Best A/T Tires???!
Discussion in 'General Tacoma Talk' started by BiggiesTaco, May 15, 2023.
  1. May 15, 2023 at 1:39 PM
    BiggiesTaco
    BiggiesTaco [OP] Active Member
    San Diego
    2017 TRD OFF-ROAD 4x4 Tacoma LB
    Hi everybody. I’m do for an upgrade on tires soon. I bought some 17” methods and I am torn between the BFG KO2’s and the Falken Wildpeak at3w’s. I’ve heard good and bad about both but am open to other opinions. I live in San Diego and it’s also my daily driver but when I do off-road I stick to the desert and have future plans to off-road in Baja California. Any suggestions? Looking at 275/70r17 for size. Thanks !!
  2. May 15, 2023 at 1:43 PM
    dangeroso
    dangeroso Just float along and fill your lungs
    Jon
    Dallas, TX
    2018 Tacoma TRD Sport 4x4
    There's no best. It really depends on application and needs. For a daily driver I would not consider KO2s, but that's just me. I had them very briefly in an E rated version and they were terrible to drive on most of the time. Zero sidewall flex translated to a very rough road ride. I have had the Falken Wildpeaks and thought they were pretty good. I currently have the BFG Trail Terrain TA and I like them better than the Wildpeaks. Haven't really tried anything other than those 3.
  3. May 16, 2023 at 9:09 PM
    Phlogiston
    Phlogiston There are no victims, only volunteers.
    Not Karen
    The wild west
    2016 SR5 DCSB
    Aesthetically Challenged
    I used KO2's for nearly 20 years on my frontier and they were great. my current set is Wildpeak AT3w's. I like them both and mine is a daily driver.
  4. May 16, 2023 at 9:12 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission 5.29 R&P FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Bed Light Kit VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Customized 2WD Low Operable (Switched) Clutch Safety Bypass
    I think the wildpeaks suck and wouldn’t recommend them at all. BFGs are meh. I’d check out the Toyo ATIII or General Grabber A/Tx. I really like both of those. Toyos have been the smoothest but they are a bit more mild.
    MM_Trkr2020 and Road_Warrior like this.
  5. May 16, 2023 at 9:16 PM
    Gingerbeard Man
    Gingerbeard Man Well-Known Member
    Jared
    North Dallas
    2016 MGM DCSB Sport 4x4
    Icon stage 3 tubular 285/70/17 Toyo ATII
    I did not care for my K02 at all. They have been my least favorite. I liked the Ridge Grappler a lot and so far the Wildpeak have been as good if not better. Toyo was decent, step above the K02.
    drizzoh likes this.
  6. May 16, 2023 at 9:17 PM
    650H1
    650H1 Well-Known Member
    Michael
    VA
    2020 (Cement) TRD O/R
    Duratracs prob
  7. May 16, 2023 at 9:20 PM
    boston23
    boston23 Well-Known Member
    Adam
    Eastie
    2019 SR5 DCSB 4x4
    Love my duratracs
    650H1 likes this.
  8. May 16, 2023 at 9:20 PM
    Veet-88
    Veet-88 Well-Known Member
    18 Tacoma DCLB sport
    Another unpopular vote for duratracs over here.
    650H1 likes this.
  9. May 17, 2023 at 3:42 PM
    Mouat
    Mouat Member
    Fresno California
  10. May 17, 2023 at 3:59 PM
    Syncros
    Syncros Well-Known Member
    I've had a bunch over the years. Rugged Trail, KO2, Duratrac, Dynapro ATM, Wildpeak AT3W.
    Favourite of them is the Wildpeak. Most over rated was the KO2.
    drizzoh likes this.
  11. May 17, 2023 at 4:00 PM
    Road_Warrior
    Road_Warrior There is nothing on my horizon except everything
    East Coast
    2021 Black SR5 4x4
    Check out the Mickey Thompson Baja boss AT’s. They became super popular recently, probably for a good reason. I don’t have them but I’ve been doing a lot of tire research and I haven’t found a single bad review of them.
    If you do a lot of sand, they would probably be great for you.
    https://www.tacomaworld.com/threads/mickey-thompson-baja-boss-at.751616/
    I have General Grabber ATXs and I have been very happy with them.
    Psybain likes this.
  12. May 17, 2023 at 4:03 PM
    BuzzardsGottaEat
    BuzzardsGottaEat Well-Known Member
    Some Toyotas
    Round tires
    Wildpeaks will be fine for what you’re doing. They wear fast in the standard load due to the softer winter rubber. They will wear slower (but ride slightly more harsh) in the LT rating with deeper tread and harder rubber. California and Utah rock ate through the Wildpeaks on my 99 4Runner pretty quick and that’s a light vehicle.
    Others to consider would be Toyo ATIII for sure. Coopers worth a price comparison as well.
    Those wheels and tires won’t fit a stock truck without some :sawzall:
  13. May 17, 2023 at 4:19 PM
    Veet-88
    Depending on the offset it should fit with only mud flaps removed.
  14. May 17, 2023 at 4:32 PM
    Dan71
    Dan71 Well-Known Member
    Dan
    1996 Tacoma
    Bone Stock
    No love for Coopers?
    BuzzardsGottaEat likes this.
  15. May 17, 2023 at 6:24 PM
    BuzzardsGottaEat
    Some Toyotas
    Round tires
    Not if you cycle the suspension at all ha.
  16. May 17, 2023 at 7:17 PM
    Veet-88
    Slight alignment tweak and it'll go I test fit 275/70r17 k02's before sticking with duratracs and they only hit the sports bumper lip and mudflap. That was on a +1 wheel, now having said that the k02 is noticeably smaller than other tires of equivalent size.
  17. Jul 4, 2023 at 7:48 AM
    Twodan
    Twodan Active Member
    Dan
    South Eastern Mass
    2025 Supersonic Red Limited
    Stock
    my 2021 came with Michelins. Suggested TP is 22PSI. I was surprised thinking they were too soft. When warmed, they are fine over 36 PSI. I would replace with the same when needed.
    Dan
  18. Jul 5, 2023 at 9:23 AM
    66stang5.0
    66stang5.0 Member
    Oscar
    2016 Grey Tacoma Sport 4x4
    Stock
    Can’t beat the ko2’s long thread life and perform well in almost every condition except mud.
  19. Jul 19, 2023 at 11:00 AM
    EL DUDE
    EL DUDE Well-Known Member
    I’ve had KO2s, coopers, and finally was shown the light and gods providence with the Yokohama Geolandar AT
    best tire I’ve ever run. Great on snow, mud and rain, I get 50-60k miles a set. I’ve used them exclusively since 2010. Will never not run them
  20. Jul 19, 2023 at 11:09 AM
    Psybain
    Psybain Well-Known Member
    SE AZ
    2022 Lunar Rock 4x4 TRD OR
    Another vote for the MT Baja Boss ATs. I've been using them as my daily driver for a few months and they handle just fine on and off road so far. Looking forward to see how they handle off road now that monsoon season is kicking in
    Road_Warrior[QUOTED] likes this.
