Best 3" lift kit for a 2017 4wd Taco
Discussion in '3rd Gen. Tacomas (2016-2023)' started by bkdonithan, Feb 12, 2025.
  1. Feb 12, 2025 at 9:15 PM
    bkdonithan
    bkdonithan [OP] New Member
    Brian
    2017 Tacoma XSP-X Black
    I have a 2017 Taco XSP-X and I want to put a 3 inch suspension lift kit on it. Which would be the best lift kit for this truck. It is a crew cab and this is the 1st time I am putting a lift kit on a truck. I have zero experience in modifying one. Any help is appreciated. I'm also looking for a black front XSP-X skid plate for sale. Any information is appreciated.
  2. Feb 12, 2025 at 9:22 PM
    Strictlytoyz
    Strictlytoyz Well-Known Member
    Charles
    HA\/\/AII
    07 Shitbox
    Why do you want to lift it? How do you use your truck?
    RIX TUX, Chew and T4R_hereforbearings like this.
  3. Feb 12, 2025 at 9:22 PM
    T4R_hereforbearings
    T4R_hereforbearings Dale Doback, M.D.
    WA
    08 4Runner
    I’ve bolted some stuff to it *lists cool stuff here*
    RIX TUX likes this.
  4. Feb 12, 2025 at 9:47 PM
    4x4junkie
    4x4junkie Well-Known Member
    So Calif. (SFV)
    2018 TRD Sport ACLB MT
    Might want to tell us whether your truck is 2WD or 4x4... Recommendations for lifts can vary a lot depending on whether you have a front driveline under there or not.
    Welcome to TW
  5. Feb 12, 2025 at 10:34 PM
    6MTPro
    6MTPro Well-Known Member
    HI -> CA
    2018 TRD Pro 6MT | 2004 4Runner 4.7 V8
    Tune, 285/75/16, Diode Dynamics, PPF, Bakflip Mx4, Meso, Cali Raised, TJM
    your budget would be helpful too for more accurate feedback.
    RIX TUX and Chew like this.
  6. Feb 13, 2025 at 3:26 AM
    bkdonithan
    Brian
    Hey guys. Sorry for not including that my truck is 4WD. I thought that I had. My truck would be a pavement princess. My budget would be around $1,500-2K. I love the look estheticly. My truck is also the XSP-X version from the South East dealerships. I know that I want a suspension lift for a better quality of ride.
  7. Feb 13, 2025 at 5:14 AM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    FYI, these trucks don't do well with anything over 2"+. Unless you throw alot of money and mods to suspension. Driveline angles to severe.There is alot of threads on this subject.
    Chew likes this.
  8. Feb 13, 2025 at 8:15 AM
    Veet-88
    Veet-88 Well-Known Member
    18 Tacoma DCLB sport
    3" lift and better ride quality cannot be in the same sentence.
    I suggest skipping the lift, do a higher offset wheel around 0 and one up size tire. There's alot of head ache that can come from a lift that it is not worth it for a street truck.
    Chew and YF_Ryan like this.
  9. Feb 13, 2025 at 8:27 AM
    IrishRed
    IrishRed Appalachian Ridgerunner
    Central PA
    2017 TRDOR DCSB 4x4 MGM Prem&Tech Auto
    Eibach Suspension, JBA UCA’s, 16” SCS Ray 10s, BFG KO3s, ECGS Bushing, Pro Skid Plate, Fumoto Valve, Pro Grille, Opt7 Tailgate Light Bar, AVS Window In-Channel Vents, Roknlokz XL Mud Flaps, Husky Floor Mats, Bed Mat, Tailgate & Glovebox Letter Inserts, TRD Grille Badge, Exhaust Tip, Toyota Hitch Plug.
    Best bang for your dollar will probably be the Bilstein 5100 with factory front coils or the Eibach Stage 1 offering. Research these offerings and see what you think.
  10. Feb 13, 2025 at 9:40 AM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    2" Bilstein 5100 w/Stock coils, would be your best 3" lift....
  11. Feb 14, 2025 at 8:42 AM
    Lsears558
    Lsears558 Member
    Landon
    2021 MGM Tacoma trd off road
    get an eibach stage 2R suspension kit. I just put it on my truck over the weekened and it drives great and looks great. if you want to save some money get blocks in the rear and should be right around 1,000$ shipped.
  12. Feb 14, 2025 at 9:03 AM
    Strictlytoyz
    Charles
    HA\/\/AII
    07 Shitbox
    "Best" will be different for every person. When you say you want better ride quality, what does that mean to you?
  13. Feb 14, 2025 at 3:28 PM
    majpooper
    majpooper Well-Known Member
    Dennis
    North Carolina
    2022 Black TRD OR
    OTT Tune Front 2" lift OME 888 coil Bilstein 5100 DuroBump extended front bump stops Archive Garage extended rear bump stops Rear 1.85" lift Icon RXT leaf pack Bilstein 5100 SPC UCA DX4 16x8 +10 wheels 285/75R16 KO2 viper cut CMC sway bar delete exhaust reroute exhaust cut just past the rear axle U-bolt flip LFD engine skid plate RCI transmission and x-fer case skid plates Spindle gussets
    Since it's a pavement queen a Bilstein 5100 2" lift with stock coils and lift block in the rear is well within your budget.
    You could go a little bigger with the tires but there you have to be careful - wheel offset is critical and typically entails a little cutting and fender trimming.
    Another route might be just a mild 1" lift with 5100s all around and 265/75R16 or 265/70R17 depending on your wheels. It will have a bit of a lift with meatier tires especially 265/75R16 to get you a more aggressive look. If you do get new wheels keep the offset reasonable -10 to +10 0 being the sweet spot. Do that and you will get a better ride and an aggressive look and no rubbing issues - then get an OTT tune and you will love the way your truck drives.
  14. Feb 14, 2025 at 3:43 PM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    I did a one inch lift.
    Random strangers have approached me and said "that's the kind of setup that says you know what you are doing "
    I see max lifts all the time. Yawn.
  15. Feb 14, 2025 at 3:52 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    why do you want a 3 in lift?
  16. Feb 14, 2025 at 3:53 PM
    Bigmatt503
    Bigmatt503 Well-Known Member
    The Eibach stage 1 kit will get you about 2 inch of lift and ride great. Throw a 1 inch block in the rear and you'll be set. Get some 285 tires and gain a little more lift
    IrishRed likes this.
  17. Feb 15, 2025 at 1:26 PM
    majpooper
    Dennis
    North Carolina
    2022 Black TRD OR
    Not exactly - there is one unusual 285/65R16 tire (made by Toyo or some other brand not sure which and too lazy to look it up) that is basically a a 32" tire that is not all that is the same size from 265/75R16 which has a lot of choices and is also a 32" tire size just a bit wider - maybe get a wider look - I get that, but still could be - I emphasize COULD BE issues.
    Once you get into 285s that are typically 33s there, again, can be rubbing issues - some minor some not depending on wheel offset etc. I would say be careful going over 32" - you can do it obviously but do due diligence.
