Best 3" Lift?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BImike, Mar 8, 2010.
  1. Mar 8, 2010 at 12:57 PM
    BImike
    BImike [OP] Member
    Looking for clearance...have a '06 Tacoma, 4x4, double cab, long bed.
    Not looking to go up too much...3" max and will not change tires until stock size wears out.
    Any ideas for a good, simple, not lose the ride, decent priced 3" lift?
    Looked at the revtek add a leaf....opinions? Will this lift prevent the sag I commonly see on lifted trucks or is there something else I should do to prevent that?
    Thanks,
    From a newbie
  2. Mar 8, 2010 at 12:59 PM
    tacomanuts89
    tacomanuts89 Well-Known Member
    Mat
    Newfoundland
    09 SR5 black
    Pionner Avic D3 with alpine M500 amp and alpine type S sub,Grillcraft, Skid plate, URD Short Throw Shifter, Rcbs204 Lighting, Huskey Liners, Extang trifecta tonneau cover, Fog Lights, Extra D-Rings, U-Haul Class 3 hitch
    I am also looking for a 3'' lift but for an 09 access cab 4x4. let me know what u find if u can thanks
  3. Mar 8, 2010 at 12:59 PM
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2005 Prerunner TRD Off Road
    265/75/16 BFG A/T, 18" Magnaflow, K&N Intake Filter, Ultra-Gauge, Kobalt Toolbox, Metal Tail Light Guards, Cobra 19 and 4ft fiberglass antenna, Plasti dipped Badges/lower valance/rear bumper/grill/bullbar/ac controls, black DIN kit, JVC KD-X40, Wet Suit Seat Covers
    What's your budget?
  4. Mar 8, 2010 at 1:02 PM
    BImike
    BImike [OP] Member
    I got a quote here at 977.00 with installation and alignment. Maybe aound that ballpark...give or take a few hundred. Not looking to style out the truck. More for practical purposes.
  5. Mar 8, 2010 at 1:04 PM
    Rainman998
    Rainman998 Well-Known Member
    "The QC" AZ
    SEXY 2010 Double Cab 4x4 TRD Off Road
    Waiting for my sugar mama to hook it up
    I got the same question I have a 2010 Double Cab TRD Off Road 4x4 and want to get a 3" lift. I am not made of money but its not an issue. My truck is my baby and I want the best.
  6. Mar 8, 2010 at 1:08 PM
    dylandercole
    dylandercole Well-Known Member
    Dylan
    Santa Cruz Mountains, CA
    03 SR5 TRD 4x4 5-speed
    sway-a-way 2.0 coilovers, 1.5'' AAL, 1'' toytec shackle lift, Go-Rhino 3000 Grille Guard, Kicker KS6502 speakers, JVC KD-S24 Head unit, billstein 5125 rear shocks, Deck Plate mod, K&N air filter, Wheelers offroad front and rear braided brake lines, diff breather mod, power slot rotors, ebc yellow stuff pads
    hell for around a grand you could get a set of coilovers and an AAL
  7. Mar 8, 2010 at 1:10 PM
    Riderx805
    Riderx805 Well-Known Member
    Thousand Oaks, Ca
    08 PreRunner Double Cab
    *Pioneer In Dash DVD Player *Aftermarket Trailer Hitch *Bilstein 5100's w/ rear block *5% tint
    How do you use your truck? I just bought the bilstein 5100s for the front and back. I get it installed on Thursday and I'm pretty excited! That setup will give you a 2.5 inch lift in the front and I went with a block for the back. Install, warranty on parts and labor, and alignment ran me about $1k.
  8. Mar 8, 2010 at 1:12 PM
    BImike
    BImike [OP] Member
    LOL! Yeah, maybe where you're at....here in the islands they steal the pants off of you. :) What's the benefit to the coilovers and AAL. Or is this another can of worms not to be opened b/c of complexity?
  9. Mar 8, 2010 at 1:15 PM
    BImike
    BImike [OP] Member
    Moderate off-roading for hunting and fishing. lava fields, dusty/rocky roads and some mud. Long wheel base with the extended cab enough clearance with the 2.5"?
  10. Mar 8, 2010 at 1:16 PM
    BImike
    BImike [OP] Member
    Rider,
    I was quoted a little more for the Bilsteins. Are they as good or better than the 3" revtek...what about sagging? I heard ride is better.
  11. Mar 8, 2010 at 1:18 PM
    dylandercole
    Dylan
    well basically coilovers are a complete swap out of shocks and coils for the front, but are paired together perfectly so the ride is much better than say pre loaded springs (spacers), or ever 5100s (also compressed springs but still pretty good ride). the AAL is pretty cheap, gives lift, increase load capacity, ect. and since the coilover is already put together the install is really easy so that will save you a lot of money if you do it yourself. Its a direct bolt on replacement.
  12. Mar 8, 2010 at 1:19 PM
    dylandercole
    Dylan
    I had the revtek before I got my coilovers and the ride wasnt that bad but there jsut want any travel with them
  13. Mar 8, 2010 at 1:26 PM
    Riderx805
    Thousand Oaks, Ca
    From what I read/heard, the bilsteins are gonna be the best for the $$$. I haven't had them installed yet so I haven't put them to the test myself. I actually read a ton of forums about them and even created my own thread on the subject. You drive your truck like I drive mine so I believe it will be a good set-up for you also. The coilovers are gonna give you a better ride but they are pretty expensive. I was looking at some sway away 2.0 and they wanted $1300 installed with a warranty and aligned (that will only give you a lift up front). From what I read, the coils may have to be rebuilt every now and then, and the bili's come with a lifetime warranty and dont have to be rebuilt. Also doesnt the AAL make the back end of your truck pretty stiff?
  14. Mar 8, 2010 at 1:28 PM
    Riderx805
    Thousand Oaks, Ca
    Thats just my opinion on the info I have researched. Im NO expert!
  15. Mar 8, 2010 at 1:30 PM
    Jigzor
    Jigzor Well-Known Member
    Pennsylvania
    17 DCSB Silver Sky
    OME 3" Kit.
  16. Mar 8, 2010 at 1:36 PM
    Riderx805
    Thousand Oaks, Ca
    I heard good things about the OME also.. Is that what you are running Jigzor? I believe its a little more expensive for the full kit tho.
  17. Mar 8, 2010 at 2:46 PM
    Lunercrab
    Lunercrab AKA "06tacosport"
    Beth
    Lehigh Valley area, PA
    2010 timberland mica dcab sport
    I've had the 5100s set at 2.5" with the aal. Everything with install and aligment came to a hair under 600 for me on my 06. The ride was a bit stiff butt I really liked the way it rode. No complaints. I think since I have a bit more coin this time around I may try the OME setup on my 2010
  18. Mar 8, 2010 at 2:54 PM
    dylandercole
    Dylan
    I have the sway-a-way 2.0 coilovers, and I got them for $650 out the door and it took less than an hour for install. I was trying to say if he can do the install himself which isnt very hard at all then he could get some better stuff for that price. but yes Iv heard really good things about the billies too
  19. Mar 8, 2010 at 3:08 PM
    BradleyJ33
    BradleyJ33 Geaux Tigers
    Brad
    Brandon, MS
    2010 TRD Sport 4x4 DCSB S/C'd
    TRD Supercharger with URD 2.825" Pulley, Toytec Ultimate Lift, LR UCAs, BFG All Terrain 275/70R17s on Procomp 7089 17" wheels, BAMF rock sliders, Viper 5902 alarm/remote start with smartstart, Pioneer Avic-Z110BT dvd/navi head unit, 2 Pioneer 7" monitors in headrests, 2 Rockford Fosgate Shallow-mount 10" subs pushed by RF Punch 500.2 amp, RF 5.25 components (front doors) and 5.25 full range (back doors) pushed by RF Power 400.4 amp, sound deadened, Whistler pro remote radar detector, scangauge II, debadged, Sockmonkey decals, blacked headlights with FX-R projectors, DDM Tuning HID fogs, Grillcraft upper and lower MX grill with Hella 500ffs converted to HIDs behind, AFE Stage 2 Cold Air Intake, Walbro 255 Fuel Pump upgrade, Dynomax Super Turbo muffler, Bestop Supertop, Wet Okole seat covers, Weathertech floor liners, Pop & Lock tailgate handle, Lighted 4x4 switch mod, 2 110v AC outlets in cab mod, Always at 400W mod, Maplights on with dome light mod, homelink in headliner mod, foglight
    Toytec Ultimate Lift FTW!
  20. Mar 10, 2010 at 4:16 PM
    Riderx805
    Thousand Oaks, Ca
    Hey dylandercole. How do you like the sway a ways 2.0? When I was making up my mind I couldn't decide what to go with. The shop made it seem like I couldn't do the C/O install myself by telling me that they would need to spend about 2 hours leveling the truck to make sure it sits right. That was probably a nice load of BS! hahah.. Oh well! I get the bily's installed tomorrow morning! I'm pretty excited...
