Best 3" lift for the money? (light offroad use)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JGJ, Feb 28, 2010.
  1. Feb 28, 2010 at 9:06 PM
    JGJ
    JGJ [OP] Well-Known Member
    Can you guys point me to the best 3" lift for the money?...
    More like tell me exactly what you would recommend?
    I want overall lasting quality all around ~ for the lift and for the truck's effected areas.
    I mostly drive on the highway and maybe take it off road 1/month (and nothing major). So it would be mostly for looks.
    I've owned a few trucks & SUVs with lifts but they were already installed when I bought the truck. This will be my first to purchase.
    I was thinking the Toytec spacers with 2" add-a-leaf...?
    Should I get coilovers? Should I replace the shocks? Do I really need to?
    Sorry for the ignorance - just need a little help/clarity.
    Thanks in advance - Jason
    2006 TRD (sport) 4x4 Dble Cab Long Bed
  2. Feb 28, 2010 at 9:10 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    best bang for your buck would be billistine 5100s adjustable shocks .85/1.85/2.5 and add a leaf. Spacers are not good
  3. Feb 28, 2010 at 9:12 PM
    yosh2000
    yosh2000 Well-Known Member
    Denver, CO
    '17 Tundra CM 5.7
    5100s from sonny at downsouthmotorsports.com. for $300 you will get 4 new shocks, 2.5" front lift and i personally believe is the best bang for the buck. as far as AAL, the 2.5 will level you out. if you want to keep the OEM rake, you'll need the AAL.
  4. Feb 28, 2010 at 9:18 PM
    Klipp11
    Klipp11 s3
    Kevin
    '06 DC 4x4 LB
    OME 885 coils, Bilstein 5100 shocks, 1.5" AAL, TC uca's, cab mount chop, 5000k HID heads and fogs, LED tails, satoshi GC w/ Hella 500's mounted behind it with 5000k HID upgrade, Extang solid tri-fold tonneau cover, Yakima roof rack, fog light anytime mod, disable a/c defrost mod
    i really like my setup; i've got the same dc lb and sounds like it would serve you well too:
    Bilstein 5100 shocks all around
    OME 885 coils
    1.5" Add-A-Leafs
    Total Chaos upper control arms
    don't know what your budget is though
    here's a pic:
  5. Feb 28, 2010 at 9:38 PM
    gtmiller1001
    gtmiller1001 Well-Known Member
    Greg
    Houston, TX
    06 Double Cab TRD Sport V6
    BHLM, Painted Stock 17" sport rims black, 3" Toytec coil overs with 5100's, AAL, black bull bar, TRD filter, parrot bluetooth, anytime foglights, debadged, removed mud flaps, added bed lights, grillcraft, Wet Okole's, Weather Tech's.....and traded in for a Tundra
    I have that lift and am pretty happy with it. That being said, I only drive on the highway and didn't want to spend too much money. Some say that the truck rides worse afterwards and it does a little, but not too much to me. I had a F-150 with a 3" body and 3" suspension previously. Even with new coils and shocks on it it rode horrible. The difference between the stock ride of the tacoma and the ride after the toytec lift is negligible IMO
  6. Feb 28, 2010 at 9:39 PM
    Just4fununlimited
    Just4fununlimited Turtle
    Tyrtl
    Cerritos/Originally from the island of Guam
    06 prerunner TRD Off Road SR5
    Toytec 3" Lift with 1.5" Lift block in the rear 285/75/16 COOPER STT 16" Eagle Alloy Style 101 PA15 TOY Decepticon Emblem courtesy of Metalmiller TRD Urban Assault Emblem courtesy of Sockmonkey More to come...
  7. Feb 28, 2010 at 9:41 PM
    Lunercrab
    Lunercrab AKA "06tacosport"
    Beth
    Lehigh Valley area, PA
    2010 timberland mica dcab sport
    I had the 5100s all around front set at 2.5" with the 2" aal in the rear on my 2006. It rode alittle stiff but I like how It felt solid. This time I have alittle more money so I'm thinking of going with the toytec OME kit on my new 2010. But I'm in the same boat as u. I don't really offroad but I wanna do something a little different this time around since I can financially.
  8. Mar 1, 2010 at 5:11 AM
    JGJ
    I'm not on a "tight" budget but I'm not also made of money.
    I'll spend the extra cash to for the overall longer lasting quality (since I plan to keep the truck awhile).
    I would think I could easily pull this off (3" quality lift) for under $1K.
    I would like to stuff a 33x12.50 tire under there. I've already done the body mount cut. From what I read I would now need a good 3" to clear that wide of a tire.
    You guys are great. Thanks again. Please keep the recommendations coming.
    So far I've heard "Bilstein 5100 shocks all around" the most.
  9. Mar 1, 2010 at 5:30 AM
    goride
    goride Well-Known Member
    Josh
    UTAH
    09 trd sport dbl cab lb
    Tinted windows,Upgraded stereo system,satoshi grill with piaa lights behind,dash light color mod to blue,mag light holder,OME dakar leafs,Toytec ultimate lift,LR uca's, BFG AT's 285/70/17 on Pro Comp 7089s,weather techs, leer shell,CBI sliders and rear bumper w/tire gate,soon DTLT w/ wicked flow catback exhaust
    I have to toytec ultimate lift with Ome leafs and lr uca's and love it so far,and put 285's on it. In my opinion its a great set up. Clearly there are many other ways to go but I like mine.Just my 2cents
  10. Mar 1, 2010 at 5:35 AM
    zimm52
    zimm52 Well-Known Member
    sneakin up behind you
    2010 PreRunner TRD Off Road
    nothing yet!
    Do spacers make your truck ride stiffer?
  11. Mar 1, 2010 at 7:34 AM
    yosh2000
    Denver, CO
    '17 Tundra CM 5.7
    well, the bils are 2.5", you go any higher and you will also have to add UCAs (at least $450-650) to the list to get your alignment correct, fyi...
  12. Mar 1, 2010 at 10:07 AM
    JGJ
    bump. Anyone else have input?
    Want to fit a 33x12.5 tire. I have the body mount cut done. Want the best bang for the buck.
    THANKS!
  13. Mar 1, 2010 at 11:34 AM
    MachoTaco10
    MachoTaco10 Well-Known Member
    Nick
    New Hampshire
    2010 Tacoma TRD Sport
    I got my alignment correct actually perfect with a 3'' lift...
  14. Mar 1, 2010 at 11:35 AM
    MachoTaco10
    Nick
    New Hampshire
    only the spacer that pre loads the spring will make it stiffer. the one like i have is a top plate spacer and does not pre load the spring the ride is the same as stock
  15. Mar 1, 2010 at 11:56 AM
    JGJ
    MachoTaco10, can you tell me exactly what you have so I can look it up and put it down on my consideration list? Do you think a 33x12.50 nitto mudgrappler tire will fit under there?
    Thanks
  16. Mar 1, 2010 at 12:11 PM
    zimm52
    nothing yet!
    good to know. thanks for the info.
  17. Mar 1, 2010 at 12:30 PM
    TacoSupreem
    TacoSupreem Dirty Trucker
    Hayden
    Kentucky
    2013 MGM DCSB 4x4 Sport
  18. Mar 1, 2010 at 12:54 PM
    2007TacBorla4X4
    2007TacBorla4X4 Well-Known Member
    Bob
    Jax, FL
    TRD Sport 4X4 Short Bed
    Borla cat back, K&N cold air, Silver star bulbs, Nerf bars,NEW BFG, Weather teck windows, Flash light on the drivers seat, TRD off Road ft tow hook, Rear driving lights on bumper, Weather teck windows & ft bug guard, 4X4 switch glows, Windows tinted 20% sun shade
    So if I do the same thing with 5100 , do I need to replace the the AAL & what is that??
    Sorry I just had to ask...
  19. Mar 1, 2010 at 5:34 PM
    jeremy.allen
    jeremy.allen Well-Known Member
    Jeremy
    The Ville, Ky
    07 DC, OR
    3" Lift with OME 885's, 5100's front and rear, alcan add-a-leaf. Banks Monster Exhaust, on the way: MM951C 17X9 and 285 MT/R's...
    most of the spacer lifts have the spacer that fits between the top of the spring and the top plate that is bolted to the top of the shock. the stiffer ride is because the spacer is keeping the shock extended and its limiting shock travel. take everyone's advice and stay away from these. i vote for the billy's. good luck!
  20. Mar 3, 2010 at 9:45 AM
    JGJ
    Even if I cut the body mount? Where are you rubbing? on the front fender well?
    Thanks
