Best 3 inch lift kit under 1000 dollars
Discussion in 'Suspension' started by Skonrady, Jul 7, 2020.
  1. Jul 7, 2020 at 12:59 PM
    Skonrady
    Skonrady [OP] New Member
    Steven
    2015 tacoma 4x4
    I have a 2015 tacoma 4wd and I would like some feedback on what lift I should get. I dont do any crazy offroading, however i do take my truck on a substantial amount of hunting/camping trips throughout the year. I was thinking a 3 inch lift but my biggest concern was getting the truck level. Anything under a thousand bucks??
  2. Jul 7, 2020 at 1:02 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    A quality set of all terrain tires that are bigger than your current set.
    If you go with 1" larger tires, you'll gain 1/2" of lift.
    That and tires will provide you much more benefit than a lift will especially with the way you use your truck; not to mention it fits the budget.
  3. Jul 7, 2020 at 2:10 PM
    TVH475
    TVH475 Well-Known Member
    Montrose CO
    If your current strut/shocks are still in good condition the above advice I spot on, if you've got worn out equip. then I'd look at Bilstein 5100 series
  4. Jul 7, 2020 at 2:19 PM
    Skonrady
    Steven
    2015 tacoma 4x4
    Thanks for the feedback. I do plan on getting a little bigger tire after I install the lift. I do not want to leave the stock suspension and just get bigger tires though. I want to level the truck out and add a couple inches of ground clearance. A friend of mine recommended the toytec/bilstein 5100 3inch kit. Someone else also recommended the rough country n3 kit. Any thoughts?
  5. Jul 7, 2020 at 2:28 PM
    TVH475
    Montrose CO
    I ran the toytec 2.0 on mine for a bit and was pretty impressed with it, I just wanted more so I moved up. We put the r/c kit on 1 of my buddys trucks a few yrs back, it's still going strong and it see's regular offroad/ fire road use
  6. Jul 7, 2020 at 2:39 PM
    samjpatt
    samjpatt Well-Known Member
    Raleigh, NC
    2018 Cement TRD Off Road
    RIP: 2015 Silver TRD Sport
    5100s, OME coils (which # depends on what cab you have), SPC light racing UCAs.
    Keep in mind that for lifts over 2" its highly recommended to get new UCAs (that accommodate 2"+ lifts) to keep alignment close to spec, if not you'll probably wander all over the road and pre-maturely wear out tires.
    Cheap lifts are.. cheap. Do your research and save yourself from spending more money down the road.
    Here's my 2.5" lift I did on a '15.
  7. Jul 7, 2020 at 2:49 PM
    RyanDCLB
    RyanDCLB Well-Known Member
    4/19 DCLBOR
    samjpatt likes this.
  8. Jul 8, 2020 at 5:24 AM
    TVH475
    Montrose CO
    I really don't want to start a control arm war here, I'll just state what I've done before my current set up! I ran Toytec 2.0 std. travel w/650 springs @ 2.25-2.5" lift with .25 top spacer for right @ 3" of lift, I tried a set of tough country arms, yep got good alignment but couldn't keep the tires out of the fenders without a CMC and I didn't want to do that. I went back to my factory UCA's maxed out caster & the truck did fine, the steering was a little quicker but still fine, I put @ 10k miles hwy driving on this set up. I do have axle shims w/ my OME med springs, but no carrier bearing drop & I'm not using the front diff spacers. Like stated not saying anyone is incorrect, just giving my advice on budget friendly suspension that I've had personal experience with.
    Coma 13 and RyanDCLB like this.
