Best 3" lift kit for 2015 trd off road
Discussion in '2nd Gen. Tacomas (2005-2015)' started by thestickswinger, May 14, 2015.
  1. May 14, 2015 at 9:05 AM
    thestickswinger
    thestickswinger [OP] Member
    2015 Tacoma Dlb Cab TRD Off Road
    I'm looking to get a 3" lift kit for my 2015 Dbl cab trd off road. Any recommendations for less than $1500?
  2. May 14, 2015 at 9:07 AM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    OME
    Rattletrap66 likes this.
  3. May 14, 2015 at 9:09 AM
    JimboAnz
    JimboAnz #OldNorm
    Jimbo
    Charlotte (Cornelius) NC
    2020 Ford F'in Ranger
    I am also saving for this budget range and lift for my 15 AC TRD OR. Ive done a lot of research, but there will be lots of opinions.
    OME or Billy 5100 fronts and rear shocks. OME 885 or eibach lift springs up front, + taco lean spacer for driver side. Progressive 3 leaf AAL out back. New UCA's.
  4. May 14, 2015 at 9:11 AM
    Mademan925
    Mademan925 Senor Taco
    Nick
    Discovery Bay, CA
    2014 4x4 TRD OFFROAD DCSB
    enough to go over stuff
  5. May 14, 2015 at 9:12 AM
    Mademan925
    Nick
    Discovery Bay, CA
    Or you could do an OME kit with new UCA's for 1500
  6. May 14, 2015 at 9:18 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    I have always considered the toytec kit to be WAY overpriced... all it is is 5100's ($320 bucks normally) springs ($170), and a single leaf AAL (75 bucks) Total of a little less than 600 bucks which they sell for 2x.
    OK yes you get the adjustable collars but in the end, do you really need that fine of adjustment over your lift for an extra 600 bucks? Id rather spend the difference on some good UCA's from JBA etc.
  7. May 14, 2015 at 9:20 AM
    Rattletrap66
    Rattletrap66 (ノಠ益ಠ)ノ彡┻━┻
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    2014 TRD Off Road DCSB
    ╭∩╮(ಠ۝ಠ)╭∩╮
    Old Man Emu
    I just need to get a leaf pack and I will be installing mine
  8. May 14, 2015 at 9:36 AM
    Mademan925
    Nick
    Discovery Bay, CA
    I think adjustability is important. As I mod and add wieght to my truck Im able to compensate easily in my drive way in a matter of minutes instead of buying new coils.
  9. May 14, 2015 at 9:42 AM
    nd4spdbh
    SoCal
    True for a bitchin rig like you got, yes having that finite adjustment is good. But for a rig like yours you are not going with adjustable 5100's... you have proper shit from ICON / FOX / KING
  10. May 14, 2015 at 9:44 AM
    Mademan925
    Nick
    Discovery Bay, CA
    Haha. Yeah his price range is 1,500. Ive spent a bit more...:thumbsup:
  11. May 14, 2015 at 11:12 AM
    DVexile
    DVexile Exiled to the East
    Ken
    2015 DCSB V6 TRD OR 4X4
    At that price almost your only choice for something remotely close to "done right" is OME Nitrochargers and Dakar with LR UCAs. That will be right at about $1500.
    LR UCA is $400 and for 3" lift you really need to do aftermarket UCAs or you will have steering and tire wear problems. So you need some sort of UCA and the LR is presently the cheapest good option out there that will let you get good alignment at 3" of lift. Add a $100 or so and you have more options for UCAs.
    At 3" lift for the rear you are looking at new leafs and the OME Dakar is a good reasonably priced choice. All Pro is also in the same ballpark price and performance wise.
    Nitrochargers are a good twin tube shock. For your price range a monotube shock with adjustable coilover is out of your price range I think unless you do the rest of the lift job poorly (e.g. use stock UCAs and some sort of an add a leaf or blocks on the rear).
    The above setup is a good lift with good off road performance lots of people use with great success and are quite happy with for years.
    If you just want to mall crawl and don't care if the truck is constantly trying to wander all over the road then there are probably a lot of other half-assed options out there. I'm just not familiar with them. You don't say if you want lift and off-road performance or just a lift for looks.
  12. May 14, 2015 at 12:13 PM
    nd4spdbh
    SoCal
    only a bit haha
  13. May 14, 2015 at 2:33 PM
    Rudy
    Rudy Member
    2015 Tacoma
    ToyTec 3" adjustable coil-over front lift Front Dif Drop Sway bar Relocation kit. ToyTec 2" AAL Bilstein 5160 shocks in the rear Rear Axel shims
