Best 31" tire size for 17" wheels opinion needed
Discussion in '1st Gen. Tacomas (1995-2004)' started by bodhi armor, Mar 20, 2016.
  1. Mar 20, 2016 at 1:51 PM
    bodhi armor
    bodhi armor [OP] 02’ Dbl Cab- "The Luck Dragon"
    Joshua
    East TX
    2002 4x4 Dbl Cab Jade Green
    I have factory 17" aluminum tacoma wheels from 2002.
    I have a moderate lift At 1.5"
    and I want some 31" or 32" tires.
    I'm curious to get some opinions on the ideal tire size for daily driving.
    Clearance shouldn't be an issue but I don't want to get a tire that's too wide or tires that create too much drag and reduce mpg too drastically.
  2. Mar 21, 2016 at 5:23 AM
    magog45
    magog45 Well-Known Member
    Canada, just south of Santa
    98 tacoma 4x4 extended cab
    5100's all around, 2.75 inch lift, polyurethane body mounts, gibson exhaust, variation of the deckplate mod, intake resonators removed 285-75-16 goodyear AT
    265-65-17 your best bet I would think
    KaptainH likes this.
  3. Mar 21, 2016 at 8:41 AM
    sa1126
    sa1126 Active Member
    San Antonio, TX
    2001 Prerunner 3RZ-FE
    I put 265/70/17's on stock 2wd prerunner suspension and they rub a bit at full lock. Kinda disappointing since the same size on 16's didn't rub but who knows, you might be good with the lift. I got general grabber at2's.
  4. Mar 21, 2016 at 9:37 AM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    Which 17" do you have? Considering no 1st Gen came with 17's from factory I assume you have Toyota 17" from a later vehicle. This matters as backspacing is different.
    ^this is correct, 31" tire size is standard and easiest on mpg.
    so the 265/75-16 didn't rub at all?
  5. Mar 21, 2016 at 9:44 AM
    sa1126
    San Antonio, TX
    Nope, not at all. I never had an aggressive tire on the truck though...previous were all highway tires.
  6. May 4, 2016 at 4:04 PM
    bodhi armor
    Joshua
    East TX
    My mistake, the wheels are 16" aluminum 5 spoke.
    the tires i have now are 265 70 r16.
    How much height difference is there between 265 70 16 and 265 75 16?
    If i wanted a 32" or 33" tire what would you suggest?
  7. May 4, 2016 at 4:31 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    70 is 30.6" and 75 is 31.6"
  8. May 4, 2016 at 6:03 PM
    bodhi armor
    Joshua
    East TX
    Good to know.
    Thanks
  9. May 4, 2016 at 6:25 PM
    KMKtacoma
    KMKtacoma Well-Known Member
    Karl
    Adamsville, OH
    2001 Tacoma TRD 4x4 5spd, 126k miles
    255/70/17 Cooper AT3's, tonneau cover
    I put 255/70/17 cooper at3's on my stock height Tacoma. I was scared that 265/70/17 would rub. I'm glad I went with this size as I was still able to increase my wheel height slightly over stock while also keeping my mudflaps (they hardly rub the mudflaps, 265/70/17 would have ripped them off). Since you have a 1.5" lift, you would be good with 265/70/17.
