Best 4.0 performace upgrade for the money?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Marcus, Oct 5, 2014.
  1. Oct 5, 2014 at 10:50 PM
    Marcus
    Marcus [OP] Member
    Mark
    Redding, CA
    2006 TRD Double Cab V6 4x4
    Pioneer 6965r 6x9's in the front Pioneer TSA1675 6.5's in the rear Kenwood Excleon Deck Kicker 200.4 Amp Dual RF Shallow mount Prime Subwoofers
    Any ideas? After reading through the forums, I have learned that k&n filters are a waste of money, and standard oem spark plugs are the way to go. Any other ideas to increase hp while conserving gas mileage? Muffler maybe? I'm stuck...thanks in advance guys.
  2. Oct 5, 2014 at 10:53 PM
    MGMTacolover55
    MGMTacolover55 Well-Known Member
    Orygun
    2013 MGM Taco TRD Off Road
    floor Mats
    Supercharger is the only way to get real power out these engines. I would suggest exhaust and headers but they only give you like 5-10 hp.
  3. Oct 5, 2014 at 10:59 PM
    Marcus
    Marcus [OP] Member
    Mark
    Redding, CA
    Thanks for the info guys. But I would rather not cut my engline life in half (or close to it). Sucks to know there isn't much out there!
  4. Oct 5, 2014 at 11:05 PM
    Yota64
    Yota64 Professional Threadjacker
  5. Oct 5, 2014 at 11:08 PM
    steelhd
    steelhd Well-Known Member
    Eastern WA
    2011 DCSB TRD OR
    Never heard "cut in half" before but a shortened life is inevitable.
  6. Oct 5, 2014 at 11:10 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    If it makes you feel better there was just a thread talking about how the SC isn't that great either, and joking about how they'd sell a lot less if they had an SC'd demo truck you could drive before you order the 'charger.
  7. Oct 5, 2014 at 11:11 PM
    Yota64
    I personally would wait until I bought a new Tacoma to boost. If I'm going to spend a lot of money, I want it to be on something I will keep forever. This truck will be with me probably for about 10 years. There really isn't a bad time to do it though.
    As for your experience, I am not saying you will have trouble down the road nor do I wish that upon you, but isn't it too soon to collect data? How recent was the install? I'd wait a few more years.
  8. Oct 5, 2014 at 11:13 PM
    Yota64
    I know it was a joke, BUT... For the sake of debate. When buying a new truck, MOST people are looking at a monthly payment. So if the charger was say, 5K added to OTD price... That's like what, 1-2 hundred extra/month? They might just go for it.
  9. Oct 5, 2014 at 11:13 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    The blower needs to come with a smaller pulley to be as fun as 1 thinks..,.... Then again the stock fuel pump cannot keep up with the 3" pulley
  10. Oct 5, 2014 at 11:13 PM
    TheMuffinMan
    TheMuffinMan Banana Nut
    Coeur d'Alene, ID
    2023 Tundra Limited Crewmax 6.5' 4x4
    Only issue with the supercharger is maybe needing to do head gaskets after 90-100k miles after installation, but that's fair in my book. YMMV.
    Beyond that I'd be looking at an engine swap. $$$$
  11. Oct 5, 2014 at 11:13 PM
    Marcus
    Marcus [OP] Member
    Mark
    Redding, CA
    Yeah cut in half probably is an exaggeration. But I do appreciate the tip guys!
  12. Oct 5, 2014 at 11:13 PM
    TheMuffinMan
    Coeur d'Alene, ID
    Where do you see evidence of that? I see people on the 2.85" pulley with no fuel issues.
  13. Oct 5, 2014 at 11:17 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    Its been shown on xru how it drops off on high demand... It cannot keep up.
    I have the 2.85 and would never run a stock pump.
    Just do some digging around...its well known and documented. Iirc on xru it showed the stocker and how it drops off when u need it the most.
    I could feel the difference after the swap.... The truck kept pulling harder and harder and not plateau as quick.
  14. Oct 5, 2014 at 11:23 PM
    Yota64
    Even 100K is not comparable to the potential life of a Tacoma (Hundreds of thousands of miles). Is blowing a head gasket repairable or too expensive to repair properly?
    What about all of the other mods you can do with the charger? I have seen Tacomas hit 0-60 in 6 or 7 seconds. Good enough for me.
    As for the pulley being too large or the fuel pump failing- if I spend 5k on a charger, I'm gonna spend the next few thousand on other top notch parts to make sure it performs at potential.
  15. Oct 5, 2014 at 11:31 PM
    Yota64
    Oh good, because I have heard that aluminum heads with blown gaskets needed to be resurfaced or something like that.
    Whether you have added weight or not-the charger is the charger, and it will always perform better than your stock engine would have without it. Good luck on the future mods.
  16. Oct 6, 2014 at 1:26 AM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    Na 0-60 WAS 6.6
    NOW, according to torque app, 5.8 with wheels spinning till 60+
    So with 4wd and or a track with track tires, I'm sure these bitches can run like the wind
  17. Oct 6, 2014 at 5:56 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    You need to decide where and how much (power and $$$), as there are upgrades but depends on where in the rpm band you want gains and how much money you want to throw at it. XRU is probably a better place to explore this then here. Too many nay sayers here. Boost always is an option, SC or turbo, NA can work, but NA gains are mostly high end gains, not down low.
