Best 3rd gen lift? Under 1000
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Trd_Timmy17, Nov 10, 2017.
  1. Nov 10, 2017 at 5:48 PM
    Trd_Timmy17
    Trd_Timmy17 [OP] Member
    Timmy
    2017 Tacoma TRD Off-Road
    none yet
    Looking for a lift for my third gen but don't really want to go with spacers. Kind of on a budget at the moment, but plan on spending more late 2018. Let me know what you guys like. Looking for 3-4 inches
  2. Nov 10, 2017 at 5:50 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
  3. Nov 10, 2017 at 5:51 PM
    eon_blue
    Azusa, CA
    $1000 should get you 5100s all around, OME springs for the front lift and a 3 leaf AAL for the rear to level it out.
    Actually just saw you want up to 4". If you have a 4x4, it isn't advisable to go over 3" unless you want a lot of issues (or drop a lot more $$$$ on a drop bracket lift). Even at 3" you will probably want to get aftermarket UCAs which would put you over a grand.
  4. Nov 10, 2017 at 5:51 PM
    jsinnard
    jsinnard Well-Known Member
    J
    Virginia
    16 QS DCLB OR 4X4
    You're not going to get a good lift at that height for under $1k, shoot for 2-3 inches under $1k and we'll talk.
  5. Nov 10, 2017 at 5:54 PM
    tcjacado
    tcjacado Well-Known Member
    He could be a 2wd OR in which case he can put maxtrac 4 inch spindle lift on it and then use the 3aal for the rear.
    Btw. Welcome to TW!
    synaps3 likes this.
  6. Nov 10, 2017 at 6:21 PM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    I just got a set of front and rear 5100’s and a AAL set from Headstrong, and installed them today. Total lift was about 1.6” for about $450 (discounted for local pickup). Tested them out just a bit tonight and they all ride very nicely. I wanted the add a leaf for extra weight capacity in the rear for towing. Extremely happy with my upgrade!
    airborndad and tcjacado like this.
  7. Nov 10, 2017 at 11:40 PM
    Trd_Timmy17
    Timmy
    none yet
    If you guys were to get strut spacers for say half a year to a year what brand would you get?
  8. Nov 10, 2017 at 11:49 PM
    Justin
    Justin Well-Known Member
    Justin
    Colorado Springs
    2018 4Runner TRD-OR
    285/75/17 on SCS 6's. ADS front & rear w/ adjusters. Relentless front bumper & roof rack. BAMF sliders
    None. Why waste money now when you can buy something better in a few months like you were saying? Spacers are garbage. Unless you don't care about the ride quality and want to bro it out, then by all means get them. If you want any function though, it's not worth it. to get 4" of lift you'd have to do 3" suspension lift (highly unlikely for $1k) and 1" body lift, or shoot for a 6" lift. 6" lift will put your off road capabilities back to stock, if not worse.
  9. Nov 11, 2017 at 4:46 AM
    jsinnard
    J
    Virginia
    16 QS DCLB OR 4X4
    Spend once, lift once and be done with it.
  10. Nov 11, 2017 at 5:10 AM
    Northern Taco
    Northern Taco Well-Known Member
    2022 Tacoma trd off road premium 2023 tundra trd off road
    If the op is satisfied with the capability of his stock truck, then a spacer lift for looks and bigger tires is fine. 1.5-2" will be fine. Everyone bashes spacer lifts, but if you're not even close to maxing out the capability of your stock Tacoma (most aren't) then a simple spacer will achieve what you want. Don't give the bs excuse about increased drive line angles, what do you think longer coils do?
    Every lift has its place, just because one doesn't fit your needs, don't wright it off as garbage for someone else.
    1cleanFG and mikestaco17 like this.
  11. Nov 11, 2017 at 5:17 AM
    jsinnard
    J
    Virginia
    16 QS DCLB OR 4X4
    He's looking for 3-4 inches, not 1-2. Can't recommend a spacer lift for that height but the OP can do whatever he wants.
  12. Nov 11, 2017 at 8:10 AM
    Northern Taco
    I agree. 3-4" I wouldn't recommend anyway
  13. Nov 12, 2017 at 5:51 PM
    mikestaco17
    mikestaco17 Well-Known Member
    MIKE
    BAD ASS UTILITY CAB
    low range off road 3/1 lift level kit very complete kit and quality parts im running it , very happy with it , remember its your truck
  14. Nov 12, 2017 at 5:57 PM
    coma toy
    coma toy Off Road Taco
    I'm new to this too, so 2" spacers won't affect the ride quality?
  15. Nov 12, 2017 at 6:05 PM
    BeaverNation
    BeaverNation Well-Known Member
    6112/5160’s from race consulting for 930$ wheelers 2 inch aal.
    kodaco771 likes this.
  16. Nov 12, 2017 at 6:39 PM
    Northern Taco
    If the spacer goes on top of the coil assembly,noit won't affect ride quality. If you get the style that goes between top hat and coil (pre loading the coil) then yes that style will stiffen the ride
    coma toy[QUOTED] and mikestaco17 like this.
  17. Nov 12, 2017 at 6:40 PM
    Northern Taco
    If only us north of the border could get those prices. I went with 5100's and they cost enough
  18. Nov 13, 2017 at 5:35 PM
    HeadStrong Off-Road
    HeadStrong Off-Road Well-Known Member Vendor
    2011 Toyota Tacoma and 2019 4Runner
    @Trd_Timmy17 There are several ways to lift your Tacoma. If you would like to PM me we can go over what will work best for you and your budget :cheers:
    Thank you so much @Unchained 5150 :taco:
