Best a/t tire nowadays?
Discussion in 'Wheels & Tires' started by h22dx, Mar 5, 2014.
  1. Apr 24, 2014 at 11:46 AM
    #121
    AlanLoshbaugh
    AlanLoshbaugh Well-Known Member
    Alan
    Columbia, MO
    2013 Tacoma Double Cab 4x4
    For any of you guys who have at BFG AT, and Cooper Maxx:
    how do the Cooper Maxx do in the snow, on the street?
    the BFG's were really good
  2. Apr 24, 2014 at 1:14 PM
    #122
    2wheelnut
    2wheelnut Well-Known Member
    Angelo
    Vallejo, CA
    '11 S/C K.I.S.S. "Factory Enhanced" DC TRD OR
    TRD Supercharger, TRD First Gen CAI, TRD FJ Alloy, Toyo OC A/T II 265/75/16, 5100's Front and Rear, OME 885x with 1/4 taco lean spacer, Toytec AAL 1.5" non TSB. TSB not done. WheatherTech Side Window Deflector, Satoshi Grill, T Rex Eyelids, Matt123 Skid Black stamped, Modded Maglite with Maglite mod for driver seat, Bed extender. Full debadging
    Toyo Open Country AT II. Thick side wall and the rock ejecting blocks actually do work! One of mine has a cut on the sidewall, pretty deep from a sharp rock. Still running strong after three wheeling trips.
  3. May 3, 2014 at 9:12 AM
    #123
    el taco loco
    el taco loco Well-Known Member
    USA
    '13 DCSB Sport 4X4 in 1E7
    Just got a Toytec Boss 3" lift and LR uca's and am sitting at Discount Tire waiting for my special order 275/70R17 Hankook Dynapro ATM's to be mounted up onto my stock sport alloys. They're going to test fit one front to check for rubbing, but I don't anticipate any issues. Replacing the stock Bridgestone Dueler H/T's, 265/65R17's that weigh in at 38# vs the Dynapros at 58#.
    Been averaging 16.5 mpg with roughly 50/50 highway/city. Expecting some loss from already disappointing mpg numbers. Oh well, if I'd been looking for high mpg numbers, I would have bought a Prius. Mmmm...probably not!
    Update: no clearance issues at all. Tires ride smooth and quiet. Set them at 40 psi and I can tell whether a dime is heads or tails up when I roll over it! Haha!
  4. Jul 8, 2014 at 5:59 PM
    #124
    ScudRunner
    ScudRunner Three Tacomas Deep
    Erik
    Twin Cities, MN
    07 TRD 4x4
    IMRYO mirror mount, color keyed front and rear, SCS wheels, 5100 on corners, ALCAN leaf packs, ECGS bushing
    Since some folks have commented in this thread:
    Advantages of P-rated and LT tires? Strictly loading? Speed rating?
  5. Jul 8, 2014 at 6:26 PM
    #125
    Jeremy M.
    Jeremy M. Well-Known Member
    Fort Drum, NY
    13 DCSB TRD Off Road
    Cooper AT3
  6. Jul 8, 2014 at 6:30 PM
    #126
    tacoman00
    tacoman00 Your Average Joe
    Rockville, MD
    2021 TRD Off-Road DCSB
    Toytec BOSS 2.0 lift, 18x9 Fuel Rebels, 32” BFG AT K02.
    Can't go wrong with a set of Duratracs. As you can see, they're tried and true.
  7. Jul 8, 2014 at 7:59 PM
    #127
    ThomasMore66
    Dallas/Fort Worth & Durango
    Putting Toyo Open Country AT2's on my new FN BFD's tomorrow. Special order at Discount here in the Dallas Area. I'm stoked.
  8. Jul 8, 2014 at 9:14 PM
    #128
    92dlxman
    92dlxman drinking whats on sale
    Kevin
    Visalia, CA
    08 access 4x4 4.0 6-gear
    5100s, ome884s, wheelers aal kit, and some rustoleum
    im running the walmart goodyear authorities, and have been for some 10k miles or so.
    for traction, excellent! air-em down and they absorb rocks well, plenty of bite in snow (I only play in snow off-road at slow speeds though), and plenty of bite in mud. the side-lugs make getting out of muddy ruts much easier than most tires.
    wear overall looks good, but my fronts (never rotated) ended up with a funny wear pattern I have never seen other than on over-loaded welding trucks sporting the same tire. alternating hi-lug, low-lug. . . .weird I rotated to try and save them and they are all squared up again.
    they are "loud" compared to most a/t tires
    walmart will no longer put on other than factory size.
    any service like balancing, rotating, turns in to hours long escapade at walmart
    they balance. . . .errrr, not balance good.
    plenty of rock-rash on sidewalls without puncture. in-fact, no repairs period on these.
    next I will either be going bfg mt km2 or cooper stmaxx, but cooper is very proud of that tire
  9. Jul 8, 2014 at 9:19 PM
    #129
    EatMyTacomaDust
    EatMyTacomaDust Well-Known Member
    2014 "Black Beauty" Baja DC 4x4
    ICON 3" LIFT, Console Vault, Tailgate Security Clamp MOD, SuperBumper Crash Attenuator, TRD Front Skid Plate, Wet Okoles - 1/2 Piped, Undercover SE Tonneau
    BFG AT's - These tires TRACK HARD. Luv 'em!
    Of course it helps if you have the RWL OUT. . . ;)
  10. Jul 8, 2014 at 9:23 PM
    #130
    ThomasMore66
    Would Jimi approve?
  11. Jul 8, 2014 at 9:26 PM
    #131
    DannyD57
    DannyD57 Member
    DannyD
    Palm Beach/Birmingham
    13' DoubleCab TRD Off-Road 4x4
    3" Lift. N-Fab Step Bars Black Rhino Sidewinder. 285/75/18 Toyo Open Country A/T 2. BakFlip G2 Bedcover
    I Run the Toyo Open Country Xtreme AT2, and i absolutely love them.
    I personally think they are the most aggressive looking AT's and they're super smooth and quiet. Also, you don't see them as often as the Duratracs or TerraGrapplers. So when you do see them you remember. Best of Luck!
  12. Jul 8, 2014 at 9:28 PM
    #132
    EatMyTacomaDust
    I think he would - they're the Stratocasters of Tires!
  13. Jul 8, 2014 at 9:30 PM
    #133
    ThomasMore66
    Hey Joe! What are you doing with that gun in your hand?
  14. Jul 8, 2014 at 9:34 PM
    #134
    ThomasMore66
    I hope so. It's been one big research project. This is sort of a stopping point for me for a bit. Lift and wheels/tires all sorted out. Now I need to decide about the supercharger. Might need to let the checkbook cool off.
  15. Jul 9, 2014 at 7:46 PM
    #135
    ThomasMore66
    I'm liking the Toyos so far. Every bit as smooth as stock, but they are "hummy".
  16. Jul 9, 2014 at 7:50 PM
    #136
    45longcolt
    45longcolt Well-Known Member
    DFW Area
    2020 Off Road
    I haven't heard that phrase in decades, thanks for the visual flashbacks!
  17. Jul 9, 2014 at 7:50 PM
    #137
    ThomasMore66
    Dates me.
  18. Jul 9, 2014 at 8:11 PM
    #138
    45longcolt
    DFW Area
    2020 Off Road
    Me too for recognizing it. And to stay on topic, I am on my second set of Hankook ATM's. Got 73,500 miles out of the first set.
  19. Jul 9, 2014 at 9:31 PM
    #139
    EatMyTacomaDust
    You know I'm goin' to shoot my ole lady - caught her messin' round with another man. . .
    And that ain't too cool. . .
  20. Jul 9, 2014 at 10:08 PM
    #140
    MedlinAround
    MedlinAround Failure is the result of letting setbacks stop you
    Cody
    Kentucky
    2008 TRD off-road edition Tacoma
    Bilstein 5100's, OME 885X Coils, Dakar HD Springs, Fox 2.0 Rear Shocks, Magnaflow exhaust, Volant Intake, OKledlight pods, Front Skid Plate, Weathertec Floor Liners, Custom Bed Rack, TRD Nation interior LED dome kit, 4X innovations sliders, DIY Roof Rack, Smittybilt RTT.
    I absolutely love my Firestone A/T. If you would have asked me before i bought them i would have been like ummm. Got a great discount on them a few years back so i gave them a try.. They have about 45k miles on them. Tones of thread left, even great wear. No sound. Good on snow and in the mud. No complaints here, will probably buy again
