stiff. But still stiffer than stock. If $$ isn't the main deciding factor, I would go with after market coils, struts, shocks, leaf springs and UCA's. You'll obtain a good lift with a smooth ride. On my 09 Prerunner I had billies @ 1.75 w/stock coils and ToyTec AAL and I was pleased with the results for the $$, especially since I did all the work and only paid for parts.
  11. Aug 29, 2014 at 10:09 AM
    MTNROMR
    Cy
    Jackson, CA
    So would this be a good option for a good ride
    https://toyteclifts.3dcartstores.com/mobile/ToytecBilstein-5100-adjustable-coilovers-_p_1171.html
    Will I have to worry about CV boots with a 3 inch lift? I will get new UCA.
  12. Aug 29, 2014 at 11:25 AM
    adamh1977
    adamh1977 Well-Known Member
    arkansas
    trd sport 4x4
    any time fog,tinted windows to 5% ,plasti dipped gun metal gray,toytec 5100's eibach coils ,led map and dome lights
  13. Aug 29, 2014 at 3:52 PM
    weezer
    weezer Well-Known Member
    southeast
    tacoma 4x4
    Bilstein 5100 shocks, OME lifting springs, Ivan Stewart 16x8 wheels, AT tires
    get OME 883 lifting springs and 5100s all around. set them at 0" setting in the front. pretty much the truck will sit level. driver's side will be 1/2" lower because of the taco lean but not a big deal.
  14. Aug 29, 2014 at 3:54 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    883's aren't going to lift a 2nd gen 3"
  15. Aug 29, 2014 at 3:55 PM
    weezer
    southeast
    tacoma 4x4
    i know. he doesn't want a 3" lift. he wants his truck level. at least that's what it seemed like he wanted. maybe i'm wrong?
    to level a truck out you only need a 1 1/2" lift in the front and nothing in the back.
    or is he wanting a 3" lift in front and 1 1/2" lift in the back to make the truck level? :D
  16. Aug 29, 2014 at 3:56 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    It all depends on how deep your pockets are and for what use you will be doing in the truck. If your off-road a lot and do some extreme stuff then yes, get a good suspension lift. If your not off-roading much at all and use it more for a daily driver then you wont have to spend as much. Def stick with a suspension lift though.
  17. Aug 29, 2014 at 3:57 PM
    OZ-T
    Peter North
    British Columbia
    " Best 3" Front Lift / Level "
    am I missing something here ?
  18. Aug 29, 2014 at 4:00 PM
    weezer
    southeast
    tacoma 4x4
    well the way he said it in his post it sounded like he just wanted the front raised up to make it level. he may have thought it took 3" to do so???
    i dunno it's confusing. :laugh:
    go by the title yeah 3" lift. go by what he said not a 3" lift.
  19. Aug 30, 2014 at 11:11 PM
    MTNROMR
    Cy
    Jackson, CA
    I think I will do ToyTec coils with 5100s, but how is the pro comp lift compared to toytec, I won't use the rear lift since I only want the front lifted, but In your opinion what would be a better smoother ride. Here is the pro comp lift:
    http://www.procompusa.com/prodDetail.aspx?partNo=EXPK5081B&catID=1&ptID=3533
    Also, is it better to buy the complete coil from toytec or save $200 and build them my self. Does that mean I need a spring compressor and the use of factory top hats? Thank you for the help
  20. Aug 31, 2014 at 12:10 AM
    zboy
    zboy Well-Known Member
    Oahu808
    12 TRD OR
    [​IMG]Smooth as a FOX
