Best 6" suspension lift
Discussion in 'Suspension' started by 808wildboi, Apr 2, 2013.
  1. Apr 2, 2013 at 12:08 AM
    808wildboi
    808wildboi [OP] Haaaawaiian!!!
    chase
    kailua kona
    2003 Toyota Tacoma DC 4x4
    If you have the cash, what lift would you buy? Looking for the best lift but not sure which one :confused: I like the bds coil over setup pretty smooth:cool:
  2. Apr 2, 2013 at 12:20 AM
    The Traveler
    The Traveler Desert Chief
    SoCal
    1991 Toyota Pickup 4x4 Prerunner
    I believe that is a drop bracket lift. I've never seen one on a Taco in person, but 4" blocks in the rear doesn't sound too appealing to me. And at $3300, I'd expect at least a new leaf pack. Not too sure what kind of spindles those are, but they look beefy. I wonder if they have any lift on them.
    Most guys on here with 6" lifts go with Pro Comp or Fabtech.
  3. Apr 2, 2013 at 12:26 AM
    cameronlane
    cameronlane Well-Known Member
    cameron
    Anywhere but there
    2014 Dbl Cab TRD OR 4x4
    the best would be any bracket and then get king c/o's and king resis in the rear with real leaf packs. But that would just be silly to do that. They are all pretty much the same. lots of folks here like the procomp lifts.
  4. Apr 2, 2013 at 12:36 AM
    AaronArf
    AaronArf Well-Known Member
    Aaron
    VA Beach
    2023 LR OR DCSB
    The two long running contenders are Fabtech and Procomp. With the BDS kit, it looks like they subsidize the cost of the Fox coil overs by skipping the AAL. If I could do it again I'd go the BDS route. That's if I even went with a 6" lift again.
    Either way, the stock leaf packs suck and even with a AAL/Block combo you'll eventually want to change them out for some custom 6" lift packs. My rear is sagging after 18k miles on the stock leafs/Fabtech AAL.
  5. Apr 2, 2013 at 1:24 PM
    808wildboi
    chase
    kailua kona
    Dud your setup is sick man! I'm curious, how did you fit your 35s on your truck? I know most 6 inch lifts require some trimming. Do you have a body lift on too?
  6. Apr 2, 2013 at 1:32 PM
    Manwithoutaplan
    ID
    if you dead set on the 6 inch i would go with DBS.
  7. Apr 2, 2013 at 1:34 PM
    Manwithoutaplan
    ID
    IF you do go with pro comp just get stage 1 and then get icon's for shocks.
  8. Apr 2, 2013 at 1:46 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Best 6" lift you can get is hands down SAS :cool:
  9. Apr 2, 2013 at 1:53 PM
    Manwithoutaplan
    ID
    Very true ^ but most people just don't have 10k laying around.
  10. Apr 2, 2013 at 3:44 PM
    808wildboi
    chase
    kailua kona
    Sas would w nice. It's worth the money. If you can afford it haha
  11. Apr 2, 2013 at 4:01 PM
    Pugga
    Massachusetts
    True but first post said "If you have the cash" :D
