Best 3" rear leaf spring pack for the Taco
Discussion in '2nd Gen. Tacomas (2005-2015)' started by streetlightning, Feb 6, 2014.
  1. Feb 6, 2014 at 3:05 PM
    streetlightning
    streetlightning [OP] Member
    Denver, CO
    '12 Tacoma TRD T/X Pro
    Last summer, I did the Fox ride height adjustable front shocks and a 1" block with the Fox 2.0 shocks on the rear. It didn't lift much and I want to change it up. I'm looking at doing adjustable UCAs and keeping the Fox shocks on the front and rear, but replacing the rear springs.
    (forgive me if this was covered, but I didn't notice it on another thread)
    What rear 3" leaf springs are good? I see the ARB/EMU and the All Pro kits and wonder if the All Pro kit is just the ARB repackaged. What else is out there for a good progressive rate spring. Not a huge fan of ARB and I've read some reviews not liking the ride. 4 Wheel Parts says its a nicer, smoother ride than stock with the ARB. Any thoughts?
  2. Feb 6, 2014 at 3:07 PM
    VTaco08
    VTaco08 Well-Known Member
    Vermont
    08 Tacoma 4X4
    OME Complete lift kit, Dakar leaf pack, LR UCA's, G2 1.25 wheel spacers, Pro Comp 17/8 5001, derrped badges.
    Go with the Dakar's. It lifted my DCSB 3 full inches. If you go this route just make sure you order new bushings for the leaf packs or make sure they are supplied.
  3. Mar 10, 2014 at 8:44 AM
    streetlightning
    Denver, CO
    I went with several people's suggestion and got the Emu Dakar springs while adjusting the front to match and changing out the UCA's with adjustable ones and doing the differential drop kit. I have to say... its pretty messed up. By messed up, drivability, control, and noises are crazy. 4 Wheel Parts told me the springs would ride nicer, but may limit the carrying capacity. I confirmed they would ride softer and paired with the Fox 2.0 shocks on the rear it should ride like its on marshmallows. Truth be told, the springs are so solid, there's little movement. Its sprung pretty tight. As far as a break in period... been through that, towed trailers and still as stiff as day one. I'll post another post about the Tacoma geometry, lifts and alignment.
    Regardless... I'll probably go back to the stock leaf springs and a block and unlift the front and remove the diff drop. Just wanted to follow up on my my experience with the ARB Dakar springs. Not happy with them.
  4. Mar 10, 2014 at 8:48 AM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    Alcan and Deaver make springs too!
    Check out
  5. Mar 10, 2014 at 9:39 AM
    aubi1414
    aubi1414 War Eagle!!
    Justin
    Pensacola, FL
    2014 Tacoma TRD Sport Blue Ribbon Metallic
    LED Dome, LED Map, LED License Plate Bulbs, , Konig SixShooters Matte Black, Toyo Open Country ATII's 285 70 17, Satoshi, Bilstein 5100s (set to 0), 885s, LR UCA's, Icon RR 2.0 +2, All Pro Standard 3" Leaf Pack, All Pro Flip Kit, Sway Bar Relocate, Exhaust Chop, Antenna X 14", Debadged, Tint, Matt123 Black TRD Skid, Black Weathertech Mats
    The Allpro Standard I heard were really good and it gives you a 3" lift. Also take into consideration that if you are using Fox 2.0 in the rear with standard ride height that they might be to short. You may need to get taller shocks for the rear 9.5" or so would correct it.
  6. Mar 10, 2014 at 9:39 AM
    streetlightning
    Denver, CO
    Saw the Deaver springs after the fact. I will look into those as well as the TRD springs they use on the TX Baja trucks. Its an extra leaf and slightly thinner with a little move movement.
  7. Mar 10, 2014 at 9:42 AM
    aubi1414
    Justin
    Pensacola, FL
  8. Mar 10, 2014 at 9:45 AM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    I dunno who the hell told you that Dakars were going to ride like Marshmallows but they were obviously full of shit. They're pretty heavy springs. The All Pro 3" would have been softer, and the Expedition would probably be the hardest.
  9. Mar 10, 2014 at 10:49 AM
    streetlightning
    Denver, CO
    Krazie- agreed, full of shit. 4 Wheel Parts has great sales people. Seemingly some of the best in the business. They also don't understand geometry or a proper alignment, toe in, caster or camber and sure can't recognize it when driving as long as they can stuff bigger tires on something and park it on a curb.
    Mully likes this.
  10. Mar 10, 2014 at 10:49 AM
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Hey...I park on curbs... :(
  11. Mar 10, 2014 at 10:54 AM
    Jetlander
    Jetlander Just trying to measure up...
    Jonathan (aka MOAB)
    Depends on the day.
    2010 Tacoma DCSB 4x4 SR5
    TKO Wheel w/ 35" BFG KM2, Volant CAI, Safari Snorkel, 3" lift, All-Pro Full Skid Underarmor, Chopped/Re-Routed FlowMaster Exhaust, CBI Moab 2.0 Front Bumper, DerpWerx High Clearance Rear Bumper, Rear Tire Swing Out, BAMF Sliders w/Kickouts, King Resi w/700# Coilovers on front, Total Chaos UCA's, King Long Travel with Resi's, Shock Hoops and King 2.5 Bump Stops, OME Dakar Leaf Springs mounted on All-Pro Shackle Flip w/ U-Bolt Flip, extended SS Brake Lines, DerpWerx Bedrack, 10# C02 Tank, Black Badges, Dual Optima Red Top's, Blue Sea 12 Fuse Block on custom Block mount, SuperWinch 9.5iSR Talon w/synthetic line, Prolink Thimble, 20" Rigid Dual Row LED Light Bar, Rigid Dually Floods, OTRATTW Switches, Cab Mount Chop, Cobra CB w/ 4' Firestik, Center Counsel Glock 23 mount (with plenty o' ammo!), Weathertechs, and plenty more mods to come!
    :D
  12. Mar 10, 2014 at 11:01 AM
    Mainmoe02
    Mainmoe02 Well-Known Member
    Moe
    Austin, Texas
    01 Gold tacoma SR5 TRD
    3" lift EIBACH coils w/ 5100's front, OME/ Dakar leaf springs w/ toytec adjustable shackles at 1.5" and 5125's out back. 33x10.5x15 KM2's Relentless DIY steel bumper.
    That's strange that the dakars ride stiff. Do you have any constant weight in the bed? Not that you should have to but it may help. And how did dakars give you a full 3" lift. Have you seen the 2nd gen Dakar thread. Those guys get 2.25-2.5" lift, so 3" is pretty high for those leaf springs. Do you have 5 leafs plus 2 overload leafs for a total of 7? Or did yours come with the AAL already installed for a total of 8 leafs? The AAL would make it ride stiff and would probably give you 3" lift especially if there is no weight. I have dakars and love them, but I'm on a first gen. But from the research I've done on both gens the dakars ride smooth
  13. Mar 10, 2014 at 11:31 AM
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    That'll do it.
  14. Mar 13, 2014 at 4:38 AM
    VTaco08
    Vermont
    08 Tacoma 4X4
    I attained a full 3" lift from the Dakar leaf pack. Both leafs packs I received from MetalTech had a plus symbol on them so they are above factory specs. They ride stiff but I like the stiffness, feels more like a truck.
