Best 3" Suspension Parts/Kit for 2008 Tacoma DC
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Alpine Beast, Jul 7, 2017.
  1. Jul 7, 2017 at 10:36 AM
    Alpine Beast
    Alpine Beast [OP] New Member
    Brent
    2008 Blue Tacoma DC TRD
    Nothing yet
    Hi
    Just bought a 2008 Tacoma DC TRD Sport with new KO2 tires on stock wheels. I already have several issues:
    1) 3" Suspension upgrade suggestions. Not cheapest or most expensive. Friend suggested OME.
    2) Factory stereo needs to be changed pronto!
    3) Clunking noise in back end. Already tightened one box bolt. Looking for other potential loose bolts
    4) Squeaky leaf springs. May upgrade to a new leaf pack (Dakar) with suspension lift.
    Suggestions and ideas would be appreciated.
    HeadStrong Off-Road likes this.
  2. Jul 7, 2017 at 10:54 AM
    tacoboy14
    tacoboy14 Member
    Cruise
    in for radio recommendations, ive been shopping around but haven't found a double-din i like
  3. Jul 7, 2017 at 11:02 AM
    PintSize
    PintSize Crossthreaded & torqued down
    Texas
    2011 2.7L 5 spd RC 4x4
    @HeadStrong Off-Road is a great place to get kit with Bilistein 5100 shocks, lift coils and AAL or dakars.
    I had sqeeky leafs cleaned the dirt that built up while installing AALs and shocks. Squeaks very, very little now.
  4. Jul 7, 2017 at 11:16 AM
    eccracer104
    eccracer104 O.G. Member
    San Diego, CA
    2016 Tundra 4x4
    OME is a great choice, but to make sure it's the best choice: How do you use your truck?
    Here's a great place to start - http://*********.com/
    Check the u-joints in the drive line, your center support carrier bearing, check to see if your leaf springs are cracked, check your U-bolts.
    Leaf springs almost always develop some sort of squeak due to dirt and debris getting stuck between the leafs. Rubber pads (shims) between the leafs works well to minimize or eliminate that.
  5. Jul 7, 2017 at 12:06 PM
    Pork Chopper
    Pork Chopper Well-Known Member
    Dallas, TX
    07 DC 4x4
  6. Jul 7, 2017 at 1:41 PM
    Alpine Beast
    Brent
    Nothing yet
    @eccracer104 yeah OEM sounds and looks good. Going to be using my truck for some fairly burly off road stuff in BC, Canada where I live. I'm not a serious off roader but I will be using my truck to get into cool backcountry places for camping and rock climbing.
  7. Jul 7, 2017 at 1:58 PM
    eccracer104
    San Diego, CA
    2016 Tundra 4x4
    Old Man Emu definitely offers a very stout suspension kit, it would work very well for what you're looking to do. If you have the time, may be worth while to scan the for sale section for a set of used coilovers to have the best of the best, but OME is a great option and the complete kit is much more well priced. I would recommend getting a set of aftermarket UCAs to pair with it. They will keep you in proper alignment and yield a little better range of travel.
  8. Jul 7, 2017 at 4:44 PM
    HeadStrong Off-Road
    HeadStrong Off-Road Well-Known Member Vendor
    2011 Toyota Tacoma and 2019 4Runner
    Thank you so much for the recommendation @PintSize , we truly appreciate it! :bananadance:
  9. Jul 7, 2017 at 4:45 PM
    HeadStrong Off-Road
    If there is anything that we can help you with @Alpine Beast just let us know. I will be back in the office on Monday :)
  10. Jul 7, 2017 at 6:51 PM
    Forshee47
    Forshee47 Well-Known Member
    Trent
    North Carolina
    2015 Off-road DCSB 4x4
    Ome is really good for the money. As far as the clunking noise when does it make the sound. Taking off, when it shifts, when going over bumps. The noise could be many different things. Could be as simple as a loose fitting hitch ball mount bouncing inside the reciever if you have one in. I've found that to be my problem before after checking many bolts.
  11. Jul 7, 2017 at 8:47 PM
    Alpine Beast
    Brent
    Nothing yet
    Checked all my bolts underneath the truck. Seems like the clunk is coming from the rear shocks. I think they are gonzo. Only makes the clunking over bumps. I think the suspension upgrade is in order.
